@ ilankrt
Hi, yes replaced BSS folder with original Sound 3D.
When I updated to a330 v2.2r3 I did not install the BSS package at all.
When I start X plane (with the A330), ALL sounds can be heard. However, at some point either on the ground or during flight, the sounds disappear. No engines, no first officer, no switch "clicks", no altitude call outs when landing, no "retard" etc.
The only sound I am left with is wind noise. I have removed every plugin possible but the problem is still there. I have also changed the location of the X Plane folder (It was on desktop but is now C:\X-Plane 11).
Attached another log. Sound went when entering data into mcdu. Then I shut down X Plane.
I am still curious about the line "E/FMOD: C:\jenkins\design-triggered\source_code\engine\sound\soun_fmod.cpp(172): FMOD error 51 - Error initializing output device."
It appears in some of the log files.
Kind regards
