176
Re: X-Life ver 2.0 R1, R2, R3, R4, R5
SirOTheOne,
Thank you for the explanation for a lack of a generated flight plan from LJLJ to LZIB.  It is a little odd that I was able to generated a flight plan from LJLJ to LOWW with just two airways from LOWG to LOWW and nothing from LJLJ to LOWG.  I looked at LBSF and LTBA, per aeronautical charts on Skyvector.com, they both have many airways.  Any ideas why no flight plan was generated from LTBA to LBSF?
Ron West
this issue is due to free airspace in austria, slovenia, ... and xlife cannot handle free airspace (without airways only waypoints).
i am from austria and cannot fly correct with xlife, too.
Watauga wrote:
No flight plan is generated from LTBA to LBSF.  See first screen shot.  When I sent LTBA to LBSF to the ATC, I got the red letter message in the third screen shot.  See the log.txt for the complete message.  When I changed LBSF to LBWN there are no problems generating a flight plan from LTBA to LBWN.  See second screen shot.  If you need more examples let me know.
Ron West
177
Morning everyone. Did anybody try X-life at SBGL. Seems the runway are too short for take off with class C aircraft. What might be a solution.
178
I've recently downloaded xlife and I've installed correctly to my knowledge, but when I go to turn traffic on from the plugin menu
X plane crashes on me. I have downloaded the 2.0 version. Any help would be great? thanks
179
I would like to know if there is a way to make the Xlife traffic visible to XPUIPC ?
How can I do ?
Thanks a lot for your reply in advance
Alexandre
180
The solution, as IRL, is not to fly class C aircraft.
181
They do actually operate from that airport, so I would like to be able to have such traffic here.
182
But then the runways are not too short for class C a/c? Do you not get enough thrust to take of before the end of the runway? Which a/c? Full TOGA thrust?
183 (edited by laohu314 2017-09-20 20:08:36)
Sadly, I have to report a rare (very rare) CTD cause by XL. Log etc attached.
Sorry for the verbose log.txt, I had debug mode on in XSaitelpanels...
184
I'm not referring to the aircraft I fly. I get 733 in and out of there without any hassles. I am referring to the X-Life traffic.
B.t.w. class B jets also have a problem getting airborne.
185
After buying X-Life, X-Plane crashes with a "totally out of memory". The free version never did that.
No errors or warnings in the log except the OOM message right on loading X-Life, followed by "0:00:13.399 D/STM: Transitioning from state state_InitialLoading to state_ShuttingDown".
http://captainduckman.com/xplane/Log.tx … -crash.txt
186
Perhaps this article may help:
http://www.x-plane.com/kb/configuring-x … al-memory/
187
Thanks, but check. This only happens when X-Life is running in deluxe (paid for) mode... And according to the log there's over a terabyte of virtual memory available, which should be enough for everyone.
188
Try to disable your other plugins and load X-Life. If unsuccessful, try a fresh install of X-Life.
189
For more convenience, I would like that  Xlife traffic would be visible to XPUIPC.
How can I do this ?
Thanks a lot for in advance
Alexandre
190
x-life still does not work with "directs" in free air space eg. austria, czechia, slovenia, ...
I´m unable to fly to EDDM with x-life. eg. LOWW SID SOVIL SITNI BAGSI MATIG AMADI Q113 NAPSA STAR EDDM with or without DCT. Does anyone know, how it works?
I think development of x-life is "broken". JAR does not respond to posts and x-life is still not working well, with or without free air space. Is x-life still alive? I´m on x-life since early alpha-phase, but i don´t know if x-life is still on development or the project dead?
191
I cheat. I let X-Life generate a flight plan and file that. In the aircraft FMC I load the flight plan I really want to fly and fly that one. No problem with ATC that way. Not ideal, but it works for me.
192
thanks for yor response, but your way (generating fp) is not like it works in real life, no airline will fly one mile more as it will be needed to reach destination and no one will fly to eddm from loww over czechia.
do you know if dev of xl is dead?
193
With all good ideas in the "plan for future" part, no more updates for July ? Bugs corrections and so on ?
Is the Xlife projetc still alive ? Or do we have to search elsewhere ?
Thanks for your helps
Alexandre
194
Alexandre
As we can feel, something is going wrong width this project. No answers to suggestion, no even small replay to our posts. This is no fear from JAR team. On the first page on internet page of JAR design wrote something like this:
We care about our users. You are very important to us, all information received will always remain confidential. We will contact you as soon as we review your message.
So like now, looks that they don't care anymore about us.
If this is no true please Jar team please to correct me.
Darko
195
My X-life stopped working it freeze when loading with the green intro text line and never disappear till i have to disable the plugin manually i tried to reinstall many times and i entered the serial correctly with no way to make it work your help will be kindly appreciated i am attaching a screen shot for what appears to me when the plugin starts
http://jardesign.org/forum/img/m/3702/t/p1bs03fu2o15d83561k1p1qsimp83.jpg
196 (edited by Arnold 2017-10-13 19:24:12)
Goodmorning everyone
Is X-Life still in development or is it an abandoned project?
Many thanks
197
X-life is not working with X-plane 11.10 b2.
What is the fix to get it working
198
X-plane 11.10.b2 is a beta ...
What do you expect ?
199 (edited by wesader 2017-10-14 14:58:15)
My x-life work very well in x-plane 11.10b1 and b2 aswell not problem at all.
My Fleet: FF A320U, FF A350, FF B763, FF B757v2 ext, JAR A330, JAR A320, ToLiss A319
Utilities: X-LIFE Deluxe, FMcar, EFASS, XEnviro, X-Camera
200
Same here. No issue at all with X-Life in XP11.10b2.
