Scania_V8_Rat wrote:One incorrect thing about this bird are weights.
@J.A.R I don't know where the hell you found those weights, but according to this http://www.flugzeuginfo.net/acdata_php/ … 200_en.php it looks far away from real. Please fix those weights!
Could you specify where indicated weight are wrong ?
I really don't like your insolence and big mouth. You red about weight on one source (that is not the right source for the A330-243) and that is good enough for you to ask for correction. You should dig deeper (if you are able) then you should get the correct data.
For example: A 330-243
http://www.hifly.aero/en/a330/cs-tfz.html
https://seefinaviation.files.wordpress. … 30-200.pdf
and so on..... !!
