for scenery not on the approved map, you have to generate the .txt file yourself with Gate Editor (within X-Life).
It is possible that there are newer sceneries than the .dat files where made for. You'd have to check them out in WED to see if they are sufficiently similar to use with the provided .dat file. Once you get the hang of it, it is also not too difficult to adapt the .dat files to a newer scenery.
haas2 wrote:and the dat txt is then added automatically?
but for example: for EDDF the files which are offered whrn i cl7cl the strar are from 2015....also older than the scenerys in the xplane 11...?
