Re: X-Life ver 2.0 R1, R2, R3, R4, R5
ScottFDNY wrote:
I am new to the x life program and was wondering how do I update x life 2.0 to new versions can someone walk me through the steps one by one thanks !
Easy to do, follow post 1 of this topic... step by step
enrigolan79 wrote:
yes Eugeny,
"we can change FREQ and save it, and this changes will be reading after reopen this scenery" yes
but big problem with the new saved *.xlf file
make xplane11 crash !!!
returned back to 2.0r3 !!
sorry
Henri
Anyone more, please report about CTD when save .xlf please for 2.0r4 !!!
Hello Eugeny
Sorry I can't reproduce the CTD problem with 2.0r4 now.
Everything is Ok.
I think it was icao.xlf on LFBH airport corrupted with some stange caracters (@ $ ù£ etc...).
Deleted and all ok.
Now we can save good frequency in xlf file, re-open and always present -)))))))
Thank a lot
enrigolan79 wrote:
enrigolan79 wrote:
yes Eugeny,
sorry
Henri
Hello Eugeny
Everything is Ok.
Deleted and all ok.
Thank a lot
enrigolan79,
I have also had strange characters show up in XLF files.  See my post #28.  I have been constructing routes for EFVA and LTAC.  Sometimes when I am saving my work X-Plane crashes.  When I look at the XLF file I was constructing I will find these strange characters.  This is the EFVA airport I am working with: http://forums.x-plane.org/index.php?/fi … -by-hapet/  I notice the strange characters where in the "start ramp" lines.  It would be helpful if we can identify the source of these extra characters.  Now that I know it is not just me, I will start reporting these character aberrations.
Ron West
104 (edited by cmckjodi 2017-07-26 23:32:02)
I have been having issues with planes not appearing at gates upon arrival. Here at KSAN there are 92 gates available but only one in use. For whatever reason the traffic does not fully load or render. Anyone else have this problem? Slider gate percentage set to just under 40%
cmckjodi wrote:
I have been having issues with traffic not appearing at airports upon arrival. Here at KSAN there are 92 gates available but only one in use. For whatever reason the traffic does not fully load or render. Anyone else have this problem? Slider gate percentage set to just under 40%
Indeed not traffic at all !!!
http://jardesign.org/forum/img/m/1591/t/p1bm0ik7didik1b1q1pbn1am91tqf4.jpg
In X-Plane 10.51 and using Xlife ver 2.0 R4, no crashes when saving changes to radio frequencies.
Thanks Eugeny
107 (edited by Habbel 2017-07-28 09:57:20)
Good morning,
my experience first time using new airport editor.
I think for Airplane editor it would be an improvement when the entered names for the linenames would stay there for the next entering. So that noname only at the beginning is readable. Because I use linesnames always more than onetime. And it would be easier to klick at the linepoints, if the questionmarks, would be a little bit higher above the points. Using the new airport editor overall is much better than to do this things with WED.
Jens
108
I have encountered a problem with ver2 R4 and I cannot find anyone else posting about it. I'm using the very latest version of X Plane and I go to the plugins menu and select xlife - Traffic on/off no messages appear on screen. However, if I repeat the action and select xlife - Traffic on/off this time xlife loads and I get the usual green and then red on screen messages. My x plane log file confirms that xlife is loading but for some reason I am not getting the messages on screen the first time I start it. I have used xlife for some time and have not encountered this before. Is the problem at my end or is it a bug?
I've pasted the relevant section of my log file below in case this helps - ignore the bit about missing scenery!
XL: 0 : JARDesign plugin: E:\CLEAN X-Plane 11\Resources\plugins\X-Life\News/news.txt file updated.
XL: 0 : MessageGreen: X-Life Traffic by JARDesign Ver.2.0 r4 250717
SkyMaxx Pro: Changing cloud conditions.
SkyMaxx Pro: Will re-use cached cumulus congestus layer.
SkyMaxx Pro: Created cumulus congestus layer alt 1246.000000 size 99297.000000 density 0.500000
SkyMaxx Pro: Cloud conditions changed. Current target visibility is 120.000000
0:01:57.710 E/SYS: +-------------------------------------------------------------------------------
0:01:57.710 E/SYS: | Some scenery textures could not be loaded.
0:01:57.710 E/SYS: | This may be an installation problem or you may have a damaged add-on scenery package.
0:01:57.710 E/SYS: | Please see the log.txt file for a detailed list of missing files.
0:01:57.710 E/SYS: | (alrt.cpp:29)
WARNING: we are missing the texture: Custom Scenery/zOrtho4XP_+55-131/textures/20704_9088_BI16.dds.
WARNING: we are missing the texture: Custom Scenery/zOrtho4XP_+56-133/textures/20384_8688_BI16.dds.
WARNING: we are missing the texture: Custom Scenery/zOrtho4XP_+56-133/textures/20368_8720_BI16.dds.
WARNING: we are missing the texture: Custom Scenery/zOrtho4XP_+56-133/textures/20400_8720_BI16.dds.
WARNING: we are missing the texture: Custom Scenery/zOrtho4XP_+56-133/textures/20160_8560_BI16.dds.
0:02:12.446 I/WIN: Opened window Settings
0:02:18.317 I/REN: Setting |water reflection detail set to 0.
XL: 0 : MessageGreen: Loading... please wait!
XL: 0 : MessageRed: Turn On real weather option, or click start again to ignore this!
XL: 0 : Bluebell XL library find: E:\CLEAN X-Plane 11\/Custom Data/Bluebell XL/
XL: 0 : X-Life Airac Cycle:  1210
XL: 0 : X-Life Airac Provider: A
XL: 0 : X-Life Airac Data:  20/SEP/2012 - 17/OCT/2012
XL: 0 : MessageGreen: X-Life NavData:  1210 ( 20/SEP/2012 - 17/OCT/2012) from E:\CLEAN X-Plane 11\Resources\plugins\X-Life\navdata/
XL: 0 : X-Life NavDataPath =E:\CLEAN X-Plane 11\Resources\plugins\X-Life\navdata/
XL: 0 : X-Life NavDataProcPath =E:\CLEAN X-Plane 11\Resources\plugins\X-Life\navdata/Proc/
XL: 102 : JARDesign plugin: E:\CLEAN X-Plane 11\Resources\plugins\X-Life\Metar/PAKT.TXT file updated.
109 (edited by laohu314 2017-07-27 14:55:02)
CTD at ZBAA when requesting FM car
EDIT: CTD reproduced
EDIT2: I think I solved the issue. ZBAA had crossing Hold Areas which I removed and no more CTD and XL is working perfectly now. It might be a good idea if Airport Editor generated an error when Holding Area lines cross.
110
Watauga wrote:
Hello Eugeny
Everything is Ok.
Deleted and all ok.
Thank a lot
enrigolan79,
Ron West
Hi Ron,
I don't know why the reason of this strange caracters !!
Sometimes appear or not !!
For EFVA you have already made by Jar here :
http://simliveries.com/index.php/2017/0 … a-finland/
111
As I see you just post 5 airports at simliveries, but all cards are empty - no files attached, no link to sceneries given.
enrigolan79 wrote:
Watauga wrote:
enrigolan79 wrote:
Hello Eugeny
Everything is Ok.
Deleted and all ok.
Thank a lot
enrigolan79,
Ron West
Hi Ron,
Hi enrigolan79,
Good point.  I do need to look at Simliveries before designing ground routes to keep from duplicating the work.
I was practicing (learning) building airport ground routes with EFVA. My goal was to then look at the Simliveries EFVA to see where I need to make improvements in my ground routes building skills and how to repair my errors (the Big RED question marks) smile
Ron West
113 (edited by laohu314 2017-07-28 21:50:41)
That's weird, I have definitely uploaded the .xlf files. I will check and upload again and also add the link to the sceneries. Thanks for letting me know.
EDIT: I tried to upload again but there is no save button now. Instead ther is some error message:
Catchable fatal error: Object of class WP_Error could not be converted to string in /home3/jardesign/public_html/wp-content/plugins/frontier-post/forms/frontier_post_form_standard.php on line 187
I'll try a new posts...
EDIT2: Posted the airports again. Hope they are alright now.
114
I have a question about the departure and landing runway choice
Today flight LSZH to LLBG
AT departure, ATC allow me runway 28, 14 or 16 and that's right according the wind direction.
BUt I see, for example at LSZH  (with the application flightradar), in real the airports uses at time runways which are not allow from ATC Xlife (altough the wind direction is wrong in real, plane take off with tailwind
Why airport make such decision in real life ?
Would it be possible to update Xlife in order that compliance with real life and to choose other runways
thanks a lot
115
Today flight LSZH to LPPT
Routing : VEBI3W VEBIT T50 ROTOS UZ669 MILPA UN869 AGN UL866 PPN UN976 ARDID DCT INBOM
several feedbacks :
-at 43 NM from waypoint NEA (and 71 NM from ZWR) ATC ask me to contact New Zealand Center (???) on 114.30 between 2 request to contact Madrid Center
-center frequencies are wrong  (for example Madrid Center on 188.10)
thanks a lot
Alexandre
116
thanks a lot
X-Life give you (and to AI aircraft) runway set according with wind. Sure, reallife airports may work with little tailwind. But no way to realize this idea with current version.
117
several feedbacks :
thanks a lot
Alexandre
thanks! We will look at this issue with New Zealand!
118
May be you should care about reading and follow How to (for autors) manual at this website.
119 (edited by azur29 2017-07-31 09:43:32)
i have the X-life 2 R4 installed on Xplane11, and i have recently installing the  Bluebell pack.
When i start x-life, many Bluebell's over plane appears on my airport but there don't match with
the gate plane type.
For example, i saw a A320 tacking-of for  200 meters with a Cesna motor sound.
If i uninstall Bluebell pack, everything comes correct again.
May i forgot something ?
Another question maybe related to.  Xlife Traffic is working while no plane are activate in Xplane 11 trafficcAI menu.
How X-plane AI traffic have to be setting ?
Sorry for my bad english.
120
Frankly, I find this tone a bit offensive but I will regard it due to language barrier. Please consider that I am trying to support the community by spending time producing .xlf files for airports that other people might want to use as well. I can just as well keep those to myself.
And I did read the "How to" but nowhere did it mention that, while any file can be uploaded and apparently saved, it would not actually save the file if it isn't a .zip file or any other acceptable file type not mentioned. It might be useful to specify which file types are acceptable and generate an error message when an unacceptable file type is selected for upload. It looks like jpg is OK, too. Also, where it says 'Select "Pending" status', no choice can actually be made.
121
Yesterday i made a flight from LEMD (Madrid) to LPFR (Faro / Portugal) and two times i was handed over to "New Zealand Center" for quite a while. After Takeoff near TOC from Madrid Appproach  to New Zealand Center and after some miles to Madrid Center. After leaving Spain again back to New Zealand Center and then to Lisabon Center.
122
Just want to say that Airport Editor is an amazing tool. By far the best way to generate and edit Taxi Routes for airports. Brilliant work by JAR!
Screenshot should be attach as Featured image to simliveries post. Else - no picture will be in cataloque.
124
Ooook.. seems like New Zealand Center become a real issue. Sure, we trying to understand what wrong in code. Thanks!
125
May be you just try to use X-Life in non-verify airport?
When you use X-Life, default traffic should be turned Off.
