126
Re: X-Life ver 2.2 R1, R2, R3 for X-Plane 10/11
Good morning X-Plane 11.20b5 x-life2.2r3 CTD when calling FMcar
X-Plane 11.20b5 x-life 2.2 r3  unknown crash
128 (edited by seppl 2018-04-17 11:41:43)
Hi JARDesign,
thank for this neat plugin! Everything works nice for me so far.
The only thing I have are the same microfreezes than annette-kuehnelt has!
annette-kuehnelt wrote:
Hi JAR Devs,
Departure and Arriving Airports now have traffic in R3.
I still get the problem with microfreezes (approx every 15 seconds freeze for 1 second and above) with 2.2 R3. You can recognize it when monitoring in CPU load. (plse have a look on screenshot). For me its like a stop breathing and I can not enjoy...
http://jardesign.org/forum/img/m/3642/t/p1caa9opbiidurb7eaqq8l17qo4.jpg
With 2.1 I can not figure out that problem and there is no hint in monitoring CPU. (plse have a look on second shot)
http://jardesign.org/forum/img/m/3642/t/p1caa9opbiq9h1p3r1p6d5dk24b3.jpg
For troubleshooting I tested on fresh Win and XPlane installation as well without any other 3rd plugins.
System: Win 10 (latest version), XP 11.11, I7 7700k, Graphic NV 1080ti, 64GB RAM, Win on NVM SSD, XP on NVM SSD
Is it possible to get version with functions and features from 2.2 with the 2.1 variant of RAM usage that CPU do not stock after loading for XLife?
Many thanks in advance for your comments.
Best wishes
I can confirm the same stutters!
I found out that these stutters depent on the "bluebell library". When I start X-Life then I get the stutters every 10-15 seconds, exactly the same time when a file
from the "bluebell lbrary" is loaded with a higher transfer-rate (this is what I can see in the "filemonitor").
After approx. 40-45 minutes the whole "bluebell library" seems to be read and the stutters are gone!
Annette can you confirm this (when you are patient ;-) )?
So, the question is:
Is there a better way to get all the information from the library?
Maybe you read the library only once and the info, database or whatever is stored somewhere, so we don't have the stutters every time we start this very nice plugin!
Seppl
129 (edited by Philou67 2018-04-17 12:17:24)
Thanks Seppl,
I remove the Bluebell library
Trafic started i have now 40 FPS, it's better than previous 17 FPS but there must be a solution to optimize it a bit more and when we stop it why we can't recover the FPS before stat
130
xlife crash mz xplane if i start xlife in cold and dark , if i start xlife after cold and dark its not crash
and i have crash, request fm car over atc, xplane crash
132
As result of a discussion about the A330, I wanted to reconstruct the flight route EGLL/YPPH. For YPPH there are in X-Plane.org  2 airport sceneries. As I tried to instal them, each one of them cause X-Plane to crash. Trying to download the scenery from JAR airport ready Google Map failed. Has anyone a functional YPPH scenery ? Can someone explain what can cause this crashes? (I can use other Australian airport sceneries without any problem)
133
Let us take a brake for a moment from all complains and have a look at a short video of mine:
Since we have the JAR plugin X-Life we can experience not only AI traffic at airports on ground, taking-off and landing but also on our flight routs. In this short video I am on flight with JAR A330-243 from SBRF to SBBR in Brasilia flying near another airliner on same route leg...
https://youtu.be/9s0zc2M-otU
134
Video link don't work for me
135
seppl wrote:
Hi JARDesign,
Hi JAR Devs,
Best wishes
Seppl
Hi Seppl,
exactly, I can figure out what you have reported and can confirm your hint. In ressource monitor I can observe same situation when loading file objects of the bluebell directory and CPU thread report short interrupt. I can compare in XP when new aircraft occurs on XLife radar the short freeze (interrupt) happen. Freeze also happens sometimes when XLife aircraft operation begins (begin pushback), but freeze time is not so long. After approx 45 min. XP works more fluently wih XLife.
I also tested without the bluebell library, with the planes of openscenery but freezes comes up as well for me. Frames increases without, but in comparison with bluebell there is no big difference for me as I usually get over 30 and on bigger ports like EDDF around 30 FPS.
Hope for a fix.
Many thanks in advance.
Best wishes
Annette
136 (edited by ilankrt 2018-04-17 21:57:13)
Sorry correct.....
137
Is there any chance that EGKK runway 26L could be corrected. You can never get a clearance to take off as there are always a number of aircraft waiting long before your aircraft gets to the holding point.
You always have to take off without clearance and hope X-Life sorts it out before climbing to final altitude.
138 (edited by FerDiaz 2018-04-25 13:39:22)
In EDDF (Frankfurt), X-Life 2.2r3 indicates SID DKB1D for outputs on runways 25L, 25C and 25R when DKB1D is for outputs on runways 7C and 7R as can be seen in the attached images.
http://jardesign.org/forum/img/m/6583/t/p1cbugdv4imnn1equ1o3218gf1197.jpghttp://jardesign.org/forum/img/m/6583/t/p1cbugbt1o1eng1g3bh8blnr87b3.jpg
139 (edited by iFred 2018-04-30 11:31:53)
Welp. Tried x-life the first time today, and with a sad heart I have to report that it totally kills FPS (Example at EDDF, 25 % traffic, 60 to 18 FPS constant).
Edit: Thread optimization on the nvidia control panel did the trick. Almost no frame hits now.
one question. I understood that from version R2.1 Xlife add real scheduled flights. I use LIRQ (Florence) as my base airport but i never see Air Dolomiti E195 in this airport and a lots of Air France. Bluebell aircrafts is installed. Do you know why this lack of this airliner ? Thank you.
Marco
Hallo, since yesterday i have a -30 FPS decrease. nothing was changed.  i tried 11.11 and 11.20R3. Thread optimization is on. when i deactivate in plugin admin then the FPS goes up. any ideas? thank you
142
Hallo
X-Plane 11.20rc4 x-life 2.2 r3  unknown crash.
From LOWW to EDDM. Approach EDDM.
143
With some airports, here KABQ, I am seeing differences in line and gate positions between airport editor and what can be seen in X-Plane (see attached screenshots).
Does anyone know why this happens? It makes it almost impossible to produce a good .xlf file for such airports.
144 (edited by iztok.slanic 2018-05-06 22:22:18)
LIPZ Tessera  airplanes stacked on runway 04R-22L, scenery LIPZ XP11-tdg and x-life 2.2 R3.
Is there any solution?
iztok
145 (edited by ivota 2018-05-07 12:39:05)
Xplane crash when I was click to create route (LDSP-EDDP / EDDF)
146 (edited by ilankrt 2018-05-09 16:27:44)
It happened 2 times: ATC STAR advice is false. Instead to offer the correct course - let say descending from south to north - it advices to descent on STAR route from north to south. This opposite direction advice for STAR happened on different flight routes.
Using AIRAC 1805...
Has anyone experienced same problem?
seppl wrote:
Hi JARDesign,
Hi JAR Devs,
Best wishes
Seppl
Hi Seppl,
Hope for a fix.
Best wishes
Annette
My update on this:
I moved X-Plane (with X-Life) onto a new SSD-Disk. But I still had the stutters :-(
I updated X-Plane to 11.20r4 and the stutters are ... GONE!!
Thanks again for this neat plugin!
Seppl
148
I encountered a crash with x-life 2.2r3 on xp11 ver. 11.20 when flying in cruize between YSSY & NZAA
hi. Unknown crash x-life 2.2 r3 x-plane 11.20.
150
Just an observation, or maybe I am wrong. I never see traffic in my RXP GTN 750. If I turn on XP11.11 native AI silly traffic I can see traffic in the GTN 750. Do I need to change something in the configuration, somewhere?
Another subject, while flying helicopters I am getting silly guidance from the ATC. For instance, the ATC wants me to line up to hold short, continue to the runway, etc. I never had this in real life. Why doesn't the ATC give me slot, heading, climb/descend rate and height information prior to take off or on approach?
