201
thanks for great update , please consider updating to native VR support for both A320 and 330
thanks
202
Underparts wrote:
Great job on V3r4 update with improved FMGS. NAT tracks now working, thank you.  I have noticed with this release TCAS is not working for online traffic on VATSIM any suggestions?  Changing number of AI aircraft makes no difference.
I told this weeks ago, TCAS not working for me in Vatsim. On ground I put this in TA Only and the ND show TA ONLY, but if I move the knob to TA/RA the message TA ONLY disappears and dont work.
This saturday is the biggest Vatsim event "Cross The Pond 2018 Westbound" with 650 flghts booked. Please please give us a fast  solution.
203
Me to as well
204
I already gave feedback because of that and for any reason its being ignored or there are no real pilots interested in real performance...The plane burns 20% to less fuel. The fuel flow is unrealistic (based on the performance according to PFPX that should be quite realistic). I dont know why nobody noticed that til now...the Fuel Flow was almost perfect in the last stable version for X-Plane 10.
205
This is one of the annoying gripe sessions ! What do you mean with fuel flow/ Do you mean fuel flow to engine? (f = [(Tt4 / Tt3) - 1] / [(nb * Q) / (cp * Tt3) - Tt4 / Tt3]), do you mean fuel flow from one tank to another? Or du you want to say fuel burning/h (consumption)?   Generally to say the A330 burns 20% too less fuel is nonsense! Fuel burning depends of X factors like FL, winds, weight, temp, engines type etc. that variate from flight to flight. You have not give us one example  a n d  numbers that we can compare for a serious discussion......
206 (edited by Franz007 2018-04-15 13:43:56)
Of course i can give examples. You should know that when you use a professional flight planner, every parameter already is taken into account in the flight planning, like weights, winds and temperature. I made like 10 long-haul flights with the A330 and each time it burned 20% less fuel than planned. You can try by yourself. Use the maximum fuel and full passengers. You will see that you can easily fly from Perth to London. Is that realistic with the A330? No it isn't. So its obvious there is somtehing wrong. I was just a bit schocked nobody saw that til yet even if its quite obvious. I am not talking about 1-2% of differences but 20%. So instead of burning for example 60 tons, it burns 48 tons. Thats quite a lot wrong...
So my post was first about this error. If the developper is ready to fix it i can help him with examples, as i already did 5-6 years ago with one of the first versions of his A330. I helped him calculating the right values.
207 (edited by sidiclei 2018-04-16 15:45:13)
hello there. Since I updated my A330 I've being having a problem. It doesn't fly straight. It flies in zig zag. Does anyone know what's going on? I love this bird and use it all the time with my long haul flights. Attached are pictures of what it's being doing lately.
thank you!
208
Well, you didn't deliver exact numbers for a certain flight, but let discuss the mentioned flight London/Perth:
At 538mph the flight will take 17.10h over a distance of 8261nm (no way in 10h even less 20%) and fuel consumption with max. 253 passengers and 0 freight will be 111272kg.  All that means that the A330-243 is not capable to reach Perth. I would like to see you flying this distance with JAR A330 in a full video and if so I promise to eat my hat....
Image of the A330-243 calculation
http://jardesign.org/forum/img/m/1591/t/p1cb71u63i1h4n1i119eg1ivp1k8o3.jpg
To the point. All my flights until now were calculated using simBrief.com (inclusive 1 hour flight reserve) and compare to MCDU data and the results of remaining fuel after landing the calculation seems to be correct.
209 (edited by Franz007 2018-04-16 17:32:14)
Seriously i am quite surprised. I first didn't want to invest time in having to prove that there is a problem and am seriously wondering why you still didn't notice the big difference in fuel burning beetween reality and that model. I was expecting users here having enough knowledge in aviation like having made observations from real DVD-flights and cockpit preparations etc. to notice this inacuracy. Anyway, here are the exact numbers:
On the left you will find the burning rates according to the original performance table from Lufthansa and on the right the ones measured during a Test-Flight with the Jar 330:
weight 185'000kg, FL390, M 0.80: 2'599 Kg /h    Jar = 2'099 Kg/h (difference: -19%)
weight 180'000kg, FL390, M0.80: 2'507 Kg/h    Jar = 2'054 Kg/h (difference: -18%)
To measure it i disconnected the Autothrottle and adjusted the thrust leveler to the exact point where the speed stayed at Mach 0.8 during at least 10 minutes, so that the FF was constant.
The test-flight i made was LSZH-GMMN. The professional flight planner PFPX - built using real world professional performance datas - calculated 14'852Kg of Tripfuel. But the Jar burned only 12'360 Kg on that trip (-17%) although the winds were quite similar to the ones taken into account by the Flightplanner. On longer trip these difference is a bit bigger since the take off and landings are counted in that number and on short trips the cruising phase is shorter compared to them.
Another thing i noticed is that the take off performance seems to be quite inaccurate as well. I could barelay take off form RWY 28 in LSZH (2500m) with a weight of only 190 tons, flaps 2 and Flex 40. I had to push the throttle to TOGA to lift off 300m before the end of the Runway.
Summary: the perfomance of the Jar 330 is quite inaccurate and i dont understand why nobody noticed that before or why there is no interest fixing that.
210
Just one note to Franz007:
Lufthansa has 19 330-300 airliners
Jar Design is    a  330-243 airliner
Conclusion: both are different types with different specification
Not comparable ! .....
211 (edited by Homer.Simpson 2018-04-16 22:22:52)
Well the Performance table mentioned above does belong to an 330-200 as found in the Infos below that table. But the table is for the -200 equiped with PW4168A engines instead of the RR Trend engines, which could be a reason for the differences. Furthermore you should take in mind that the table is only used in ISA Standard Atmosphere and for a CG of 37%, so if you have flown with real weather and another CG there are more factors which could lead to differences.
I will also do another check flight to see if there are any significant diffences in fuel usage on my side.
212 (edited by Franz007 2018-04-17 15:48:40)
No it was for their A330-200 they had. and not for the A330-300.
213 (edited by Franz007 2018-04-17 16:10:14)
Ok so let's invert the question then. Can you please give the source where the actual fuel consumption of the Jar330 applies? I need the real values and a source. If you are doing further tests, what will you compare the results with? To which source? And seriously, the CG and ISA temperatures wont made that much of a difference. They don't even do it in the FF 757, FF320 or IXEG, where the fuel burning rate matches the tables. So it doesn't make sense arguing which such details.
We had the same problem with the FF 777 who suddenly had wrong performance when used in XP 11 compared to XP 10 and that has been discussed in the org forum many times. And the same seems to happen now with the Jar330. The Fuel Flow was correct in XP 10 and now its burns 20% less on long hauls. So can you explain me why this happened? Is it because of CG? Is it because of the ISA temperature? Where these values all wrong in XP 10, although how wonder they matched all comparaisons with real values?  Its's so obvious there is a problem and i can't understand why some users don't want to accept it. There is no argument or prove at all that shows the actual values being right. Its the opposite in fact: every comparaisons shows they are not. I really would appreciate an official statment form a developper here.
214 (edited by Homer.Simpson 2018-04-18 21:00:41)
So today i did a test flight LSZH-LGKR with an OFP made using Simbrief. See attachment loaded the A332 to match fuel and MTOW using the CI and FL.
Trip fuel which should be used in accordance to flight plan: 9049kg
Trip fuel used by the Jar A332: 83xx kg (Don't remember the exact value, thought that I've made a screenshot of the FU indication on touchdown, but it wasn't captured)
But did also an enroute fuel used check:
Waypoint DIPEP fuel used in accordance to OFP: 6700kg
Waypoint DIPEP fuel used by Jar A332: 6105kg
So here I've a difference between Simbrief OFP and JAR Bus by around 8%
215
Yesterday I made a flight from SBBR to SBDN (Brazilia) using also data from simBrief.com. Prediction of fuel consumption for flight (exclusive 15 min push and taxi) 7274kg. At the end of flight (40kt tailwind over all flight route)  the difference to JAR A320 was 7%. I guess that flying under other wind conditions the difference could be less.....
216
Had a CTD today flying from EHAM to EGLL. Everything was running well until I had to re-program the MCDU to change the runway landing direction from 09L to 27R. X-Life gave the new direction when I asked for decent. While re-programming the MCDU XP crashed. I had pre-planned for 09L, things changed on route.
I can't see how to attach a Log.txt on this forum, I did look at the Log.txt, but I'm no expert at reading it. Having said that it didn't show a crash it just ended.
217 (edited by Franz007 2018-04-19 18:03:39)
@Homer and Ilankrt: i doubt Simbrief is an accurate base. Or do you seriously think its more accurate than PFPX? Without comparaisons with real tables like i've done its useless. And below 3 hours of flight its also quite useless since the main difference appears during cruise. And on short flights you wont remark that difference because 5%-7% could be also because of winds differencies or differences in take off / approach performances. So its not an accurate way to compare.
Anyway: it was about the A330 and not the A320 (to Ilankrt)
So as long as nobody can show that the values are correct based on REAL tables like i've done, do we have a chance that these wrong fuel burning values will be fixed in future? But as it seems there are no developpers reading here?
218
boastler wrote:
AirFMC wasnt working for me after the most recent update. Is this a bug/any plans to fix, or is it a problem on my end? It said something about not being able to read the .acf file. Or is it a haversine issue they should fix?
Hello, this is something i would like to know as well please, Haversine is claiming, that the issue is not on their side.
I bouth the JarDesign A320 and A330 only because they were listed on AirFMC Page as compatible (yes, i first bought the FMC, then bought planes i can use with it) so you have at least one customer who came to you thanks to them wink
Please get in touch with Haversine Air on this topic
219 (edited by shanemontoya 2018-04-23 01:40:18)
v3r4
1. ZBAA RWY36R Go-Around route - why the aircraft draws such awkward turn like that?
2. Missing runway symbol ("="symbol)
3. Alt constraints below FL100 shouldn't show "FL" - 3940ft shouldn't be FL3940 right?
4. From cold and dark, why the RAT is deployed?
5. After takeoff, the ND went out however the zoom function of the ND is still available.
6. Forget one thing during engine start - before clicking the ENG1, the EPR indication in the EWD rotates violently - I just used keyboard for my engine input, no hardware throttle control.
7. F-PLN in selected mode - the curved f-pln is still solid, but the rest of the straight lines are dashed.
I am using the latest stable version of XP11.
Please fix them in the next version.
220
shanemontoya wrote:
v3r4
1. A330 works fine to me
2. Please read checklist fot A 330 you will find in "JARDesign Group Board → Flying school, DOCs, FAQ → Airbus A330 Jardesign Checklist & Real A330 flight procedures Video" so you will correct prepare aircraft for fly
3. Your point 7 its dashed becouse you have entered heading 182 and not have in automatic position.
4. Your point 1 - missed approach route. Its look that MCDU missed to put on plan Track fix PEK, but if you fly 6 nm straight and then turn AP its all be fine. I add picture for missed approach procedure from Little navmap.
5. When you start engine start first engine, wait for that engine is AVAIBLE and then start the second engine. Throttle is in IDLE position.
6. ND go out becouse you maybe by mistake turn ND to off. Look knob on left side of panel.
7. RAT is maybe  deployed by you by mistake.
8. At the end why you are on runway width no started engines ?
9. I'll try to make fly from ZBAA to ZBAA width FPLN from 18L to 36R with procedures saw on your pictures without problem including GO ARROUND.
http://jardesign.org/forum/img/m/4390/t/p1cbone8f11knt1ku5rrv10tb1eip3.jpg
221
I just updated to Version 3.0. The handling is much better but I noticed that the aircraft ascends and then descends a few feet during the cruse and does not hold at assigned FL. Also the auto throttle is constantly adding and reducing power.
222
shanemontoya wrote:
v3r4
You should begin with a Cessna 172. It is the best way to learn how to fly and use instruments correctly......
223 (edited by shanemontoya 2018-04-23 12:15:28)
shanemontoya wrote:
v3r4
I followed all the instructions (I started using JAR when their A320 was in version 1.2 so you don't need to ask me to read about the FAQ - we wrote the operation manual in simplified chinese dated back in 2014 in Chinese x-plane portal).
My point 7 - yeah in the selected mode all the f-pln should be in dashed however only the straight lines are dashed - I am asking why the curves are not. (And from that time I have pointed out there was no dashed line in selected mode in 2014 but no one replied in this forum.)
My point 1: simply because the drawing algorithm for the f-plan and ga route is not as clever as other aircraft. Just admit the fact that it has shortcomings and will improve.
For starting the engine sequence - first engine? it doesn't matter which engine starts first - both engines indication rotates. Throttle is always in idle position. Usually we start our right hand engine first as the jetways are usually in our left side - starting engines from the right side will minimize the risk of potential damage to jetways if the engine on the right side fail/or catch fire.
ND went out - come on I didn't touch anything.
RAT - again I didn't touch anything.
On runway without engine started - simple. I respawn on the runway just to test the aircraft. Are there any problems?
Please, focus on my findings.
And thanks for the map however it's rather useless to me. As the RL airline guy, I have the latest and full set of charts for ZBAA published by CAAC and my company operates about 20 flights a day to ZBAA.
Anyway thank you for your reply.
224
I did not know that you are, as I read your answers, expert player with completely new problems with A330.
Your point 7 - sorry I don't read well your question.
When I say start first engines I mean first started engines and not engines number 1.
I wish you a nice flying with this excelent plane.
225
Today I did another fuel test flight. Duration: 6,5h of flight. As source I used a real world OFP for an A330-243 and simulated the flight which took place at the same time.
As per OFP I should have used 31100kg.
As per vacating the runway I have used 27600kg, so only 89% of the planned trip fuel
AT the middle of the flight I only used 93% of the fuel I should have used.
So I'm still not getting your results.
