I am enjoying this update, but I hear no call outs - retard, etc. I'm sure something is not turned on - on my end. What am I missing?
JARDesign Group Board → Downloads, Updates. → XP11 JD330 v.3 r1,r2,r3,r4,r5
Had issues activating it.....after entering my serial and restarting XPLANE, the pilots disappeared but the windscreen still was pink and had those small squares as it does when the aircraft is not activated.
It all went away if I disable Rain Effects in the FMGS...if I enable the rain effects, the windscreen goes back to pink with those small see through squares.
One of the best things to check if the A330 is not loading correctly is to search the Log.txt, see if you find any "Error Code = 1114". In that case it's failure because X-Plane can only load a certain amount of plugins, and usually that involves too many GroundTraffic calls. Try and disable some Ground Traffic airports that you wont use fort that flight.
v3r2 have a solution - v2 will look at plugins list what already loaded and make disable traffic plugins in auto mode to avoid conflict. Sure this is swithable option.
Hello 2 bugs
1) the engines start with the PACK on
2) the engines start and the plane take off with the pumps l1l2r1r2 OFF
Best regards Philippe
Multi monitor supported???
Can't get activation window. Just a dark screen in centre of displays.. Tried everything but no joy.
Having to stick with V2 for now...
Thanks for the update. Issue this morning. Total freeze of XP11 with an error message the application asked to terminate runtime in an unusual way. Log attached. It happened when I was using Betterpushback to start pushback.
Hello 2 bugs
2) the engines start and the plane take off with the pumps l1l2r1r2 OFFBest regards Philippe
1. Normal. As long as Engine has enough air bleed pressure. Plus on airbus aircraft, the PACK valve automatically closes during engine startup, as soon as you put the engine mode selector to IGN/START.
2. Gravity Feed
2. Gravity Feed
True. Try a steep climb/descent with pumps off and nasty things will happen.
Hello! We prepare v.3 release 2 with some improvements:
+ distance calculation fixed
+ fuel calculation fixed
+ 3th part plugins conflict ("no sound" issue fixed)
+ CTD after speed enter at CRZ PERF page fixed
+ some kinds of CTD fixed
If you already use v.3r1 you may just update 3 files only:
- replace win.xpl and mac.xpl in .../JD330XP11/plugins/fmgs/ folder
- place plugins_disable.txt file to .../JD330XP11/ folder if you meet "no sound" issue
Another way - redownload and reinstall aircaft from
http://jardesign.org/a330/download/install/JD330_v3.zip
Thanks for your report & logs & dumps!!!
Just tried to load 330v3r2 into XP 11.20vr6 and it immediately crashed XP. Still OK in XP 11.11.
Log.txt sent to JAR.
Need use 11.01-11.11
Hi and thank you for this great airplane.
Is there a way to save the settings made via the fmgs/CommandShowMcdu?
For example, if I want to save the 'no show fps' option not to have to adjust it at each loading.
Thank's for help
jcmic
First flight with V3r2:
- sound problem remains, specificaly, I can't run it properly with xEnviro enabled, mainly engine sounds are muted.
- No CTDs at all
- Manage to program the MCDU, however I still can't figure out to set it properly to manage speed and altitude, need to read more about that.
- Despite a few setbacks with the A/P, it worked properly most of the time and it autolanded the bus on a strong crosswinds runway without any problems.
Such an amazing job was done with this Airbus, congrats to Mr. Romanov and his team
Hey jar team.The Distance calculation bug seems to be not solved with r2.Wanted to fly from MDPC to EDDL.Distance is about 4100 Nm and my mcdu told me that it is about 3200 Nm.Hope you can help thx.
Your flight route was ?
KATO2A KATOK THANK M597 KEEKA M597 FIVZE 30N055W 35N050W 39N045W 42N040W 45N035W 47N030W 49N020W BEDRA NERTU GAPLI UM197 REDFA UL620 PAM UP62 TEBRO TEBR3G this was my flightroute MDPC to EDDL
Greets
For example, if I want to save the 'no show fps' option not to have to adjust it at each loading.Thank's for help
jcmic
+1
jcmic
+2 Could be done by a settings.txt which is read at startup
ANN Test (all lights on) maybe? Would be cool and really unnecessary
Greets
Checked you'r right.
This is a case for JAR to look after..
R2: the Fuel "+" does not seem to work for me, OS X 10.11.6, XP 11.11r2
"-" works, until: not enough fuel SIRelse: many thanks for all the hard work! this plane is amazing!
EDIT: It works, after posting this.. so waiting seems to solve it
May be You just trying to add fuel after start engines or APU? If so - This is not good idea.
i just tried to do a flight with the A330 V3 R2, but i got some bad oscillations when on autopilot on nav mode. The plane flew alongside the flight path and right before it reached the waypoint it started banking hard to the left in an effort to intercept the waypoint, and it did, only that now it has to bank hard to the right to try to intercept the next waypoint. it did this on every waypoint.
Also i could not load this Flightplan i provided, but i had no problem manually inserting each waypoint to get the exact flightplan.
info:
Vers: A330 V3 R2
Flight: LEPA SID MEROS UN853 LUMAS UZ191 NEVIX UZ192 ROTIS UN870 MAXIR UN853 VANAS DCT ESOKO DCT GODRA DCT DITON T163 ZUE T125 ROMIR UN851 TEDGO DCT TIKNI UN746 KENIG UZ400 ARGAD UZ330 OKAGA DCT VIBAR DCT NILUG STAR ESSA
Weather: Default X-plane real world weather, 110kt crosswind from 289* at FL400.
Plugins: BetterPushback, 124th ATC v2.
Thanks in advance.
Hi . Ive tried a new route ESSA-KMIA but the Distance calcuation bug is still there.Will send log.txt and dump.txt to jar and here in the forum .Thanks for your hard work.
That was my route.Maybe someone want to try it. KOGA3C KOGAV L77 BOR Z418 ROVPA P996 IPTON DCT 62N010W
62N020W 61N030W 59N040W 56N050W DCT LOMSI N516A TOPPS DCT HTO VS1
ORF J174 DIW AR23 PANAL DCT ADOOR DCT BLUFI.Also got this message after i have entered the route:MessageRed: Missed Leg: I30,HM,BRBRA,25.967286,-80.453019,2, ,0.0,0.0,155.0,04.3,0,0,0,0,0,0,0,0,0
Greets
Hello
I have some trouble to fly to EGLL and try to put on plan the STAR with name BIG.. This happened to me yesterday on the attempt fly from LFPG to EGLL, when I every time I entered in the MCDU arrival with name BIG.. seen a CTD. Log and dmp file I yesterday sent to the JAR.
Today I try again. In plan I for the arrival to EGLL use STAR WEAL4B and everything was fine. The flight ran great, but on TOD when I, at the request of the ATC, try to change the STAR on the BIG4B .. crash.
