176
I would like to remind on what HomerSimpson wrote some times ago:
"Hello all together,
well the A330 is released and now every day there are multiple topics poping up in the forum.
So to keep the work for Jar and Slava easy and structured, I would kindly ask all users to use a standardized bug reporting. We used that in the alpha/ beta phase and it was quite well because you clearly could see which bug was fixed, if there is a discussion about bug and so one.
So my suggestion are:
1.Search the forum before you open a new topic. Your bug might be already reported.
If your bug is already reported:
Post your findings to this existing topic.
If your bug wasn't reported before:
2. Open a new topic
3. Choose a Topic subject which describes your bug in the most shortest form and use one of the following to identify your problem in front of your topic subject:
[sys] for bugs concerning the aircraft's systems
[fpln] for bugs concerning flight plan
[vis] for bugs concerning the outside/ inside look of the 3D objects
[other] if you can't put your bug into one of these categories
4. Describe your bug precisely as possible in the write message field.
5. Attach X-Plane Log.txt and A330 bb_log.txt.
6. If possibile add sources from FCOM, POH, AMM proving JarDesign's A330 is wrong.
And last the most important point for a fast fixing of bugs is that you please post only one bug into one topic
To my mind if we all spent the time to do our bug reporting like that way, JarDesign could easily work through the reported bugs
Best Regards
Lukas"
177
A330 v3r4 no any sounds??? I tried already this http://www.jardesign.org/ticket/kb/faq.php?id=72, but still not working
178
I just did a flight in R4.....wow....MUCH better....handles really well, no issues with turns towards waypoints along the route or wobbling to capture cruise altitude. Great Work!
179
i have the same issue.
180
Test flight EBBR - EGCC A330v.r4 + XL latest version. As with v.r3 perfect flight. FPS as I saw depends mostly on the kind of airport sceneries. On route I get 34 - 40 fps. Simmer who uses MESH 4 do not be surprised if their FPS drops noticeably. Another factor are the weather plugins. Using SkyMaxx and RWC costs some times some FPS on strong cloudy days. Setting rendering high can also become a disturbing factor.
X-Life works also perfectly with a lot of aircraft traffic on ground and in the sky. I noticed that now aircraft on taxiways are not colliding (or passing through my airliner) any more (have to Check it further on).
At this development stage I wish 2 things to be changed: 1 Disappearing of the "grey background shadows"  from PFD +ND.... and 2. more accurate weather radar that  drawsnot only storm clouds but also other cloud formations and  in addition also a strong crosswind warning before landing..
181
Currently doing a flight with v3.0r4 and all is fine. It's a joy to set-up and fly this add-on.
182
@JAR
Evgeny  , on V3.0R4 ,
I have identified that CEF plugin stops the sound win.xpl and others not to load .
Yes I did check with all my plugins , and the plugins_disable.txt is in the folder
WITH CEF Plugin
D:\X-Plane 11/Aircraft/JAR Design/JD330XP11/plugins/fmgs/win.xpl : Error Code = 1114 : A dynamic link library (DLL) initialization routine failed.
[SASL] Starting...
X-Plane scriptable avionics library plugin snapshot 2.5.1 20171214 Commercial Edition
Loaded: D:\X-Plane 11/Aircraft/JAR Design/JD330XP11/plugins/sasl/64/win.xpl (1-sim.sasl).
D:\X-Plane 11/Aircraft/JAR Design/JD330XP11/plugins/sound1d/win.xpl : Error Code = 1114 : A dynamic link library (DLL) initialization routine failed.
D:\X-Plane 11/Aircraft/JAR Design/JD330XP11/plugins/sound2d/win.xpl : Error Code = 1114 : A dynamic link library (DLL) initialization routine failed.
D:\X-Plane 11/Aircraft/JAR Design/JD330XP11/plugins/sound3d/win.xpl : Error Code = 1114 : A dynamic link library (DLL) initialization routine failed.
With out
[SASL] Starting...
JARDesign 1D Sound Engine v251017
Loaded: D:\X-Plane 11/Aircraft/JAR Design/JD330XP11/plugins/sound1d/win.xpl (jardesign.sound1d).
JARDesign 2D Sound Engine v251017
Loaded: D:\X-Plane 11/Aircraft/JAR Design/JD330XP11/plugins/sound2d/win.xpl (jardesign.sound2d).
Lawrence
183 (edited by asandor 2018-04-07 23:30:50)
Having an issue with the PFD and backup display, as you can see by the photo, can't really see the display much. I have the brightness turned all the way up on the PFD
https://www.dropbox.com/s/juzgnjv4c68t7 … 4.png?dl=0
I figured out what it was, on my saitek panel, the panel lights switch need to be on. Please ignore this message.
Sorry.
184
anyone else not getting any navdata?  I copied it in and nothing...
185
zasavage wrote:
@JAR
Lawrence
Thank you for that! you've just solved my sound issues! I can confirm sounds are all on and properly working, with that CEF plugin out of the plugins folder. I've saved it aside XP and now the A330 loads perfectly!
BTW, do you or anyone know what it does? "Disabling" it, XP loads perfectly, with no errors or warnings...
186 (edited by mar197878 2018-04-08 10:55:03)
Good days to all, thank you for this work of A330.
I like much, I am new here in the forum it will leave my file log.txt for if someone can help me.
1) I have JD330V30R4
2) I do not find the way of seeing the radar meterologico, it is not activated, I use X Enviro.
3) Not as doing in order that the A330 to initial descend t/d, decrease up to the LOC of an automatic way to SUMU rwy24 Kevis. HOW I DO?
4) I use Simbrif SBPA-SUMU  manual flight:MIKO1A PTS UA305 LDS LDS1C/airac1804.-
5)Engines are two high sound,in to de cockpit, i try down,but can not have result.
PLEASE HELP:
Thank you very much for his help, comments, and advices
187 (edited by Luke173 2018-04-08 11:59:06)
I'm about to finish a nice flight with R4. The plane has become really nice, thank you JAR.
I still hve a few points to mention:
- QNH and VS seem to reset themselves in flight. At the approach I dialed in the local QNH, just to find later the value 1013. The same happend with VS. I was in a descend with 1800fpm, to find the plane levelling off too early. VS set itself to 0000.
- OVFL button: As already mentioned, I cannot get it to work. Could one of you please test this for me? (set a random fix in your flightplan to "OverFly".
- Load Sheet: nice idea, but it takes too many clickt to load and unload. a slider would be awesome, with the possibility to manually set the value (like 25 pax).
- MCDU settings: I would really appreciate the fact the setting are stored, so I don't have to tune this every single flight.
- scroll wheel support. just a dream.. wink (EDIT: for the knobs, like overhead, we already have it for some actions)
Thanks again!
Luke
188 (edited by Darko24 2018-04-09 11:05:28)
Flying with this plane V3. r4 is really nice and everything works fine for me.
I just have one problem when landing at the airport and then want from here to continue the flight to a new destination. In this case I can not set automatic brakes - does not work, and in MCDU settings not all phases settings are shown.
Have anyone else noticed this problem?
I like to fly short flights from country to country in Europe and at the larger airports, so annoys me that then every time when I successfuly landing, before continue flying, I have to re-download the X-plane.
189
Worked for me on WPT MTR (Metro) near EDDF (Part of TOBAK9D). I only tried assigning it later:
  • Open F-PLN page in MCDU
  • Press OVFY Button, so upward facing triangle is in scratchpad
  • Simply click left LSK (Line Select Key) for the WPT you want to overfly (in this case MTR)
  • F-PLN becomes temporary and behind the WPT, there should be a triangle now
  • That's it (checked in PLAN-Mode of ND)
NOTE: this was r3, not r4!
190
Just to say that r4 is a vast improvement. Much better turns (no banking left and right). Well done JAR.
My only problem is that the ground spoilers still don't always deploy.
191
They will always deploy. First of all high nose pitch attitude is required, then you should begin at 40ft with the flare and at 20ft pull throttle to idle(retard). At touchdown you will hear an announcement and the spoilers will deploy automatically. Activate the reversers only after touchdown...
https://youtu.be/9Vv14dEeb4I
192
Does any one have a clist file for Xchecklist plugin, with auto-check procedures? I have one but it doesn't auto-check.
Thank you for the advice ilankrt. I was expecting a video from you smile Maybe I have been performing an incorrect procedure?
At around 40/50 feet I flare. When I hear "Retard" I activate reverse thrust. In the majority of my landings the ground spoilers do not deploy (they are armed).
So, when I hear "Retard" I should pull thrust lever to idle and only engage reverse thrust with all wheels on runway? Do I need to switch off auto throttle at any point?
Thank you for the help.
194
Yes the  retard call only reminds you that your throttles arent at the Ilde position. Activate thrust reverserers only if at least the MLG is fully on the ground. Then also the GND spoilers should come on.
195 (edited by ilankrt 2018-04-10 14:43:02)
and
you don't meed to deactivate the AT....
196
@ ilankrt and Homer.Simpson
Thank you both for your help. Tried it earlier but unfortunately had a CTD during flight. Will try again.
197 (edited by ilankrt 2018-04-11 18:10:05)
On last flight LEBLLFML that was a perfect flight,  during landing I mistakenly pushed throttle too far activating the thrust reversers (T/R) mode too early at 5ft above ground. This caused the ground spoilers not to deploy automatically.
Does someone know if in the real A330 T/R are locked until main gear touch down respectively at what point the T/R can be handled manually ?
198
Yes thrust reversers are locked:
„The Transcowl Lock System (TLS) inhibits any inadvertent in flight reverser
operation. The TLS uses the radio altimeter and the FCPC (Flight Control
Primary Computer) information.
Two aircraft powered transcowl locks, one per sleeve, provide an independent
locking feature through electric motor driven hooks.“
So thrust reverser shouldnt be activating until Sensors say Aircraft on ground
199 (edited by ilankrt 2018-04-11 20:34:37)
Great! thanks for answer (I wasn't sure because I red about it a long time ago..)
Now we should ask JAR to add a subsystem/algorithm that prevent T/R to deploy while aircraft still in the air...
200
Great job on V3r4 update with improved FMGS. NAT tracks now working, thank you.  I have noticed with this release TCAS is not working for online traffic on VATSIM any suggestions?  Changing number of AI aircraft makes no difference.
