201 (edited by everstalker 2017-04-16 12:27:17)
I don´t know if the issue actuelly report. When I change the vertical speed in selectet mode after departure the engines goes down and up and when change from Flex to CLB trust the same
Is it a XP or A320 issue?
202 (edited by thomas_99 2017-04-16 15:51:04)
Hi Jar,
There is a bug in the PFD, showing the compass at the bottom.
If you are >0deg, it shows negative values....
http://jardesign.org/forum/img/m/552/t/p1bdrmq4v9bttt3t18pgjut1ld63.jpg
if you are at >350 deg, it shows 370 and 380 deg :-)
http://jardesign.org/forum/img/m/552/t/p1bdrmq4v91c8cll2d5drhvd714.jpg
should be fixed..... should look like this:
http://jardesign.org/forum/img/m/552/t/p1bdrnb9r5joqv9i7dhup21bn13.jpg
Just for information, re the problem I was having with runway 23R at EGCC ( See post 170 ) I found that if I went back to nav data set 1410 that comes with the A320 the issue went away. Take off runway 23R, runway heading and then a left turn to LISTO.
However, if reloaded Navigraph nav data set 1704 the problem returned. Flight plan route behind the aircraft when lined up on 23R.
It needs someone cleverer than me to sort that out.
204
loganfid wrote:
Great update! I'm having issues when either in take off or in my departure, the navigation will tell me im close to top of decent and will cancel my navigation... any fixes?
Any log.txt?
Here is the a screen shot of where it happened, and i have attached the log.txt file.
205
Have recently purchased this again, have 3.0 r5 but when trying to push back, the plane drops back to ground and the tug has gone, is this known problem?
206
yes, update to v3r6
207
To avoid some newcomer questions I made a tutorial video from Cold and Dark of a short flight  with JAR A320.
Although it is version r3 it is suitable for all A320 r versions:
https://youtu.be/RaKz01gXrSA
208 (edited by dimkzr 2017-04-18 22:20:10)
Сегодня после взлета, во время ручного набора, директор отклонился от курса. В определенный момент вертикальная | стрелка на PFD начала уходить вбок, как бывает, когда пропускаешь точку (хотя, судя по индикации ND, я четко шел по маршруту к следующей активной точке).
Стало интересно - включил автопилот, он сразу пошел догонять убежавшую стрелку и полетел вообще в сторону от курса. Раньше это лечилось просто - принудительно задавал DIR на следующую точку, но в этот раз не помогло. Решил вернуться на курс с помощью HDG, щелкнул крутилку - и обнаружил, что все это время автопилот пытался следовать этому непонятно откуда взявшемуся курсу, накрученному на HDG. Сам я HDG совершенно точно не трогал вообще, т.к. знаю, что на земле оно не работает. До тех пор, пока я не щелкнул крутилку, она совершенно точно была неактивна ----*
До сих пор не понимаю, как тут у вас прикрепляются файлы, поэтому вот ссылка на лог до того момента, как я перещелкнул HDG и автопилот вернулся на курс:
https://drive.google.com/open?id=0B-5ha … VF6ajlxbzg
Второй момент - хотел бы предложить сделать так, чтобы крутилки не воспринимали скроллинг колесом мыши вверх как нажатие. Например, я накручиваю давление, самолет трясет, курсор мыши смещается из "зоны кручения" в "зону нажатия" и я ненароком устанавливаю STD. То же самое происходит со скоростью, курсом и другими кнобами.
209
Nice video. I just watched the first half, and I have 2 remarks:
1) You switched on the weather radar, but you did not touch the "tilt" settings. If you do so, you won't see any weather displayed
    even if there is something to display. You have to set the tilt down to compensate the climbing angle from the plane.
    In cruise, you can set it to "0" or a little bit down. And yes, the tilt angle is working. And yes, the weather display is
    working even in 160/320nm ranges!  No display -> play with the tilt settings. Now I understand that many people claim
    that the weather radar is not working.....
2) Your departure route does not work at all. On the ND, you can clearly see (during takeoff) that your route until the 1. waypoint
    is completely messed up. Needs some investigation why the A320 did not pick up the correct SID. Maybe you have to enter the
    correct waypoints by yourself. Maybe the FMC does not select the correct SID waypoints by its own.
210 (edited by ilankrt 2017-04-19 14:30:01)
@thomas_99, thanks for critical advices.
to 1: indeed I forgot to set "tilt" setting. Obviously because of that I saw nothing on ND although I was flying during approach through thick storm clouds. Unfortunately on many flight with heavy clouds on approach in some cases  I didn't get data on radar screen although a adjusted to "0". I am going to check it more closely....
to 2:  I got SID from X-Life ATC. On the image below you can see that the faulty SID path begins with 90º left directly from runway,  so I flew manually a turn and then engaged AP. In some cases I am adding FIX for an appropriate turn.
Have a look at the approach, maybe you have some more advices...
http://jardesign.org/forum/img/m/1591/t/p1be39t0bm13q1prb1r0qi2lh3.png
211
Just finished a very difficult landing at VOGO  GOA indian (worth to try landing there)
A3203r6 without using X-Life. Got no problems.
Streaming now my landing
https://www.twitch.tv/ilankrt
212 (edited by thomas_99 2017-04-20 13:10:10)
I think you did all right while entering the SID in the FMC. It seems that this is a bug in the drawing.
That's the SID:
1)  SID,BIRS1T,26,5
1)  CA,0,262.0,2,1300,0,0,0,0,0,0
3)  DF,TN820,59.194389,24.792111,1, ,0.0,0.0,0,0,0,0,0,0,0,0
4)  TF,TN821,59.123722,25.015000,0, ,0.0,0.0,0.0,0.0,0,0,0,0,0,0,0,0
5)  TF,BIRSI,59.115278,26.037500,0, ,0.0,0.0,0.0,0.0,0,0,0,0,0,0,0,0
explanation:
1) SID = BIRS1T, Runway 26
2) CA = Course to Altitude, 0=Turn Direction use shortest turn, 262.0=target course (magnetic), 2=Altitude "above",
     1300 = altitude, rest not interesting (normal waypoint, fly-by)
3) DF=Direct to Fix, TN820=name, 59...24..=position, 1=turn left, no navaid ident, rest not interesting ((normal waypoint, fly-by)
4) TF=Track to a fix ......
5) same.
In short words:
Take off from RW 26, turn to 262 deg, altitude higher than 1300ft, go to TN820 by turn left, ......
So looks like it's a drawing problem from the ND. Regarding to the SID, you should see a course from RW26 short turn to 262 deg...
I'm dissapointed about lack of "Take-off with preset HDG" procedure. Isn't it a basic functionality for aircraft?
I've been planned to train circuit flying on A320, but this is really annoying, when you can't set heading on the ground or during take-off.
I hope this will be fixed in one of the next updates.
Meanwhile, what conditions needs to be met to make HDG knob alive?
214
hi, i've tried th tilt in the weather during take off/descend and landing but never saw the clouds i'm seeing infront of me
i guess it's not working
for the record , i am flying on IVAO servers
215
You won't see just some clouds, you only will see "heavy weather" like storms, thunderstorms and so on.
i thought it might show any form of clouds , thanks for clarification
217
Well, I am sorry to say..that for me the JD320 V30R6, does not seem to be very interested in staying on course. I can fly a magnetic course.
I take off and after 1500 feet I turn on the AP.. it stays on course for a bit..then just wanders off.
sorry..:(
I am using
iMac (Retina 5K, 27-inch, Late 2015
4 GHz Intel Core i7
32 GB 1867 MHz DDR3
AMD Radeon R9 M395X 4096 MB
mac os 10.12.4
Xplane 11RC1 (64 bit)
X55 Saitek Pro Rhino Stick
X55 Saitek Rhino Throttle
Log.txt
218
oops I forgot to mention.. Re: 320 VR3.0 R6... after i get moved onto the starting ramp.. I start the plane. As soon as I begin to taxi.. it flashes a warning that my flaps are not down. another little thing..the nav data.. your folder has no capitals in the test and
my Navigraph does.. how odd. I changed navigraph to match yours, no capitals.. The 330 likes to follow the course from the flight computer but the 320 doesn't.
I am using:
4 GHz Intel Core i7
32 GB 1867 MHz DDR3
mac os 10.12.4
219 (edited by steve.cox72 2017-04-21 22:36:55)
Just updated to 3.0 r6, very pleased to see the push back bug fixed, but the ND and PFD screens are very dark (as per attached screen shot).  Turned up the brightness settings (2 knobs on the left of the displays to full) but still very dark, is this a known issue or have I missed something?
Very pleased with v3 so far.
Steve
220
Portuguese:
Eu tenho configurado várias câmeras na aeronave, e a cada atualização esse padrão de câmeras é perdido.  Essa configuração de câmera é salva em qual arquivo? Assim eu posso fazer backup dele para não perde-lo na próxima atualização.
Sugestão:
Criar um instalador para aeronave, esse instalador poderia identificar uma versão antiga, solicitar backup de câmeras, backup de Livery e demais personalizações possíveis para que não sumisse a cada update.
221 (edited by steve.cox72 2017-04-22 09:54:21)
Steve
Doing flight in daytime though and all looks well, so only appears to be an issue in the dark.
Steve
222
what about the fadec bug from the engines it´s possible to fix it it is really bad
and gives a known bug list ?
223
Flying without issues on 3.0 r6.  Updated navdata today and started getting the SASL error.  Reinstalled the plane and reactivated, but still getting the error.
224 (edited by belyaev.d.p 2017-04-22 18:23:58)
Hello! The same problem I have after update navdata. SALS error.
225 (edited by yetteh 2017-04-22 20:24:11)
Same issue here, its happening almost every flight now sad Only hapening on 3.0 r6
