26 (edited by cmckjodi 2017-07-08 12:30:31)
Re: Plan for future
A lot of improvements have been made since the beginning! Much time and effort spent thank you JAR! Some notes here.                        1. Ability to skip a waypoint (sometimes vectored too far away and must circle to get to a waypoint)                                                         2. Have more planes at gates. (If 90 gates are available why only 35 planes appear? If slider is moved all the way right)                                     3. Choice of approach (Such as a VOR or RNAV) Only choice now is ILS with ATC.        4. Request Cruise altitude change (Because of weather or turbulence)        5. Flight plan change during flight (Can you do this now? Haven't tried yet)        6. All airports accepted (Not have to be verified. Actually you can use unverified airports and use WED to export .dat)                               7. Choice of carriers at airports (A small US regional airport would not have KLM or Air China as example)                                              Again thanks for all efforts and time spent! Very complicated and challenging to please everyone! Improving all the time X-Life
Re: Plan for future
Still a problem with planes not appearing at an airport. I landed at KMIA no planes at the airport. Possible bug?
Re: Plan for future
100% ATC real
Re: Plan for future
100% ATC real
No kidding ?
30
Re: Plan for future
I would love to see some " emergency services " driving around on airports , Like Firetruck , Police , Customs and ambulance
That would give more "life" to an airport
Re: Plan for future
I would also see that ATC, control ... prevent from turbulence, bad weather conditions ...and that we could be able to indicate to ATC that we have trafic insight or around us
thanks
Re: Plan for future
Hi again,
Also the possibility to chose another runway for departure or arrival that the one chosen by ATC.
For example today flight EDDH to UBBB
At EDDH ATC told me runway 23 or 15.
IN real that the 33 which is used
Re: Plan for future
It would be very cool to introduce start up engin time and to use real frequencies of airports for ATIS, Ground tower and so on
Re: Plan for future
Hi, I think a lot of good work has been done on X-Life since it's release, a couple things I would like to see which have already been mentioned is, change of FL during flight and divert to alternative airport.
Perhaps a mix of male and female controllers on the same flight would sound good.
There was someone asking for radio chatter, I found on my system if I change the frequency of ADF 1 on the radio stack I do here radio chatter. All American voices, I don't remember which update that came with.
Re: Plan for future
this come with bbs sound pack... included inside
36 (edited by Adrien KZO 2017-07-22 08:14:07)
Re: Plan for future
Thank you for your work, X-Life allows to improve flights.
So, ideas witch, according to me, could improve X-Life.
It will be nice to have the possibility to change the destination (airport), flight level during a flight and to listen other ATC communications with planes.
Thank you for your job,
Have a good day,
Adrien
37
Re: Plan for future
It might be a bit difficult to include in X-Life, but the occasional hold at a designated waypoint would be good. Perhaps there could be some sort off choice whether you wanted a hold or not.
Cheers.
Re: Plan for future
It would be great to allow xlife to insert (in flightplan operation) also airport which are not still on the map (GCTS for example)
Thanks a lot
Re: Plan for future
For communications with planes and ATC (in order to make as real as possible) I play sound from :
https://www.liveatc.net/
regards
40
Re: Plan for future
Just a very small usability improvement. Make the array "> Ground...." in front of the ATC frequency larger or highlight the current active button. On a 4K monitor the > is almost not readable. Anyway a perfect product, compliments.
41
Re: Plan for future
It would be so nice to make following airports compatible with Xlife :
GCTS
LEMD
LEPA
LFBD
LFST
Thanks a lot
Alexandre
42 (edited by enrigolan79 2017-07-29 12:44:30)
Re: Plan for future
GCTS
LEMD
LEPA
LFBD
LFST
Thanks a lot
Alexandre
Some of your request are here :
http://simliveries.com/index.php/catego … -airports/
And files attached for LFBD - LFST
43 (edited by usa2305 2017-07-29 18:59:33)
Re: Plan for future
Hi, dear simmer and JAR Design crew!
Could You add to the ATC the following:
1- expand a map to see all waypoints
2- when You pass/enter an air space of a country, you would get a notification to connect with a tower or approch to follow You.
I think it also might be  some realistic.
Thank You in advance!
44
Re: Plan for future
Would it be possible that during the climb phase, when crossing FIR/UIR, ATC ask also us to contact center / approach or to give him, our position or altitude.
At the moment, we have to reach fast the cruise level for contact ground and to report.
thanks a lot
45 (edited by tomkuhmann.69 2017-08-03 08:06:12)
Re: Plan for future
HI, I would like to know if I can go to KJFK by LFPG going through the Atlantic with a direct or an other think
sorry if it's not correct i use google trad
thank's you in advance
Re: Plan for future
In my opinion:
-ATIS have to provide by ATC. So when we receive ATC clearance, then show command option to receive ATIS.
Also altimiter or QNH (I want to see in ATIS only one), depend of country (region) standard.
-better switching from APP to CTR (in climb), and CTR to APP (in descent)
Re: Plan for future
Like this new plugin for pushback :
https://github.com/skiselkov/BetterPushbackC/releases
it would be great to have different ATC accent depending the countries or airports
For examples english with spanish accent, french accent, german accents and so on...
Alexandre
48
Re: Plan for future
It would also be nice to have a setting for altimeter to change from inHG to HPA. Atm it looks like only inhg is used by atc to check altimeter.
Problem : if altimeter is (2992 inhg) 1013 hpa and if you set the airplane altimeter from 1014 to 1013 hpa i get error "Wrong ATIS Information". If i switch now from hpa to inhg in the plane i can see whats the problem. The altimeter is 2993 inhg (not correct) but switched back to hpa  it is 1013 so correct. The Problem is that 2992 inhg and 2993 inhg is both 1013 hpa and you have to use inhg in the plane that you don't get ATIS error.
49
Re: Plan for future
I would like you to work on a new aircraft like an A350 or if you can a 787 ! i have faith that an amazing studio can come up with something brilliant!
50 (edited by laohu314 2017-08-10 21:47:26)
Re: Plan for future
I thought the flight plan error was gone but it is back. KBOS SID PATSS DCT NELIE STAR KEWR again doesn't work in XL. I have the  latest AIRAC navdata in the GNS430 folder and in the XL folder but no joy. The A320 reds the plan just fie but XL throws this at me:
XL: 40 : MessageRed: Flight Plan error: PATSS DCT NELIE Segment Error
XL: 40 : MessageRed: Please check what installed NavData cycle is the same for:
XL: 40 : MessageRed: - X-Live Plugin
XL: 40 : MessageRed: - Aircraft FMS
XL: 40 : MessageRed: - Flight Planner
I just checked another flight plan, it had a DCT in it and won't work.
very disappointed!
