Re: X-Life ver 2.1 R1
This v2.1r1 version runs quite well on my Mac.
Question: how can I start X-Life automatic when XP11 is started?
AND:
What I really miss is a way to correct some miss-communication with ATC.
Sometimes I push the wrong button and there is not a good way to correct this.
brunokoechel wrote:
I set the correct QNH. When I click "readback" there is still the wrong QNH written and in result I got a wrong QNH message.
Using the FF320 by any chance? Latest Xlife not reading the Flight Factor 320 QNH yet.
28 (edited by brunokoechel 2018-02-02 15:26:33)
Yees I used with FF320! So need Xlife or the Aircraft a Update?
Xlife needs to be updated i guess. Other applications read it just fine. Pilot2ATC for example.
30
I don't know what is going on, but when I start x-live it needs 6.8GB of RAM.
http://jardesign.org/forum/img/m/6191/t/p1c5bms7occdd1l49110t1pqvvok3.png
On the graph you can see the moment, when I turn on x-live before I can use the ATC function. 7.0GB with X-PLANE running and 13.8GB after starting x-live.
Is it a bug or do you realy load so much data? On big airports like KLAX my System is running out of RAM an X-Live is crashing. Did I somthing wrong? Did anyone else notice that?
FFa320 do not write  proper dataref of cockpit baro setting, which x life seems to read for checking. it remains at 29.92
32 (edited by brunokoechel 2018-02-02 19:14:58)
I asked them about this in beta forum.... hope for an answer.
A workauround for me is not to use Realweather for clearence. I turn it on after clearence.
Edit  I got news: "Set transponder on in ground. "
I will test soon.
I will test soon.
thank you very much, it works
No problem with frame rates was getting 35 to 45 at CYVR, 54 airborne 35 to 45 at KLAX. Same as the previous 2.7b version.  gmail login
Hi jar where is the schedule data come from as like I said before in the U.K. there is not much traffic but in xlife there seems to be lots all so the traffic at eghi pilot plus cuts on to the grass at the end of the runway is this pilot plus job to rectify or jar thanks
36 (edited by cmckjodi 2018-02-03 15:54:37)
Who is ellascott and why is this person using one of my previous quotes for his gmail link?
37
One of those spambots that dont get banned here
Just wondering what is causing the AI aircraft on approach to have another AI aircraft "attached" to the front of the plane??
I have version 2.1rc installed.
39 (edited by cmckjodi 2018-02-04 02:42:42)
Do you have the Bluebell AI packs installed? Without them might be causing the problem.
40
Hi x-plane 11.11, and x-life 2.1 R1 and FMcar 2.6r1  with new .xpl files Aerosoft EGLL payware after landing CTD when call FMcar. I add files.
41 (edited by brunokoechel 2018-02-04 11:12:15)
I also had a crash at EDDC.
My next problem is that no Follow me car appear when I land at my destination. At my depature airport everything works great.
I can call it via ATC or via the Follow me car menu but nothing happens.
At the airport map I can the a orange point where I want to go but not on my position!
When I load X-Plane again then it works also at my destination so the XLF ist not the reason.
I can't say anything about the crash cause after landing but only recommend to open taxi map after landing and choose manually taxi to the from ATC advices parking...
Yes, I have the BlueBell AI packs installed.
44 (edited by Watauga 2018-02-04 21:19:16)
JAR wrote:
Watauga wrote:
X-Life 2.1R1 in X-Plane 10.51.  Windows 10.
CTD when turned X-Life on.
is CTD happen in any airport or this only?
JAR,
I tested 5 other airports, no CTD.  I then remembered we had problems with XLF files last years.  Strange characters were showing up.  See X-Life Version 2.0  Post number 28 and 102.
Below are the corrupt lines I found in the airport folder for LJLJ.  Complete LJLJ xlf file attached.  After I remove these strange character I had no more CTD at LJLJ.
E,26,31,32,1,0,0,FromGa1DToTw
E,27,33,34,1,0,0,FromGa17ToGa
E,28,34,35,2,0,0,GaTwy
E,29,36,34,2,0,0,GaTwy
E,30,37,38,1,0,0,FromGa1DtoTw
E,31,39,37,1,0,0,FromGa1DtoTw
E,32,40,39,1,0,0,FromGa1DtoTw
E,33,32,40,1,0,0,FromGa1DtoTw
E,73,71,66,1,0,0,FromGa14ToGa
E,74,79,64,1,0,0,FromGa13ToGa
E,75,57,63,1,0,0,FromGa12ToGa
E,76,86,87,1,0,0,FromGa9ToGaT
E,77,88,89,1,0,0,FromGa10ToGa
E,78,90,91,1,0,0,FromGa11ToGa
E,79,92,93,1,0,0,GA11TieDowÿÿ
E,80,94,92,1,0,0,GA11TieDowÿÿ
E,81,95,94,1,0,0,GA11TieDowÿÿ
E,82,96,95,1,0,0,GA11TieDowÿÿ
E,83,65,96,1,0,0,TieDownGA1ÿÿ
E,232,250,251,1,0,0,TieDown38Lÿÿ
E,233,252,253,1,0,0,TieDown38Lÿÿ
S,33,TieDownRam˜,72.129997,46.228550,14.455329,0,1,0,0,0,0,0,1
S,35,TieDownRam, ,71.980003,46.228649,14.455103,0,1,0,0,0,0,0,1
S,41,Ramp Start?b,71.831734,46.231247,14.450117,0,1,0,0,0,0,0,1
Did you ever find out how these strange characters get saved in the XLF files?
Ron West, KBNA
Edit-forgot to attach the xlf file.
45
The "request follow me car" option is very unstable and often result in a CTD for me.
Of course I can use the Follow me car manual but a beter compatibility would be nice.
Watauga
Try this XLF for LJLJ
Last version is working, but:
1.)During activation, after filling my email address, input window for code has been filled by some html code, beginning with DOCTYPE..... Next start of X-Plane11 stops with message "X-Plane totaly out of memory" Deleting X-life preferences file was the correct step for recover X-Plane.
2.) Checking ATIS info I have got two informations - see picture.
Mike
48
Watauga
Darko24,
Thank you for the LJLJ XLF file.  I installed it and watch the takeoff and landing action.  Looked good.  In my version I have some of the tie downs facing different directions.  I picked up a few pointers from yours.  After I make a few more changes I will send you my LJLJ XLF file for you to look over.
Ron West, KBNA
49
In this latest version using the FREE X-Life, I select Departure info and get the runway info. I see Ai planes taxiing to that assigned runway and planes landing there as well. However, when I approach the runway to takeoff, Ai planes start to land and takeoff from the opposite runway for head-on collisions..I've reported this before via bug ticket but no resolution. Please fix this. Thanks very much. Everything else works great.
50
I'm having trouble with xlife giving me wrong/no SIDS/STARS. It says something like, "via departure" when departing. It does give me a STAR on TOD, but it's always the same STAR regardless of where I'm coming from. I have up to date 1802 navdata. Any ideas?
