Topic: FMCar v2.6 For Win 7/8/10 MAC OS (for X-Plane 10/11)
FMCar v2.6r1
Whats New:
r1:
+ add new airport description file format (.xlf) support
+ compatible with more airports
r2:
+ .dat files reading fixed
r3: 211019
+ macOS Catalina compatible
If you have v.2.5 always installed, you may update only 2 files - win.xpl and mac.xpl
If you own an old version of FMCar and not have serial key, please contact support email and just send a copy of conformation email from shop where you get it.
Download here:
http://www.jardesign.org/fmcar/download/FMCar.zip
Re: FMCar v2.6 For Win 7/8/10 MAC OS (for X-Plane 10/11)
Thanks for update!
3 (edited by wesader 2017-11-29 09:02:26)
X-plane 11.10r1 CTD when call FMcar. Usually it's working, don't know what happend. No hurry, i just paste log.txt for information.
Problem could be in better pushback plugin also. I try it again and better pushback goes bugged. So ignore this message for now
Strange problem, I'm running XP 11.11 Final and every time I load KDCA, Washington Ronald Reagan, which is an X-Life airport, XP crashes. If I remove FM Car it loads no problem. I can fly over and around KDCA, all is fine, try and land and it crashes.                  I have used FM Car a long time and it has never crashed XP at any other airport, only KDCA.
I tried default and add-on scenery and it crashes default as well. I can't understand why only KDCA, I sent a bug report to Laminar and they have no answer. I made a clean re-install of XP 11.11 with no added scenery, KDCA loaded without problem. I then downloaded FM Car from JAR added it to XP. Tried KDCA and it crashed.
I made a support ticket, so far no reply. I wonder if anyone else could see if they have an issue with KDCA.
5 (edited by b1kbw 2018-02-20 18:39:24)
Same problem here with other airports too. KLAX for example. Just have a look at your RAM usage while starting FM car or X-Live an you will see, that the plugin needs more RAM than the hole XP11.11. Something realy strange is going on with this plug ins and no anwser from JAR.
RAM
ps: this is a 16GB of RAM system.
how do i get payware version (i cannot use it in xplane 11 windows 10
Always crash xplane, if i request fm car. I have up to date all, but every time crash.....
I have install fm car, x life deluxe, ground handling deluxe
in EDDH if i request follwme car, its always behind the plane ..........its a bug ?
I have the found a ploblem at Airport Lübeck (EDHL). If i call the FMcar the game crash to desktop.
Any plans for VR support?
Bonjour,
J'ai installé FM car dans x-plane 10 ressources/plugin. quand j'ouvre Fm car j'ai le menu bar qui apparaît et quand je clic sur map il ni à rien qui apparaît, que faire?
Boujour,
Est-ce les gens de JARDESIGN lisent nos messages ?? Aucun ne daigne répondre ni demander de détails supplémentaires !
Ce n'est pas correct.
J'ai le même problème que "alainpayen" : avec x-plane 11.26 et FM car (FM 290718) bine installé dans "resources\plugins\" et bien sûr légalement enregistré, le logo FM Car disparaît lorsque je clique dessus mais ne plante pas X-plane.
Cependant, lorsque j'appelle la FM Car à partir d'X-Life (ver. 210718), là X-plane crashe !
Merci au support de JD de bien vouloir cette fois-ci nous répondre.
Goeland27 wrote:
Boujour,
Bonjour
Dans votre cas il est préférable d'ouvrir un ticket sur "support"  (et non dans le "forum") en exposant votre problème (en anglais) et surtout en ajoutant le fichier log (situé à la racine de X-plane) pour permettre de comprendre ce qui ne va pas . Le "forum" est plus un lieu d'échange entre utilisateurs ...
Vous pouvez aussi appeler Eugeny Romanov sur skype  "just call me skype j.a.romanov" et vous expliquer .
Eugeny répond toujours .
the FM plugin causes a CTD at YSCB, always (xplane 11.30r2 on mac)
How to see all standings in large airport with many named taxi routes, like LEBL. I'll look xlf files with Airport editor and all is OK but i windows i cant see all standings.
Please make FM Vr compatible?
A most required feature: please allow users to zoom in on the map!
Thank you smile
My X-plane 11.32 crashes when loading plugin after startup of X-plane. I have tried different versions of FM but same problem every time. Do you have an idea of whats wrong? X-plane works fine after deleting FM from plugins folder.
My X-Plane 11.32 as well crashed every time I start the game.
In the log it mentioned fmcar to be the cause
X-Plane 11 crashes when starts at SABE.
Log.txt shows that crashes because FMCar (\Resources\plugins\FM\Airports/SABE.xlf )
X-Plane version:11.40r1
Airport: SABE (default version)
Thanks in advance
I'm running XP 11.41 Every time I load CYUL, Montreal International Airport, XP crashes. If I remove FM Car it loads no problem   I have used FM Car a long time and it has never crashed at any other airport, only CYUL.
X-Plane 11 crashes when starts at RPLL, with the great RPLL Scenery https://forums.x-plane.org/index.php?/f … a-scenery/
Lastline Log.txt: "XLF file exist: /Applications/X-Plane 11/Resources/plugins/FM/Airports/RPLL.xlf"
Removing the .xif doesn't help, must rm FM and X-Life plugin.
Thanks in advance
Just came across this post whilst trying to troubleshoot an identical problem with SABE airport scenery. Is there any news/advice on how to resolve this issue other than not to use JD products with this scenery or dump the scenery?
