151
Hey!
The SASL script error makes me crazy so I need some help.
The story in few words:
~ 2 weeks ago I got an SASL script error message. I checked the log file and I found a navdata problem. OK don't worry... I refreshed the navdata from navigraph and the problem solved. Until now.
Another SASL error.
The error message appears in XP11 when I'm trying to make a flight plan via 124atc ATC addon. Only with Jardesign A320.
(I'm using 124atc plugin from april with no problems.)
I found this one in the log file:
[SASL ERROR] Error updating avionics: [string "u//mcdu_fpln.sec"]:0: attempt to index a nil value
Softwares: Xplane 11.05r2, JAR A320 3.2r1, 124thATC ver. a58. Navdata refreshed via navigraph subscription, cycle 1710. Some custom airports and SkyMaxx pro 4.6.
Any ideas?
Thank you!
152
Hi, after the update I have same problem.
airac 1710 updated.
was working properly. fmc will clear in the flight plan configuration.
A330.
153
Hallo! I downloaded 320_JARDesign 3.2 r1 for X-Plane 11.05 and the message always was the same:<ERROR a320 system (SASL) plugin not activated. Please check your aircraft installation!Please check what your aircraft was activated!> I checked everything - nothing worked!! I have no problems on X-Plane 10.51 with the _V2.7r2. Please help me! My serial number is:T2-X7EWVJ-XUC88J-JY3WRA-NWUJ4H, wolf.roth@aon.at
Wolf
154
Wolf, the XP 11 Version is an paid upgrade, youll get a new key once you bought it. I would strongly suggest that you remove the key from your post!
155
Wolf, I would also strongly suggest that you remove your key from your post and contact jar support directly! Open a ticket here: http://www.jardesign.org/ticket/open.php
156
Finally the external shadows and XP11 icons issues for the A320 should be fixed with XP11.10, see here: http://developer.x-plane.com/2017/09/ai … -in-11-10/
157
ERROR: a320 system (SASL) plugin not activated.
Just downloaded and tried to install 3.2x and for the first time ever with the JAR320 I had an installation error. 3.1 was working just fine (back to using that one for now).
Just updated with the latest Navigraph
27" iMac, 16G/4G, XP11.05
Thoughts?
158
Thoughts?
That happened to me as well when I updated Navigraph in the _navdata folder. I reverted back to the cycle that came with the Jar A320. I since have updated the AIRAC cycle in the Custom Data/GNS430/navdata folder and select the alternate in the MCDU.
159
After a320 finds flight plan discontinuity in the progress of flight, I get dead PFD (altitude, speed and nav stuck ) and this in log:
160
All the time this error. sad
161
Come on A320 Flight Factory! Where are u? I cant get more bugs with jardesign.
162
How to fix that Jardesign?
163
When you check the flight plan , if you find a discontinuity, you have to remove it ...
To do so ,on the flight plan page
Click on Clear (which gives CLR)
Click on the left side , in front of the DISCONTINUITY
Then click on INSERT
and the discontinuity is removed .
That the normal way to procced .
X-plane 11.20Vr2
164
Test flight ULLI ESSA
All Ok... no error
Geforce GTX 1060 6Go - Saitek Proflight yoke and rudders - XP11.11r2
A320neoJDv3.2r1 & BSS PW1000 v4.0 sound pack - A330JDv3.0a & BBS PW1000v2.02 sound pack
GHdeluxe FMcar2.6r1  X-Lifedeluxe2.1r1  X-ATCchatter v1.5.3   EFASS NG   XPRealisticPro   xEnviro1.07
165
Hi guys, sorry to bring this topic. Looks like FF is coming out with a very well complex study level aircraft. My question is are there any plans to make this bird as complex as FF or FSLabs? or is it under development or something?. Can we wait it before we make any decision?. Because i like the JARA320 model and textures compared to what i have seen in FFA320, like fuselage, window reflections etc...
166
Hi guys, sorry to bring this topic. Looks like FF is coming out with a very well complex study level aircraft. My question is are there any plans to make this bird as complex as FF or Flight Sim Labs? or is it under development or something?. Can we wait it before we make any decision?. Because i like the Jar Design model and textures compared to what i have seen in FF, like fuselage, window reflections etc...
167
The Ja320 runs impeccably. My favorite plane in x-plane. By far. Stable and dependable. The A330 however stutters all the time. Every 5 seconds my FPS drops severely. The A320 doesn't do this at all and runs at 35-40 fps consistently. I'm on a MAC. Why does the A330 stutter and perform so poorly when the A320 is absolute perfection ?! Any help would be appreciated.
168 (edited by gabilondo77 2017-10-19 20:52:56)
I have the same thing with A330,only 30-40FPS stuttering from time to time,and with A320 40-80FPS everything ok..I have windows10 Pro 64bit
169 (edited by mahmutyum 2017-10-21 20:54:45)
Maybe u can add 2 step to Speed brake. Now Arm/Disengage/Half/Full but on image and original Arm/Disengage/Quarter/Half/3 Quarter/Full.
If you could add this , that we have more stability on approach.
170
regarding the speed brake problem, make sure you don't have an axis assigned to speed brake in XP.
iMac Retina 5K 27” (2015), Core i7 4GHz, OSX 10.13.3, 32GB RAM, AMD Radeon R9 M395X 4096MB, Saitek X52,  Saitek TPM, Radio, Switch & Multi Panel, 2xThrustMaster Cougar MFD,  XP 11.11r2, A320v3.2r1, A330v3.00b2, XL v2.1b4, FM v2.6r1, GndHdg v040118, SMP4.5, RWCv1.1, FlyWithLua v2.6.5, 3jFPS-wizard, PythonInterface v2.73.06, NOAA Weather v2.4.1, XSaitekpanels v2.70, Xchecklist v1.28
171
Read what I said again. I just got a suggestion.
172 (edited by wesader 2017-10-22 16:52:00)
airbus A320 have non graduated speed brake if speed break must graduate it make unrealistic A320 not a good ide.
My Fleet: FF A350, FF B763, FF B757v2 ext, JAR A330, JAR A320.
Utilities: X-LIFE Deluxe, FMcar, EFASS, XEnviro,
173
Hello guys, just updated to 11.10b3, (was on beta branch for a long time) and this aircraft is simply not compatible (everything was working fine on 11.05)!
Works perfectly until you got to use A/THR, FD, CLB/LVR, Managed mode, AP and was bored testing longer but probably more. I hope their is an update soon to fix everything, cause flying with an airbus without A/THR / Flight Director / Autopilot is quite impossible!
174
everything work fine for me with 11.10b4
no pb no error
175
The only issue I've had flying the A320 in 11.10 is the outside camera being millions of miles away from the plane, other than that, haven't had any other issues.
