Re: JD320 Airliner ver 3.1r1,r2 WIN/MAC 64 bit (X-Plane 11)
what does the (cross) waypoint mean?
Sandy
GHD
FMCAR
JD320
JARDesign Group Board → Download, Updates → JD320 Airliner ver 3.1r1,r2 WIN/MAC 64 bit (X-Plane 11)
Sandy
JAR, what about sudden movement to E46 airport?
I'm honestly afraid to fly now, knowing this bug may occur.
You've experienced it with the A320 too? The last days I only flew the A330 and I experienced this problem a couple of times (http://forums.x-plane.org/index.php?/fo … portation/). It's very annoying and it's no fun anymore to fly that aircraft because you always have to expect that sudden teleportation.
Or is it maybe a bigger problem, not only concerning the JAR aircrafts?
Hmm... Looks like Flight Factor are working on an A320 now. The price point is going to be high though, so I hope that JARDesign works hard to keep their A320 at the top - as they have done so for so long!
And not sure if it's the A320 or not, but I get a CTD on EVERY flight now... No idea what is causing it though. It could be something to do with T/D, as it only happens as I approach it. Could be SASL, as that's the last thing that was written before the fateful death of X-Plane 11.
Replacing SASL 3.1 with 3.0 might have fixed it, but will test theory further.
Can now make a full flight, but have to reload the aircraft because autopilot won't engage after T/O, and V speeds, although entered, are not displayed/read out.
PLEASE JAR INSERT PILOTS (.OBJ) INSIDE THE COCKPIT...(LIKE IN 330...)
I have big problems after missed approaches
pulling throttle to ToGa, the aircraft does many mad things
but not climb to selected altitude. Last try most instruments stopped
working, so i had no height, speed and FMC FPLN was empty,....
The red crash message left bottom of the screen pops out
The other thin is, that autopilot functions are not reliable after activating.
To get working NAV mode after start, i have to pull/push the HDG bug even if its
displayed the managed mode dot and NAV in display.
This is no fun, hoping for an update. Until this the ac stays grounded in the hangar.
dimkzr wrote:JAR, what about sudden movement to E46 airport?
I'm honestly afraid to fly now, knowing this bug may occur.You've experienced it with the A320 too? The last days I only flew the A330 and I experienced this problem a couple of times (http://forums.x-plane.org/index.php?/fo … portation/). It's very annoying and it's no fun anymore to fly that aircraft because you always have to expect that sudden teleportation.
I thought that maybe it's the X-Plane bug, but googling for it results only in JAR references. (Honestly I'm not surprised.) I haven't experienced this myself. I'm still on 3.0b6 and don't really want to update, seeing that each new release brings more bugs than it fixes.
Always, it overshot on ILS intercept.
Also, on GCLP approach, rwy 03L TERTO and ENETA transition (arc), it lost NAV and turn to incorrect side.
Same on departure LELN rwy 23, RATA1H.
Vertical Speed, dragging it, count 1 to 1. Not round hundreds on click to manage it and QNH don't match with screen.
Sandy
Cross the Mach to Speed transition, where the aircraft relies on IAS instead of mach. Usually somewhere between 24,000 - 30,000 feet.
Hi Jar!
Do you plan relase another update for the A320? When please?
A lot of bugs listed above restrict Airbus experience :-S
"restrict Airbus experience" ... funny words for this situation
I also like typo from A330 thread nearby: "long rage plane"
Will there be a GHD integration, i dont like the aeroflot handling at west europe airports.
Feel free to use my modified textures with "Aeroflot" part erased:
https://drive.google.com/file/d/0B-5hag … sp=sharing
Copy three PNG files from the archive into YOUR-JAR320-FOLDER\objects\
Don't forget to backup original ones.
It is easy to change, I made special logo area to quick change possibility.
Good fix. Finally thrust does not shoot near 100% when setting 50% for stabilization before FLEX/TOGA.
Is there any way to pop-out the MCDU panel in the latest version?
you can use AirFMC on iPad/iPhone. works perfectly
J.A.Romanov wrote:dimkzr wrote:JAR, what about sudden movement to E46 airport?
I'm honestly afraid to fly now, knowing this bug may occur.What should I do exactly to get this bug on my side? How can i reply this bug?
I don't know, maybe ask guys above who experienced this bug and posted their logs, ask Vasiliy?
Or do you think it's a pure X-Plane bug?
So here is the video that I record for the apt:E46 bug (I have listed all plugins that I used in the video):
https://www.youtube.com/watch?v=1awIMA2D6co
(happens at 25:30')
Here is the log file:
https://www.dropbox.com/s/py6wzpnek7aeqd8/Log.txt?dl=0
I was using JAR330 flying from CYVR to KEAT, it happens 6 times for me now and route is not the root cause. I have tried a flight in Florida as well.
I was afraid of updating due to all the comments here. I did it anyway, yesterday, and the plane is working perfectly fine for me. Moreover, it seems to be less resource-intensive and I get about +10FPS.
@jasonstein: Did you contacted the JAR support directly? The guys there are very qualified and respond very quickly.
Not yet, I thought the forum is the place to report bug since it says "developers forums". Should I send them email instead?
Test flight LYBE -LYTV A320 v.3.1r2 XP11r2
1. Sunshine ball disturbance on instruments glass
2. Auto-brakes remain green after TO
3. Cockpit at first daylight way too dark
4. TOC up arrow don't appear on ND green route
5. After disabling the replay aircraft get out of control !Flight properties are correct and the aircraft flies stable also during VOR approach
I will publish soon a video of this test flight......
What plugins did you guys use? Did you guys use VNAV or not? I want to figure out the root cause here.
Please give a serial number on А320.
Let me see here... How about no?
Hi - Really loving the JAR - Just have one question or thing thats happening.
We all like watching our replays - If I forget to shutdown the engines although set to idle, after switching back from replay, JAR goes into a full TOGA and crashes, crashes x-plane even.
I know the easy answer is shutdown the engines - but is this a bug? anyone else having this thing?
