Scania_V8_Rat wrote:
EDDF - EDDS (EDDF/07C ANEK4F ANEKI Y163 NEKLO Y171 INKAM N850 KRH T128 BADSO BADS2A EDDS/07). Some weird click sound (does CPT switch on LDG Lights automatically -F100 ?). Weird "looping" in the STAR, didn't see it at initial PLN-check and went into a hold.
Level-restrictions are working very good!
I'll try same flight with no problem. As I see on charts I manually put SPD limit on point 417 to 220 knots  into plan.
Every time when I see shown the way, as it is shown on your attached pictures, is probably the targeted speed on this section is too large so the bend is not concluded.
Charts
http://jardesign.org/forum/img/m/4390/t … jojil3.jpg
No that’s not a bug it’s normal
103 (edited by Scania_V8_Rat 2018-03-15 15:13:25)
Charts
Thank you for your reply, but VATSIM charts don't show this (there is no complete BADS2A published AFAIK). Sorry, that some won't afford Navigraph Charts, but Navdata from Navigraph. By the way the screenshot you linked is not readable at all (too low res), but thank you for thinking of an attachment of the situation.
EDIT: I was flying at green dot speed, because I know the "sharp" turns....
Try: RID8C RID Y163 NEKLO Y171 INKAM N850 KRH KRH1E
Thank you @ilankrt, I will try this tomorrow. Cool, because this STAR will take me over my house (I live just a few hundred meters from VOR/DME KRH)
@Darko24: sorry, according to the picture I was flying way over Green Dot speed and with a strong tailwind component. My mistake.
I don't have an answer to your question but, did you load your flight plan by hand, or did you upload your flight plan into the system?  I no longer can get the MCDU to pull the flight plans from the flight plan folder.
107 (edited by ilankrt 2018-03-16 15:15:01)
Scania@ I made yesterday this flight as a test and everything works well. You can see my landing on a short video I made. Maybe you can recognise  your home :-)
https://youtu.be/AJpCkR5up6s
108 (edited by Scania_V8_Rat 2018-03-16 19:50:00)
This time on your route without any problems. Was a nice flight (HOLD added over my lovely KRH to see my village), which I recorded - at least I thought so. Somehow OBS was only able to capture the sound but not the nice visuals.
One thing which needs to be improved, too, is the "Flaps One"-Callout on ground, because on ground it's "FLAPS ONE PLUS F". F1 in  flight only means slats but no flaps, but for a takeoff....
EDIT: @ilankrt My landing was a longer landing, too smile
109 (edited by argoss1 2018-03-18 03:37:27)
http://jardesign.org/forum/img/m/5237/t/p1c8ritd1nepggh8110b1sbi2214.jpgRTE SEGMENT ERRORS... I can no longer upload flight plans from SIMBRIEF/ FLIGHT PLANNER/ or DELTVA for long haul flights into the MCDU... short flight plans (flown 3 so far) had no problems. Not sure where the issue is... any ideas? This forum is HORRIBLE for trying to find other responses similar to what you are looking for. I'm sure someone else has already addressed this.
110
Just for information, I just tried to load A330v3r2 into the just released XP 11.20b1. It immediately crashed XP. It may be a Mac problem, so perhaps Mac users could give it a try. I'm not using VR, just single screen as a try out. The release notes did state that the release does include updates for non VR.
It works perfectly in XP 11.11, but hopefully it will be sorted as I'm guessing that when XP 11.20 goes final we can use it in single screen. Not sure how far down the road good VR is for Mac users if we want to use it.
JAR is aware of the issue.
111
2 test flights under XP 11.20b1 no problem.....  (iMac27)
Hi ilankrt, my setup is the same as yours and yet mine crashes every time, it doesn't even get as far as starting. I select A330 plus starting airport, start flight and it immediately crashes.  It may be an add-on, but I'm only running X-Life 2.2r1,  FM Car plus add-on airports. So, what I can't work out is everything is the same as XP 11.11 and it runs fine with no crash on start up.
113
The minimum decision altitude (MDA) in APPR-page is broken. When i enter an altitude it will be overwritten bei the standard DH of 200. Is there any chance you could fix that?
114
Have you restart your iMac? If I have troubles I use also to restart system...
115
Hi ilankrt, looking at your setup above the only difference is you're on High Sierra and I'm on El Capitan, and I'm using alpilot HD 4 scenery. You have a couple of add ons I'm not running .
What is strange I made an exact copy on my desktop of XP 11.11, I then updated that to XP 11.20b1.
The A330 works with no problems in XP 11.11, but crashes XP 11.20b1 every time.
I will try your restart idea and play around with it to see if I can find an answer. ( Perhaps I will send a bug report to Laminar.)
116
Hello colinah, I encourage  you updating MacOS to the last version. I have some more "heavy software in use and all of them including X-Plane are working well. There is also a better performance in use of the graphic card as I see an improvement of X-Plane FPS...  Maybe you should also ask JAR (Skype) what MacOS version he is using on his iMac... Indeed your case is looking very strange but I have no further idea at the moment.
BTW I deinstalled pilot HD4 since it burden strongly the sceneries building and the graphic card usage. XP sceneries are today at very high quality and resolution so instead I installed simHeaven x-Europe 1-3 that uses XP original resources but enhance landscapes and cities sceneries. The results is fabulous!  He will also offer us other parts of the world.
117
Hello ilankrt, I will give the upgrade to the latest MacOS some serious thought.  The problem is I do a lot of photography stuff and if I upgrade I will loose a lot of the apps I use for that, and that will cost me a bit of money.
I did send a bug report to Laminar and they could not reproduce my problem either, so as you say my problem is very strange.
I will play around with it for a bit and see if I can come up with an answer, if I do I will let you know.
Thanks for the replies.
118 (edited by LUCASMILAGRE 2018-03-20 12:48:04)
HELP ME PLEASE:
I do not know what else to do. I downloaded the latest version again and when it's in Cold and Dark, I get 60fps. When I put the payload and fuel, it drops to 30fps. And when I put the Stars and Sids in the FMC, it drops to 15fps. I already uninstalled and reinstalled and the problem continued. Someone help me please!
My PC: i7 4790k - GTX 1080 - 24GB Ram
119 (edited by ilankrt 2018-03-20 14:35:16)
LUCASMILAGRE wrote:
HELP ME PLEASE:
It is nearly impossible to help because there are many factors that can influence your simulation. (scenery, add-ons plugins, etc.)
On your image you sent we see for example that your aircraft is placed on runway, while on ND the runway is elsewhere  ?!
At best you send us a short video....
BTW framerates change frequently depending also on view as you know (inside, outside, 3D etc.)
120 (edited by LUCASMILAGRE 2018-03-20 14:41:11)
LUCASMILAGRE wrote:
HELP ME PLEASE:
The aircraft is on the runway, but I already did the test at the gate as well. These errors occur before start engines. I'm not using any plugins and the (airport) scenario is XP11 default.
121
LUCASMILAGRE wrote:
LUCASMILAGRE wrote:
HELP ME PLEASE:
Have you tried another airport ?  (try an Aerosoft airport scenery)
122 (edited by LUCASMILAGRE 2018-03-20 16:22:59)
Yes, I tested it at 5 airports. Before the BETA version I did not have this problem. This is only happening after the last update.
Hello ilankrt, I tried removing plugins one by one, removing certain scenery and a few other things, and it still crashes. So, I've now run out of ideas.
If the only answer is upgrading to the latest MacOS which I will have to think about. Of course that may not be the answer and I've lost all my photography apps.
It seems that I can only run the A330v3r2 in XP 11,11, when XP 11.20 becomes final I will either have to stick with 11.11 or loose the A330.
124
Bad and sad news !
Last chance: In such a case I would contact JAR directly on Skype. In the past when I had a serious problem and no solution, we both had made a Test Flight on my iMac sharing my screen to find out what is the cause.... JAR is a very helpful person..
125
Today I made another test flight EPWA-UMMS. X-Plane 11.20b1, A330 v3r3, X-Life, diverse plugins, from cold and dark. Everything works perfectly. FPS at 38-40.  Descent with tailwind (19kt) I didn't need to deploy speedbrakes. Also during descent I  changed landing RWY and STAR I programmed before after newer ATC advice. With the last A330 version I can now proceed flare without that aircraft begins to climb as in earlier versions.
Trying to land I have the experience that some older airport sceneries can cause that the aircraft does not calculate correctly the ILS entry and thus aircraft is flying too high.... Old Airport sceneries causes a suddenly X-Plane crash... So now I have made a "Black scenery" list of those airports. (I am flying exclusively between airports that are on X-Life list)
