Topic: X-Life ver 1.3
So, it is time to make next step forward.
What new in ver.1.3:
+ add ATC enroute control
+ add custom commands to control ATC panel via joystick
(instruction http://jardesign.org/x-life/www/custom-commands/ )
+ some minor improvements and bug fix
Permanent link to actual release
http://www.jardesign.org/x-life/download/xlife.zip
Installation:
!!! If you have ver 1.2 installed, you may update win.xpl and mac.xpl files only!
1. Be sure what you use OSX 10.9-10.12 or Windows 7-8-10 and X-Plane 64 bit 10.42+ or X-Plane 11 64 bit.
2. Be sure what you have at least one of static library installed -
OpenSceneryX. If not, you can install it for free opensceneryx.com
3. Copy “X-Life” folder to your ../X-PLANE 10/Resources/plugins/ folder
4. If you prefer use HD “Bluebell XL” traffic AI library, please download 3 files from
http://jardesign.org/downloads/BBXL/BBXL-1.zip
http://jardesign.org/downloads/BBXL/BBXL-2.zip
http://jardesign.org/downloads/BBXL/BBXL-3.zip
Next unZIP and put “Bluebell XL” folder to ../X-PLANE 10/Custom Data/ folder
and install folders “PackA”, “PackB”, “PackG”, “PackJ”, “PackP” to
../X-PLANE 10/Custom Data/Bluebell XL/ folder
X-Life use NavData (old) cycle by Aerosoft from own /navdata/ subfolder
or from ../X-PLANE/Custom Data/GNS430/navdata/ folder if exist
and put new cycle to ../X-PLANE/Custom Data/GNS430/navdata/ folder
All remain the same
- please post you opinion about this version, post what you like/unlike
- post your log.txt + x-life.dmp if Crash happen and you are on Windows.
So, now, i just continue coding ver 1.3+ Cheers!
