176
dimkzr wrote:
rdrehmer wrote:
Well, it`s very unfortunate to know about that. I just had a quick chat with him on Skype 10 min ago and the conclusion was
“This feature exist at real airbus but work different, depend of MCDU software version.” (his words).
I`m not a real a320 pilot, so I don`t have parameters to disagree. But comparing to other FMCs, this indeed seems to be very strange.
On his place, I would rather deactivate this feature than letting it buggy like this.
The last time I tested, it automatically inserted a FL003 (300ft). Huuuum I don`t think I want to fly this low, thanks.
Can JAR prove his statement with references to FCOM/QRH or any other real document?
Let's pretend this feature do exist on a real A320. Then can JAR please explain the logic behind it? Why it randomly changing FL to random values, or even to complete nonsense?
Если интересно.. Ну нужно просто позвонить - расскажу, какие трудности то?
177
I too am having problems leaving EGCC on the LISTO departure from 23R. (See post 170) I am using 1704, the problem seems to me that the first waypoint shown on the plan is FD30RD23R then followed by CD50, which is completely in the opposite direction to the runway heading.
I also tried R23 on a SANBA departure, again heading off to FD30RD23R in the wrong direction.
It could be something I'm doing wrong, but it didn't happen before a couple of A320 updates ago.
178 (edited by ilankrt 2017-04-14 12:00:40)
As I said, JAR A320 is not yet 100% stable. I am one of those who try to help to get the optimum out of this model.
After perfect flight I also experienced a malfunction with the MCDU. After changing landing data (RWY, APPR...) during flight, I saw the new route on ND but the route wasn't display any more on MCDU.
http://jardesign.org/forum/img/m/1591/t/p1bdjj63nqk6u1f4k7je1c6p1jbl3.jpg
If you use Plan view of ND, you need scroll to point you need to see at MCDU
I switched to plan and tried to scroll but it didn't work.
The only thing I could do is back on MCDU to UUEE airport and try to input
RWY and APPR for new, but route didn't appear and scrolling was not possible (even plan mode on ND). The problem with re-programming RWY and APPR during flight (after I programed on MCDU before take off)  and choosing another RWY  (because of X-Life ATC advice) occurs several times....
179
Ok, now about NEW CRZ FL issue..
If you are on v3r4 and still have this issue, please take this file and put it to
../X-Plane_11/Aircraft/320_JARDesign/Custom Avionics/sys_mcdu/ folder
!!! Please inform me about results here or (better, if issue not gone) to skype j.a.romanov
Sure, NEW CRZ FL is normal Airbus function, but it should work if (and only)
Departure..TOC Distance + TOD..Arrival Distance < Flight Plan Distance
(for entered CRZ FL)
180
About "flying ground cars" issue..
If you are on v3r4 and thill have this issue, please take this file and put it to
../X-Plane_11/Aircraft/320_JARDesign/Custom Avionics/ folder
181 (edited by Zmile 2017-04-14 14:27:13)
Guys i need some info about one thing,
When landing if the plane Bounce (crappy landing i know) but it Bounce and it auto assumes go around (although i can still land it) hmm it retracts the speed brake and wont let me deploy them. Question, am i commited to go around at that point or can i force the speed brake a to deploy (well ir wont let me but is it normal?)
182
Congratulations, working for me (1. flight:  EDNY->EDDL, FL390, no problem !!)
Did you need to insert the "mcdi_fpln.sec file ?
184 (edited by thomas_99 2017-04-14 17:53:25)
Yes, as described. Not 'insert', replace it, overwrite the old file.
185
15. APRL 22.00 GDZ
STREAMING TEST FLIGHT A320r4
http://ilankrt1.blogspot.co.il/2016/12/ … ne-10.html
www.twitch.tv/ilankrt
Note that I am also testing streaming (FPS, quality....)
Your responding is welcome
186 (edited by awf757 2017-04-15 10:00:12)
Ok was trying out the bus for XP 11 , nice work.
(have the bus for P3D (FSLABSA320))
Noticed the system level is at a very basic level and was prepared upfront and operated in normal law.
So I looked at this from that perspective and as a dev from the dark site lol, noticed a few things which I wouldn't expect.
- Almost level of at FL100 to accelerate and then start the climb again.
- Overshooting way points in turns by a large margin
- Loosing the flight path and have a mind of it's own (also during a RNAV approach)
- MCDU (FMGS) when programming more airways in sequence not possible
- MCDU (FMGS) when not inserting the way points but programming more in sequence (yellow text) and then insert the FMGS crashes
- APU starting up sequence wrong!
- RNAV approaches no VDEV simulated?
- Love the model and reflection stuff in XP and also the 3d party BSS sounds
- Would prefer to have a few more steps in the display intensity level find it two steps to low...
- Some strange color way point lines blue instead of green with RNAV
- New FL CRZ logic not correct when starting with a sid and a star in the flight plan
- THE MCDU should show the correct current way points and below in the MCDU page but in this bus it stays where is left by the pilot and is static.
- ECAM message no FLEX set is strange and not expected... curious after which software version you modeled this bus.
- Reflections are over done for the display and windows (already discovered the windows one so easy to adjust but what is used for the displays)?
Ok much more to discover and will have a more in depth look...
Hope it's helpful...
André
Cheers,
187 (edited by rdrehmer 2017-04-15 02:20:41)
It happens some times during takeoff the airplane start rotating way before V1, just like if the trim was in the wrong position. What am I doing wrong? Pitch trim is automatic also on the ground, right?
188
Good morning Eugeny. Thank you for the update.
Installed the R5 version. Trouble with the push back truck... soon as I hit to GO button, park brake releases and truck disappears. Just to let you know.
189 (edited by venni 2017-04-15 11:40:40)
Edit: hdespres was faster:)
Same problem here with R5
190
Same here, when press GO to start Pushback, Parkbreak OFF and disappear the truck. i'm backing to "r4"
Carlos.
191
André
Cheers,
Great review! Thanks!!!
Sure, FSLABs 320 is the best for today for MSFS/P3D. So, the same autor as PMDG 737. Deep systems, good looking. One problem - it is not for X-Plane.
192
So, R6 should fix that or .. need just put this file to Custom Avionics instead of old r5 file.
193
Great update! I'm having issues when either in take off or in my departure, the navigation will tell me im close to top of decent and will cancel my navigation... any fixes?
194
Test flight XP11, XL, A3203r5, UUOB to URRR all systems are working.
Descending with strong tailwinds, I had to use speedbrakes permanently (half) all the way down to 10000 ft.
Before landing ATC ordered a GA. I pushed THR to TOGA and then problems began. Dialing speed 250 kt and 2200 ft altitude as ATC required and although under AP control all things went wrong and I had to land manually..... Who knows about an A320 video about GA ?
195
thomas_99 well than what would my problem be because I can not manually put in the DEP/ARR airport as it says not found.
196
First check if you have an installation problem.
- load the plane, use airport "EDNY"
- press "hot start" button
- look at the fmc. you can see your cycle. You should see something like this:
http://jardesign.org/forum/img/m/552/t/p1bdqs3mplosv1pvt1qhj18vpuvf6.jpg
If that's ok (no error, not empty), goto "320_JARDesign\FlightPlans" and make a new text file with name
"EDNYEDDL.txt", containing:
EDNY SID ALAGO Z5 LOKTA UN851 TEDGO UZ210 NOSPA UN857 DIK UN853 ARCKY UZ907 ELDAR T857 BIKMU STAR EDDL
Save it. That's the flight plan.
Load plan:
http://jardesign.org/forum/img/m/552/t/p1bdqsdp5td7o2tg1njtrgn3g19.jpg
http://jardesign.org/forum/img/m/552/t/p1bdqsfo0geseb78e661uti1sd5c.jpg
This should work.
Any log.txt?
198
with R6 the align  time message disappear
also   press enter to pos http://jardesign.org/forum/img/m/1294/t/p1bdr1gj8f6k7mkdv994i9c3l3.png
199
I forgot , also transponder and radiohttp://jardesign.org/forum/img/m/1294/t/p1bdr1qc2tgehrbtj8s4m1arp3.png
200
Anyone more have the same?
