Topic: X-Life ver 2.1 beta 3,4,5,6,7 (add real schedule)
Sure, I read "plan for future" topic well.
Our Long silence means just long coding. The next version 2.1 is designed to improve one of the problems of X-Life. I mean the inadequacy of airlines and airports. Some details for new feature:
- every time when you start traffic (I mean Deluxe version), your x-life plugin will send a request to the internet and "ask" to renew schedule info for your selected Arrival and Departure airports.
- this request executed on our server side and after this, actual schedule data come to our server from real-life data schedule provider.
- next - this data (sorted from actual ZULU time) come from our server to plugin
- so, your X-Life plugin have real schedule for actual ZULU time inside now
- next step - your X-Life plugin use real scheduler with this way:
> if aircraft library (Bluebell) have needed (exist in schedule) Aircraft/Livery for next flight number we will see it in traffic (for next generated slot) with actual Aircraft/Livery/ArrivalAirport/FlightNumber
> if aircraft library not have Aircraft/Livery for real flight, plugin will try to generate flight with Aircraft/Livery what exist for this airport in real schedule
> if no lack (like we mean most of GA flights) - autogeneration will use.
So, in most of big airports we will get a flights with real Aircraft/Livery/Arrival-Departure/FlightNumber flights and this is some improvement i think.
Sure, this is a public beta version and you may take part in beta tests.
If you are on version 2.0, you need put new .xpl file (attached) to your X-Life plugin folder instead of old.
Please not forget about ZIPs (with log.txt + xlife.dmp files) if crash will happen.
So, lets start our beta job! Thank you for using!
What new:
ver.2.1 beta 3:
+ use real shedule info
ver.2.1 beta 4
+ 2 kind of crashes fixed
ver.2.1 beta 5:
+ fix some bugs and CTDs
ver.2.1 beta 6:
+ share datarefs about ATC position/state for ATC-sound plugins (expect integration)
ver.2.1 beta 7:
+ add datarefts for X-ATC-Chatter (separate plugin by Mark Ellis) integration
