201
Re: X-Life ver 2.0 R1, R2, R3, R4, R5
Suddenly I cant use ATC in x-life. I can made plan and send them to ATC and flight computer, everything work and it is OK but ATC window show me only ATC tabs and if I  go to dispatchers there is no command to put in. So I cant fly with X-life ATC.
Any idea my friends.
202
I can confirm that some planes taxi way too fast. Thats on XP 11 for me.
happy room
203
Hi fellers, have found a mistake in ATC X-Life Deluxe!
My ATC-Flight Route with JAR A320 NG and X-Life Deluxe EDDM to LGAV:
EDDM SID TULSI UM736 LIZUM UN503 LIKDA N503 LAMPO T101 AKADO L613 LISKO T415 DIPEP Q772 TIGRA UL995 KRK UL53 PIKAD STAR LGAV
Everything works fine but after command "...contact BRINDISI Center...comes next "contact AUCKLAND OCEANIC CENTER"???
Next command "...contact TIRANA Center"...next command also "contact AUCKLAND OCEANIC CENTER"...next command "...contact Athen Center"!!!!....RIGHT...on real traffic!!!!
Somethings going wrong in this aeria! Could you please check this?
Regards Thomas
204
Next question:
Start my JAR 320 NG at EDDT, starting X-Life Deluxe, window show me 53 Gates, 23 busy...ok. Start my flight from EDDM to EDDT. Follow exatly the ATC, starting decend, set all parameters for landing and have contact to approach...window show me 53 Gates, 1 or 2 busy??? No traffic on the airport, no planes at the gates! This happened on many other airports. Have no static aircrafts installed, all installed airports have ...xxxx.dat and ...xxxx.txt or .....xlf in the X-Life/Airport folder! I don't know what's going wrong?? Thomas
205 (edited by irk72ag 2017-10-21 13:54:44)
Покупал x-life еще в альфа или бета версии. С тех пор уже вышел 11 плейн, а аддон этот как не запускался у меня так и не запускается. Есть шанс что мне тут помогут? С аддоном игра зависает на этапе запуска, на фразе чек плагинс. ЧТО делать шеф?
Это делал. Толку ноль.
You may try to fix this:
- install OpenSceneryX to your XP11 Custom Scenery folder
- copy GNS430 folder from ../X-PLANE 10/Resources/ folder to ../X-PLANE 11/Resources/
206
most impressive work, phantastic!!
My question is: Are there a possibility to synchronize X-Life airplanes and traffic via network with different PC's,
because I have multiple view set up with 3 PC's and 3 X-Plane 11 versions.
I
207 (edited by cmckjodi 2017-12-16 18:47:50)
TKurzweg wrote:
Next question:
Agree this problem still exists in the latest 2.5 update planes are at the gates but very little activity upon arrival
208
X-plane 11.11r1 x-life 2.1b5 freeware SBRJ is without traffic.
My Fleet: FF A320U, FF A350, FF B763, FF B757v2 ext, JAR A330, JAR A320, ToLiss A319
Utilities: X-LIFE Deluxe, FMcar, EFASS, XEnviro, X-Camera
209
Latest Version of X-Life getting stuck on "Will init Plugin's" - no crash, just sits there.
XPlane v11.11
Please advise - Thank You
210
This is exactly what I’ve been looking for! geometry dash
211 (edited by ilankrt 2018-01-30 15:10:34)
cmckjodi wrote:
TKurzweg wrote:
Next question:
I cannot agree. In every X-Life airports I used to fly (free and payware) I see AI traffic (sometimes I have to wait long time in a raw before take-off). There are many questions open about how is the configuration of users X-Plane, plugin used etc. I wrote many times about the need of user information but no-one seems to take care about it ! So complains about complains will accumulate and no one will get a solution.
BTW every time  I see such a complain I tend to reconstruct same flight in present in a video to show - it works !!
212 (edited by cmckjodi 2018-01-31 00:44:53)
cmckjodi wrote:
TKurzweg wrote:
Next question:
Since version 2.5 significant improvements have been made 2.1.7 runs very well for me I have no problems at any of the airports that I use all show plenty of active traffic upon arrival
