126
With Beta 3, I have just experienced a CTD during an approach in LFRG, when I clicked on ACTIVATE APP PHASE.
With Beta 3:
On ND, the distance on top right needs to be a decimal (like 2.3 NM). For the moment it's rounded to 2 Nm.
Otherwise, we cannot shoot some approaches as the distance is not accurate enough.
On arrival, no transition nor Initial Approach Fix selection possible (it was working on A330 v2)
I checked on LFBD > VOR23 > ROYAN8L (STAR)
We should have some transitions, such as ETPAR
TA ONLY not displayed anymore on the ND during take-off phase (as it was in v2)
Any possibility to set an ALTN airport in FMC?
Thank you for your hard work!
128
No luck with the newest V3 version. X-Plane 11.11 won't even open with this aircraft. I had to force quit X-Plane. Even if I load another aircraft first and then open the A330 v3, X-Plane won't open with the aircraft.
big_smile
I read v. 3-2 ?!
Can you correct it to v.3-3 please////
But Where?
130
A330 with latest beta:
- Flight EDDM - EDDT (create with EFASS) and FSGW with X-Life Deluxe
- Flightplan import to FMC well done, no problems
- Starting X-Life Deluxe, no problems, works
- request Follow Me Car...CTD ! not working !
- FMC shows no altitudes in the flightplan !
- Take-off..."Message Power-Set"...no "Flex/50" and no sound for "V1, V2, rotate" !
- no "T/C and no "T/D" marker in the display
- no sound "We are close to the T/D sir" !
- very good pop-up displays, works well
- right-klick for knobs working also
- Frames about 20 - 30 FPS (with my settings)...good and no problems
I think this is a great beta-update for the A330 with some little bugs! Great work!
After entering Flight plan do you fill INI pages 1 and 2 ? That way you wil have altitude .
and afterwards PERF page ? Filling speeds (just click on left key in front of them) you shall get announcement at TO .
If you already do that , this means it is a bug as in V3.2 this worked fine .
There is no Trans for EDDS in FMC.
133 (edited by McWillem 2018-02-11 11:44:18)
Oh I have an issue when rainwindows on (MCDU menu on)
All liveries
Framerate: with Texture Q> Maximum Visual or lower  Eff>High or Lower  (no changes at all)
  • Overhead >33->53
  • Outside 28->36
  • default forward <20- >33 with rain window on
  • default forward <20- >33 with rain window off
Attachment icon Schermafbeelding 2018-02-11 om 12.28.34.jpg 461.33 kb, 127 downloads since 2018-02-11
134
Tried it again ... no way this works on my setup. X-Plane is beachballing at "Done with preloading" ... it stays there indefinitely and needs to be force quit ...
135 (edited by 0321Sjoerd 2018-02-11 12:26:26)
Just tried a flight with the beta: I've tried Dubai (OMDB) to Muskat (OOMS) with this route:
OMDB 30R ANVI3F ANVIX L223 TARDI N629 MUSUK MUSU1V 08L (my flightplan told me to fly this route at FL250)
The following things happened that seemed odd:
- Upon programming the arrival in the flight management system I received an error code in red stating something about 08L missing leg;
- After programming the route on the init. page my cruise altitude was reduced to FL210 (maybe because of trip length (218NM) vs weight (take-off weight was 177887 kg)
- When I started the engines and moved the starter switch to the start/ign postion the EPR indicators started spinning wild. When the engine is started this normalized to correct reading.
- After I reached my cruise altitude of FL210 I wanted to check if I could reset my cruise altitude in the Flight Management System to FL250. When I opened the INIT page and wanted to dial in FL250 I had a CTD.
Attached are the log.txt and fmgs.dmp file from my X-Plane11 directory immediately after the CTD. I've filmed the entire flight, so if it helps I can transfer the video to the developers.
SYSTEM SPECS: CPU: I7-6800k; GPU Nvidia GTX 1080 8GB; RAM 64 GB; SSD 960 GB; HDD 4TB
OS: Windows 7 64-bit
Plugins: X-RAAS, SkyMaxxPro 4.6, Better Pushback, Ground Handling Deluxe
Add-on aircraft: JAR A320/A330; FJS 727, 737 & Dash 8; FF 757, 767, 777; Rotate MD 80; IXEG 737; Zibo 737-8; Justflight Piper Archer III/IV; Carenado DO228; PMDG DC-6
136
McWillem wrote:
Test A330 Beta 3.0 on  NO ISSUES!!!! TOP PERFECT FLIGHT
Modelnaam:    iMac
  Modelaanduiding:    iMac18,3
  Processornaam:    Intel Core i7
  Processorsnelheid:    4,2 GHz
  Aantal processors:    1
  Totale aantal cores:    4
  L2-cache (per core):    256 KB
  L3-cache:    8 MB
  Geheugen:    40 GB
With most regular plugins, AN,FM,GHD,BP,TR,SMP4.6,XL,LS,LUA,XR2.0,
Point of attention ar the announcement of the flight ATT ( no resons)
Can you test flight using X-Life (If you own it)
137 (edited by ilankrt 2018-02-11 13:12:18)
You might publish your flight on this site. It will be a opportunity for us beta tester to see what is working and where the problems are. But we have also to know what is your hard- and software (plugins) configuration - write it in your Profile (up on the blue line)
138
Personally I think that the best way to analyse our test flights will be if we publish them as a whole flight video instead to write a half page about that often don't explain exactly what we mean.  There are 2  problems, FPS reduce and actuality (as I made a video about my flight with v.3.2 and now we have already v.3.3). In addition the publisher must tell us  what are the relevant sequences..
Here my published test flight LIPZ - LIMJ
https://youtu.be/1PlAFriH4-k
139 (edited by altsve 2018-02-11 15:29:17)
Приветствую, Евгений!
Самолет сдувает боковым ветром. На скриншоте показано как это выглядит.
Самолет сдувает после прохода точки, потом при приближении к следующей точке возвращается на траекторию - потом все повторяется, особенно заметно, когда точки расположены близко друг к другу при достаточно сильном боковом ветре, в моем случае это примерно 40 узлов боковой ветер и 5 миль между точками.
Nice work, but I have some problems with 330-v3 to following flight plan. Here is the example:
I have loaded FP to plane comp and X-life. X-life accepted plan an I control plan on my plane comp too, evrythink look ok. -
But when the plane fly to one of on plan point happened this -
so cant reach planed point RIFEN
I used latest AIRAC cycle for X-life,Aircraft and in GNS430.
A330B3:  From EDNY to LOWI:
Route: EDNY SID BEMKI Y326 XEBIX STAR LOWI
http://jardesign.org/forum/img/m/552/t/p1c62psca19cg6710h91ijs1ckj3.jpg
Flying V3.3 from LFPO to EICK Rat deployes after screens became dark .
Apparently fuel prédiction looks wrong , even whith more than one hour extra flight time .
On last flights when starting A330 fluel tanks are empty , normally they should contain the remaining fuel from previous flight , are not they ?
What am I doing wrong ?
Hi Jar
This version is very good! Its a big jump forward. Thanks very much. The only main problem i'm having is with fuel predictions. Its quite messed up (shows sometimes more at destination left that having right now). And the fuel flow seems like 25% too low. I could fly OMDB-KLAX without any problem, what is not realistic. It would be great if you could fix the fuel flow to more realistic values.
144 (edited by m5001 2018-02-11 18:05:17)
JAR wrote:
m5001 wrote:
Installed Ground Handling in:
C:\Program Files (x86)\Steam\steamapps\common\X-Plane 11\Aircraft\JD330_v3\plugins\GndHandling  (This place was the same as I had in the other beta and had no warnings)
And a lot of lines appear with this warnings:
CUSTOM DATAREF (int): jd/diagnost/ghd
[SASL INFO] loading    falses
[SASL ERROR] can't load component    falses
wrong installation. should be at
C:\Program Files (x86)\Steam\steamapps\common\X-Plane 11\Resources\plugins\GndHandling
Hi, Mr. Romanov
I did a reinstallation of the aircraft (beta3).
I also reinstalled GndHandling in place: C: \ Program Files (x86) \ Steam \ steamapps \ common \ X-Plane 11 \ Resources \ plugins \ GndHandling.
But the same warning occurred.
I returned to Beta1 and the warnings disappeared.
Probably I am the only person with these warnings in beta 3 so it should be something else, maybe on my computer that I'm going to analyze.
Thank you for your work on this amazing airplane.
145
No you are not alone. Same for me. Thousands of warnings.....
Best regards,
146 (edited by jcdp 2018-02-11 21:37:17)
Best regards,
Hi so I am
Loaded airplane fine but as reported multiple times in this topic, the MCDU does not allow proper programming of arrivals and transitions for arrival runways.  Will someone in admin acknowledge that this is being reviewed/looked at?  Thanks in advance.
148
Sending live now, and it will be up for later watching as well. A330 B3, SMP 4.6.
FLP:
YSSY MARUB6 WOL DCT KADOM Q401 UVUPU J21 MUBID Q10 HAMTN Q158 BEVLY BEVL4X YPPH
https://www.youtube.com/watch?v=axX5VAaovco
just tried inputting a coroute and got a out of memory error and CTD  with beta 3
150 (edited by MrGeeBee 2018-02-12 08:19:38)
A saved co-route from the MCDU or created with some other tool? I have had some issues with external tools. Can you attach the file? Or the route?
My above flight look like this:
YSSY SID WOL DCT KADOM Q401 UVUPU J21 MUBID Q10 HAMTN Q158 BEVLY STAR YPPH
and is in <X-Plane Root>\Aircraft\JD330\FlightPlans folder. Plain text, UTF-8 encoding.
Attachment icon YSSYYPPH.txt 74 b, 343 downloads since 2018-02-12
