Topic: Availiabel airports
I habe a question to the availiable airports in x.life deluxe:
On this map I see all airport where xlive works, correct?
https://www.google.com/maps/d/viewer?mi … 06&z=6
I can use this plugin with the normal Xplane 11 scenery or shpuld I download the scnenerys in the map (free) ?
Peter
Re: Availiabel airports
Yes, these are the compatible airports if you want to use ATC. You can use these with the default scenery but there will be differences in the taxiways and ramp starts so I would advise to use the sceneries for which the .dat files were made.
haas2 wrote:
Peter
hello
abd where i can finde the dat files and how i install them?
what is in these Files?
4 (edited by laohu314 2017-05-31 20:02:28)
Hi haas2
the necessary .dat and .txt files get downloaded automatically from the JARDesign server. The .dat files contain ramp start position, ATC taxi routes and the runway data for the respective airport.
The .txt files contain information on the acceptable size of AI aircraft for each ramp start and can be modified with the Gate Editor that comes with X-Life. You can also modify the .dat files with WorldEditor (WED) from Laminar Research. There are instructions on the top of this sub forum (http://jardesign.org/forum/viewtopic.php?id=1670).
i have the xplane 11 from dvd with the installes scenery and xlife deluxe.
what i have to do to get the correct scenery/ txt files etc for an airport? can you make an example for me?
On the map, click on any airport (star) you want, and a side bar pops up on the left that shows you the links to all the relevant files. Download the scenery to your XP11 Custom Scenery folder. That's all you need to do.
and the dat txt is then added automatically?
but for example: for EDDF the files which are offered whrn i cl7cl the strar are from 2015....also older than the scenerys in the xplane 11...?
for scenery not on the approved map, you have to generate the .txt file yourself with Gate Editor (within X-Life).
It is possible that there are newer sceneries than the .dat files where made for. You'd have to check them out in WED to see if they are sufficiently similar to use with the provided .dat file. Once you get the hang of it, it is also not too difficult to adapt the .dat files to a newer scenery.
thank you
so whe I want to use for example EDDM:
https://www.google.com/maps/d/viewer?mi … 15&z=7
What files I shpuld download? There is no .dat file offerde ?
Peter
