let's have a compatible version vr (11.20) ?
can touch the buttons at the "hand" ?
JARDesign Group Board → Download, Updates → JD320 Airliner ver 3.2 r1,r2 WIN/MAC 64 bit (X-Plane 11)
Unfortunately the the aircraft continues to be unstable. SASL errors occur when trying to change the livery which seems to adjust itself during flight to the JARDESIGN default livery. A reload to another or previous livery causes SASL crash with all auto flight systems and displays failing.
I am currently on XP-11.11, but the problem has pursued since X-Plane 11.01. For me there has not been a stable version of the A320 by JAR with no flight being able to complete.
Could you add log.txt, please .
Currently I fly A320 with no problem at all .(XP 11.11 and Win 10, A320last update)
I can change livery during flight without trouble ... Are you sure to use A320JAR liveries ?
Just reporting in that the current version seems to be not working fine with 11.1, just for information.
Hey everyone, hope there´s a update soon for VR. I can´t use buttons and knobs in VR. Anyone with same issue?
Thank you.
Hi @jardesign The airplane still seem to be very unstable when approaching it swings a lot to the sides, it also freezes up when entering the fuel amount in the fmc, it also dont fallow VNAV path when approaching, and the biggest thing i see is that the automatic descent is not appropriate calculated it descents too fast that causes the airplane go over speed and hard to decrease speed even with the speed brakes full. Thank you very much
when i start engine, the plane turn around and around on himself.
Then, wire is flat then crash
SASL error announced
Have you this issue ?
Bonjour, peut-être télécharger la dernière version A320 R2...
C'est le cas
Would there be any problems if I used this plane on a different version of X Plane? I'm using 11.11 and the only problem I can spot is that the flaps have a stuttering sound. I tried redownloading the plane and sound pack several times but there it doesn't help. How could this be fixed? Thanks!
Sur ta photo je vois la version R1
the problem was i had keep my prefs.
Hi problem with FMC. I cant enter an aerport. example : i try to put LFPO/LFMN and i have the answer :
the aeroport don t be find.
How can i do plz?
hello jardesign team ,, Wondering if theres an update coming up fixing the descent rate making it more accurate, ? thank you
me too...
Jardesign Please update!
Can not activate the addon because I am on a high version. After almost 1 year would be just an update to the time!
Awaiting Update - SASL error announced still showing up.
When asked to pay additional for new release after x-plane 11, we all did. When will we get a working airplane?
If you need help, please add the log.txt ...
denismeuret wrote:Awaiting Update - SASL error announced still showing up.
When asked to pay additional for new release after x-plane 11, we all did. When will we get a working airplane?If you need help, please add the log.txt ...
Text LOG added. Thank you
jcdp wrote:denismeuret wrote:Awaiting Update - SASL error announced still showing up.
I found two things :
1) when you installed something in the "custom scenery" you have not deleted the scenery_pack.ini file from your "custom scenery" ...it will be automatically rebilt in the correct order when restarting X-Plane .this way the zOrtho ...will be placed at the end of the list (as expected...lower priority) and not at the beginning .
2) X-plane has not found navdata in the custom data/GNS430 folder .Apparently data are missing
Please verify and update if necessary .
I suggest your learn how to use X-plane first and A320 afterwards before claiming ...
Hi Sir Romanov can you tell if there is a new updates for X-plane 11.20? Best regards
When asked to pay additional for new release after x-plane 11, we all did. When will we get a working airplane?Hi
Ok... tell me what i miss and will be glad to advise all of my shortshight!
You dis not read the log.txt and you missed the source of your trouble .
