151
I have noticed some airplanes are not following the taxiway or runway.  Attached are two screen shots.  The first one has the airliner following the edge of the taxiway.  The second is a screen shot of the XLF file for this part of the taxiway that the airliner should be following.  Several planes before this incidence and after this incident followed the taxiway with no problems.  The remaining question marks in the log text are for the GA ramp and Cargo areas.  There are no question marks on the taxiways, runways, or terminal areas.
A couple of weeks ago I noticed a Cessna 150 going into the grass median instead of staying on the runway after a landing.
152
Eugeny,
There appears to be a landing gear problem with some of the H25B airplanes.  The first three screen shots are H25B's on the taxiway without landing gears extended.  The last one, N893FL has its landing gear extended.  Is this a correction for X-Life to make or should I report this to Bluebell?
Ron West
153 (edited by ilankrt 2017-08-25 12:23:53)
Trying out under X-Life airport scenery UNKL as an approved airport on JAR map, it turned out to be an unacceptable scenery design (not that this airport is an attractive one). Airport graphic is on level of XP9 and there are no parking lots to put aircraft on one of them at simulation begin. In addition taxiways are missing. X-Life Airports includes an UNKL.xlf  file so that not might be the reason for the lack....
X-Life presented also a wire approach of an AI aircraft (I had to start from cold&dark my B748 at runway end because there was no way to park airliner elsewhere)
http://jardesign.org/forum/img/m/1591/t/p1bocko57p1ouj19rl155u10gu1m0cg.jpg
http://jardesign.org/forum/img/m/1591/t/p1bockloc71oac1n7d1pmg16u615c3d.jpg
154
I have just tried to install x-life (unregistered). I followed the installation instructions, how ever, when I try to launch X-Plane 11, it hangs at "Will initialise plugins" and will not launch. If I remove the x-life folder from the plugins folder, then X-Plane works fine.  Please help?
155
Hello everyone, I'm not sure if this is the correct place for my question, apologies if it isn't.
I have recently purchased the X-Life Deluxe ATC Plug-in, but for some reason every time I activate it, my FPS drop from 80 to about 10-15. As soon as I disable it, it goes back to normal.
I have tried to set all to minimum in the X-Life settings page, but it didn't make any difference.
I am on XPlane 11 and normally fly the A320.
156
Eugeny,
I have noticed three additional airplanes that do not have their landing gear extended while on the ground.  See attached screen shots.
Ron West
Attachment icon G-GMAA without landing gear extended while on taxiway.jpg 522.41 kb, 222 downloads since 2017-08-27
Attachment icon N728TA without landing gear extended while on taxiway.jpg 595.75 kb, 223 downloads since 2017-08-27
Attachment icon VP-CKN without landing gear extended on runway.jpg 348.8 kb, 194 downloads since 2017-08-27
157 (edited by Watauga 2017-08-28 04:16:02)
I was observing traffic flow at tdg's new LIPZ airport using the .dat and .txt files from last year.  As a side note I noticed Simliveries has a new .XLF file for this airport posted about 2 hours ago.  Traffic starting backing up at the holding point for rwy 04R.  See attached screen shot.  The first airplane in line to take off was waiting for B763.  I looked at the radar at 75 miles out and did not see a B763.  See second screen shot.  Where is this plane that is holding up the take offs?
Log.txt attached.
In post #135 I reported a similar situation at LTAC.  There the airplanes were holding for a plane that had already taken off.
Ron West
Attachment icon LIPZ Airplanes stacking up waiting to take off.jpg 112.7 kb, 194 downloads since 2017-08-27
158 (edited by wesader 2017-09-01 10:50:43)
Morning. All FPS problem are solved .. finally. Xlife FPS are now stable and between 36 and 70 depend airports. I turn off all antivirus software and cleared x.plane preferences. And i need also change my motherboard (not a xlife fault:)) but it stop booting. Anyway now all is working perfect after 2 hours testing.
PS. FPS causes and reason is solved also. All problems was cause Bitdefender freeware antivirus program, when it is on fps suttering from 45 down to 25 and more depend how long u wait, when it turn off fps punch up to 70
159
Eugeny,
I noticed another H25B without its landing gear extended while landing.  See attached screen shot.
Ron West
Attachment icon C-F JHS without landing gear extended.jpg 870.7 kb, 221 downloads since 2017-09-03
160
While observing night time operations at LTBA I noticed an airliner going off of the runway just after the rollout on rwy 05.  See first attached screen shot.  The second screen shot is taken in the Airport Editor mode so you can see the rwy sign 05/23 in relation to the position of the airliner off to the side of the rwy.  The third screen shot gives an overview of the ground routes at LTBA.  You can see the runway sign in relation to the rwy 05 and how far off the rwy the airliner went.  Unfortunately I lost the log text for this incident.
I am using this LTBA: https://forums.x-plane.org/index.php?/f … l-airport/
Attached is the .XLF I am constructing for LTBA.  I still have a few question marks to eliminate.  The taxiways and runways have no question marks.
Ron West
P.S. is there a way to attach a video of these incidences using this posting program?
Attachment icon Airliner running off the side of the rwy at LTBA.jpg 159.13 kb, 207 downloads since 2017-09-04
Attachment icon Expanded few of LTBA ground routes.jpg 158.35 kb, 195 downloads since 2017-09-04
Attachment icon Screen shot of rwy line the airliner did not follow.jpg 118 kb, 179 downloads since 2017-09-04
161
Where / How can i see what version of ' X-Life deluxe'  i have ?
162
Airplanes stacking up at LTBA waiting for A343.  First screen shot is of the radar out to 187 NM.  I did not see a plane labeled A343.  The next two screen shots are of the planes waiting for A343.  Before I started Xlife all question marks were gone.
Ron West
Attachment icon Planes waiting for flight A343 @LTBA.jpg 95.37 kb, 193 downloads since 2017-09-07
163
Starting X-Life FPS will drop
http://jardesign.org/forum/img/m/1346/t/p1bo00gra51vop1d4etvmfnq9sa4.png
http://jardesign.org/forum/img/m/1346/t/p1bo00gra51qde8ao5fl13vg23k3.png
164
No updates ?
no new things after the post from our wishes to perfect Xlife ?
Thanks a lot
More then 100 times we wrote about that looking at a specific case one need to attach the log.txt file
More the 100 times we pointed on a the fact that a specific constellation of hard and software and the plugins that are installed can cause this drop and not X-Life itself, etcetera.....
To you knowledge: X-Life is functioning 100% and bug free!
166
X-life plan still not working good for me. Planning from LJLJ to LOWW in incredible. They want to go around world in this short fly, please try and laugh. Same problem is in when i want to make plan from LOWW to LJLJ, but there is only LOWW SID LJLJ and ATC don't accept them. If i plan with online flight planner i can put plan in computer but x-life don't accept them.
When i fly from LOWW to EDDF x-life plan working, but if I strictly follow ATC route command i must go on nose if I want follow ATC command altitude.
I think you must work more on x-life planner or simply allow to ATC accept any plan from MCDU.
I have correctly installed last Aerosoft navdata cycle.
167
@ilankrt, can  you use DCT in your X-Life flight plans? On my install it doesn't work
168
After adjusting the XLF file for LBSF v3 I moved over to LTBA to observe traffic movement for the XLF file I created.  After 10-15 minutes I found aircraft holding for a plane that already took off.  See radar screen shot in the SW quadrant for B738 @ about 60 NM out.  Both planes in the next two screen shots appear to be holding for  the B738 that already took off.  Additionally I have attached the log.txt and the XLF file for LTBA.  At LTBA all question marks have been removed.
Attachment icon Plane @LTBA waiting for B738 which already took off.jpg 721.36 kb, 149 downloads since 2017-09-11
Attachment icon Radar Showing B738 already took off @LTBA.jpg 464.06 kb, 212 downloads since 2017-09-11
169
hi. I found solution myself, i was similar problem. Disable u antivirus software it helped me and x-life works perfectly.
170
171
I don't understand, I set the wind in X-plane 11 weather against a runway e.G. Wind 350° 10 knots,
but the ATC from X-life always send me to the wrong runway! e.G. 17 and not 35.
What is wrong here? There comes a red message about the real weather or something,
but disappears before I am able to read it...
172
Using X-Plane 10.51 and the latest X-life version I had a CTD while taxing to rwy 17R at KAUS.  I am using an XLF file I created.  All question marks have been corrected (removed).  Log text and dump file are attached.  The destination airport is KDAL which also has an XLF file.
Ron West
173
When setting up IFR route from LJLJ to LZIB no flight plan is generated.  See first screen shot.   However, when I check the ATIS for this flight LZIB is present.  (This is can be seen in the first screen shot) When I change LJLJ to LOWW then a flight plan is generated from LJLJ to LOWW.  See second screen shot.  To minimize variables I keep the alternate airport the same for both fight plans.  I have noticed this lack of flight plan generation at several airports.  I will report one more in a separate post so I can attach a log.txt for each.  Any ideas as to why some flight plans are not generated?
Ron West
Attachment icon Flight plan generated from LJLJ to LOWW.jpg 522.84 kb, 224 downloads since 2017-09-14
Attachment icon No flight plan generated from LJLJ to LZIB.jpg 523.93 kb, 234 downloads since 2017-09-14
174
No flight plan is generated from LTBA to LBSF.  See first screen shot.  When I sent LTBA to LBSF to the ATC, I got the red letter message in the third screen shot.  See the log.txt for the complete message.  When I changed LBSF to LBWN there are no problems generating a flight plan from LTBA to LBWN.  See second screen shot.  If you need more examples let me know.
Ron West
Attachment icon Generated flight plan from LTBA to LBWN.jpg 416.46 kb, 211 downloads since 2017-09-14
Attachment icon No flight plan generated from LTBA to LBSF.jpg 407.76 kb, 183 downloads since 2017-09-14
175
this issue is due to free airspace in austria, slovenia, ... and xlife cannot handle free airspace (without airways only waypoints).
i am from austria and cannot fly correct with xlife, too.
Ron West
