301
ComRPM wrote:
I´m not totally sure but I think the TCAS don´t work.
TCAS works fine. At least with X-Life and P2A.
302
Hi, I just downloades version 3 beta. Found following points which confusing me:
- MCDU: I could enter ALT constraints but they does not have effect on flight plan (flown from KMIA to MUHA and an HA407 is a restriction of 4000 ft or above and I entered 4000 feet and there was no change to the origin plan of about 7.100 ft. So the complete decent profile was too high. Even at JANSE where is a restriction of 2.000 or above there is no change)
- MCDU: Aircraft does not follow speed constraints. I have to tune in the correct speed manually in SPEED on Glareshield
Least some "optical" things:
- green frame around left window
- sunshield on left window is not retractable and has no effect on lightning in cockpit
Using XP 11,20 VR3 on iMAC
303
Hi. TCAS with WT3 seems doesn't work. I've got P2A, P2ATC confirm traffic, but ND display not showing.
Same optical things from dahuebi.
Cheers.
XP 11.11 on Windows.
304 (edited by Beerbog 2018-02-26 12:45:02)
A/P went off course majorly, even disconnected once in my last 2 flights. Log text attached.
305
Test with WT3 3.1.9 only.
Works fine, aircraft's on ND.
https://youtu.be/XnTV72sN_QM
306
Seems more likely that the problem is with WT3 then the A330.
307
A few hours later and now I get:
G64:  57.064:  Aircraft File: (Aircraft/JD330/a330.acf)
G64:  57.068:       MD5 Hash: (e5bdb33795507a090844da2555e05c5d)
G64:  57.068:    Description: (Airbus A330-200 by JARDesign)
G64:  57.068:         Author: (JARDESIGN (C))
G64:  57.068: Plugin Mode: Community Edition
G64:  57.068: GizmoAircraft::cache_getScriptsFolder()
G64:  57.070: Boot Count: 2
Fetching plugins for D:\X-Plane 11/Aircraft/JD330/plugins
CUSTOM DATAREF (float array): jd/light/01
CUSTOM DATAREF (float array): jd/light/02
CUSTOM DATAREF (float array): jd/light/03
CUSTOM DATAREF (float array): jd/light/04
CUSTOM DATAREF (float array): jd/light/05
CUSTOM DATAREF (float array): jd/light/06
CUSTOM DATAREF (float array): jd/light/07
CUSTOM DATAREF (float array): jd/light/08
CUSTOM DATAREF (float array): jd/light/09
CUSTOM DATAREF (float array): jd/light/10
CUSTOM DATAREF (float array): jd/light/11
CUSTOM DATAREF (float array): jd/light/12
CUSTOM DATAREF (float array): jd/light/13
CUSTOM DATAREF (float array): jd/light/14
CUSTOM DATAREF (float array): jd/light/15
CUSTOM DATAREF (float array): jd/light/16
CUSTOM DATAREF (float array): jd/light/17
CUSTOM DATAREF (float array): jd/light/18
CUSTOM DATAREF (float array): jd/light/19
CUSTOM DATAREF (float array): jd/light/20
CUSTOM DATAREF (int): jd/diagnost/a330
Loaded: D:\X-Plane 11/Aircraft/JD330/plugins/330/win.xpl (jardesign.a330).
JARDesign 3D Sound Engine v230516
Loaded: D:\X-Plane 11/Aircraft/JD330/plugins/BSS/win.xpl (jardesign.sound3d.custom).
Loaded: D:\X-Plane 11/Aircraft/JD330/plugins/diagnost/win.xpl (jardesign.a330diagnostic).
D:\X-Plane 11/Aircraft/JD330/plugins/fmgs/win.xpl : Error Code = 1114 : A dynamic link library (DLL) initialization routine failed.
D:\X-Plane 11/Aircraft/JD330/plugins/sasl/64/win.xpl : Error Code = 1114 : A dynamic link library (DLL) initialization routine failed.
D:\X-Plane 11/Aircraft/JD330/plugins/sound1d/win.xpl : Error Code = 1114 : A dynamic link library (DLL) initialization routine failed.
D:\X-Plane 11/Aircraft/JD330/plugins/sound2d/win.xpl : Error Code = 1114 : A dynamic link library (DLL) initialization routine failed.
Nothing else is changed...
308
but please answer the questions on the forum regarding the X-life and JD320, at least tell or you have something in the plan.
X-Life next version is on tests now. We improve framerate and decrease needed memory a lot, add CRZ FL change requests during flight. Will publish it soon. After JD330 v.3 release we will continue with JD340. Will think about next steps with aircrafts after 340 release.
309
Sorry for asking something of you again but I would really like to understand why the A330 won't follow the flight plan. It should turn slightly to the left but instead it turns right.
It doesn't follow the flight plan and the auto-pilot control stays on.
2 attempts :
1/ respect of PERF of MCDU
2/ decreasement of the speed : 250 kts instead of 314 kts (MCDU)
Please watch the video here: https://drive.google.com/file/d/1uxgH16 … sp=sharing
"With little help from my friends"… Please.
Peter
FYI :
A330 - V3 - Beta 6
Flight : LSGG - LFPO
Alt : FL 250
Flight plan : suggested by MCDU.
Metar : No problem
No plugins except SkymaxPro but disabled (CAVOK)
310
I just performed a flight from LEMD to GCXO
The whole flight was pretty good. No bugs encountered. I program the route manually from a flight plan generated with PFPX.
Plugins better push back skymaxx and real wx connector , and world traffic radar. Good frame rates during whole flight even with AI traffic at the airports.
Just notice the following The fuel burned until TOC was equal to the  flight plan. Then on cruise with Mach 0.83 as planned the fuel burned was far away compare to the flight plan. (save 2000kgs during a 2hour cruise). I gotta check with another template but it seems that is not burning what  it should have done in cruise.
I would be nice to have the options radial in and radial out to intercept courses.
And as was mentioned in another post would be nice too to have the ecam systems in a logic automatic sequence.
Congratulations on such a nice product
looking forward for the big bus 340
311
LEPA-EDDK with Beta 6 at FL340.  110-115 knot crosswind at cruise from 285 degrees and aircraft had a difficult time staying on course.  Aircraft continued to bank and also overshot the flight path on a few occasions while trying to stay on course.  Aircraft also swung side to side but it appeared less noticeable than earlier betas.  Approach was smooth with a nice line up for the ILS to RWY 14L.
312
Thank you JAR for the information. This is all what we want to know, because your users we can't wait innovations and improvements. We wish you successful implementation of your plans.
Greetings Darko
313
Although I'm not an experienced pilot, I have tried a few flights with the 330 v3 b6.
My general observations are that on many occasions the plane rolls (+/- 20 degrees) even when on a "straight" flight path.
Ground spoilers have only deployed once. Most landings they didn't deploy.
I miss the North Ref display too.
I'm sure it will all be sorted eventually.
satch10
314 (edited by S3rg1o 2018-03-02 00:16:44)
Anyone can help ?
I don't have any sounds, except, external wind and air flow. I don't have any sound 3D plugin...
I'm sending my log
315
S3rg1o wrote:
Anyone can help ?
I'm sending my log
/sound1d/win.xpl : Error Code = 1114 : Falha numa rotina de inicializaзгo de DLL (dynamic-link library).
/sound2d/win.xpl : Error Code = 1114 : Falha numa rotina de inicializaзгo de DLL (dynamic-link library).
/sound3d/win.xpl : Error Code = 1114 : Falha numa rotina de inicializaзгo de DLL (dynamic-link library).
You have an errors for any of the sound plugins.
316
Ok, we just jump to release today.
r1 is ready now and may be downloaded from here http://jardesign.org/forum/viewtopic.ph … 791#p19791
We will continue work on FMGS features. Both exist JD330 and future JD340 will get the same FMGS module and we should make it perfect.
So, I want to say THANK YOU again to all pilots who take active part in tests.
