Re: X-Life ver 2.2 R1, R2, R3 for X-Plane 10/11
Unfortunately, to me exactly the opposite.
i9-7900x, 64gbRAM, SSD dedicated to Xp11, 1080ti, certical sync locked at 30FPS, as I start X-life FPS drop to 10 or less... if I switch off on the admin panel back again to 30 rock solid. Did a lot of tests, can't understand, let me know how i could give more info... desperately looking for a good ATC (supporting SID/STARS) as it is the only lack in X-Plane... thank you very much.
Ciao and thank you
Hi guys
Since new win.xpl update I am getting micro stutters every 10 to 15 seconds. The CPU time will go from 0.0150 in average to 0.350 or similar. Data Graph Window in x-plane shows such stutters only after loading the traffic.
I tried everything so far, but nothing could help. The problem is related to CPU, not GPU.
Finally, I had to overwrite win.xpl with the old version.
I was so happy to see the major improvement with this latest update (more planes in the sky), but micro stutters every few seconds are just a show stopper.
Does anybody else have the same problem, possible solution?
Cheers
i7-8700K (4.9 GHZ OC), Asus Strix 1080 G, 16 GB RAM, SSD 250GB
Dear JarDesign I Team, really like your x-life! Besides the wishes of many users to have supported every airport, I have another suggestion for future plans: I was on final approach to EDDM Munich and clicked on "request vectoring". What he does was send me back to IAF which was AKAN and back to FL230. There was no way to undo my mistake. I would like to have a possibility to redo it or to "interact" with the approach/tower controller so that I can say "request clearance to land" or something like that (sorry, I am not a pro). This would also be great to simulate an emergency landing on an airport I have not filed before. Just tune in to tower or approach an click "request landing clearance" or "report emergency" an get vectors without having filed a flight plan. Thanks
miro.t wrote:
Hi guys
Cheers
I will think about microfreezes. We have 2 ways of CPU/Memory usage:
- make global matrice for airways once and use big part of memory for it (ver 2.1)
- make local small matrices before every route building (really small memory usage and need very little time to prepare new route), but this preparation may eat CPU time by time (ver 2.2)
Sure, need find balance for coding approach or may be make just a switch for user choice.
30
Good Morning! CTD when call FMcar 2.6r1  from X-Life 2.2r1 ATC panel. No FPS differencies between x-life 2.1 and 2.2 versions.
31 (edited by cptsquared 2018-03-16 05:54:59)
Hi all I'm having a CTD and my Log file indicates an XLife crash. I'm on the latest update, Pro version, with BlueBell libraries installed and AIRAC 1803 installed.
Here's the latest from my Log.txt:
XL: 4326 : X-Life plugin ver.2.2 r1 070318 detect crash.
XL: 4326 : Memory dump saved to x-life.dmp file
XL: 4326 : Please send this log.txt file and x-life.dmp file (from X-Plane folder) to support@jardesign.org !
x-life.dmp file attached.
CTD happens when flying KSFO -> PHNL using FF757. Just reinstalled everything fresh and still getting CTD. Any help = thanks!
Never request the FM Car via ATC. Its resulting in CTDs for me too. Request the FM Car via the FM Car Plugin.
I hope they fix it in future.
Hello !
Just bought X-Life and installed 2.2.
The ATC module gives me some headache. After listening to ATIS, then requesting clearance from delivery, I get the message from delivery 'Wrong QNH, set to <value>"
Well, the correct QNH is set to that value, for both FMGS and Standby in the FF 320 Ultimate.
Why would any delivery come up with the QNH in my plane anyway ?
Anyway, I'm stuck ...
Mike
xlife 2.2 is working good on my imac5k.
it would be very welcome that a created flightplan can be loaded by the Zibo B737 fmc.
Hi everybody,
I'm rather new in X Plane 11 and tried X-Life (latest version). So far it works, but I have a significant FPS drop when starting traffic in X-Life.
Is this a known issue and are there any workaroiunds for this?
I like the product very much and it does exactly what I was looking for.
Here are my system specs:
ASUS P8Z77-V LX Z77 Mainboard
Intel i5-3570K - OC@4.2 (4 cores)
GeForce GTX 1080
Corsair 2x8GB XMS DDR3-1600
DVD SATA Reader/Writer
Western Digital Caviar Black 7200 64MB 1TB
Corsair H80 Wasserkühler mit 2 Noiseblocker Fans
I have a triple monitor setup and FPS are "normally" 30-40. After starting X-Life traffic I have around 15....
Any help is greatly appreciated!
Markus
36
carrerars wrote:
Hi everybody,
GeForce GTX 1080
Markus
that Xlife decrease frames is normal. There are some tasks that need calculate to bring up the traffic. But around 15 is a "heavy". Try the 2.1. This load some more of your RAM, but in my humble opinion this version runs smoother and do not raise up the CPU times and cause some micro freezes (air traffic is not so high frequented in this version sad ).
Anyway, I suggest you to use a SSD for your operating system and in the best case a second for your XP. As your HDD could be a massive "bottle neck" for loading next ressources into the RAM. In case you only use one ssd it is better to start XP from there as well.
Another try could be decrease your auto generated objects in XP graphic settings. That could decrease the amount of CPU usage and the full XP environment could "breath" a lot more.
Hope this helps a little bit.
Best wishes
37
ackermann_michael wrote:
Hello !
Mike
Put transponder on
Anyone get a CTD randomly when using FSEconomy? I mean, aside from the other annoying CTDs this one seems consistent.
Nice option for change FL, and have many aircraft in the sky as transit. It is nice to see all this AI planes on map or SimBrief map it make the feeling that you're not alone in the sky gmail login
40
deleted
41
r2.2 has crashed 3 times - I'm on a mac 10.12.6 and 11.11r2
log file attached
Sorry! My bad! Crash happen during build .xpl
Please update to R2 using attached files:
R2:
+ some CTD fixed
+ framerate optimisation
Only time to check it till take off, all ok, nice fps. R2.2 xp11.20b2
44
Great update, more medium and heavy aircrafts in the sky ... a little more FPS with last xplane beta update
45
With the latest update it does not transfer all the data on the traffic the airport at which I am coming, not even traffic at the airport.
http://jardesign.org/forum/img/m/4390/t/p1c96eql948jeoju6jh136f687.jpg
http://jardesign.org/forum/img/m/4390/t/p1c96eosduno0gvb2jtkg9sgl3.jpg
http://jardesign.org/forum/img/m/4390/t/p1c96epvu7u3e80a13ki1n171jar5.jpg
for me similiar situation. Departure airport traffic works on ground, departing a.s.o.. Arriving airport is empty, no traffic and aircrafts on the ground. ATC still works and route to all procedures. Tested in several situations (sceneries and aircrafts), always the same. Traffic in the air is working. Can recognize micro freezes every time when XLife AI aircraft begin roll to takeoff (same time when you can hear turbine acceleration sound), touchdown runway at landing and begin pushback at gate/stand. Using Bluebell Aircraft. Attached log (maybe it helps). Will roll back to 2.1.
Many thanks for your handon and keep up the nice dev..
Best wihes
Running R2. CTD during AI autogen.
48 (edited by ilankrt 2018-03-22 14:41:39)
Which aircraft model are you using? If A330, have you installed "plugins_disable.txt file״ ?
49
As seen in figure I use JARA330, plugins_disable.txt is in A330 folder as required. The previous version works without problem, I returned it.
50
I think I found a solution for my problem. I download X- life from permanent link to latest version and take win.xpl from there and put in my x_life. Now everything was OK.
