Re: X-Life ver 1.2
I finally am on my PHNL to ZSPD flight on XL, A330.
After trying several changes to the route loaded from the aircraft into XL it turns out that XL had problems with ANY segment of the FP. So I basically had to use PHNL SID 1stWP STAR ZSPD to get it to work.
This needs to be looked at. XL should accept a flightplan loaded from the A330/320 without any issues so I consider this a bug.
Re: X-Life ver 1.2
I was flying with The Airbus A330 and X-Plane has crashed. I think it's linked to X-Life.
Log.txt and x-life.dmp files are linked to this message.
Thanks for helping,
Bye,
Adrien
Re: X-Life ver 1.2
Thanks for helping,
Bye,
Adrien
Thank-you, for the log.txt it made the job very easy to diganose.
So, here is the line of text that tells me that the plugin FollowMe Car has an issue;
//* FMCar plugin error: Couldn't resolve host name ///
The host name need to be resolved to get the issue resolved.
Re: X-Life ver 1.2
You're welcome.
I don't understand, moreover I don't have "FMCar plugin".
Thanks for helping,
Bye,
Adrien
Re: X-Life ver 1.2
Please,
Where can I download ALL custom ATC routes for XP airports?
When I purchased my X-Life DeLuxe license, inside the downloaded xlife.zip file there was a folder called airports containing all .dat and .txt files of all custom airports.
Why does not deliver a monthly (or whatever) zipped folder with all custom ATC routes for XP airports, including updated and new ones?
I have tried to download xlife.zip again but airports folder is empty.
106 (edited by jcdp 2017-04-10 20:27:22)
Re: X-Life ver 1.2
PGrima wrote:
Please,
When you start from an Airport of approuved list , .dat and .txt files are automatically dowloaded in the X-life Airport folder .
For airports not in the list you need to download and install yourself  .dat and .txt files from proposed airports on the X-life forum.
107 (edited by Adrien KZO 2017-04-11 14:39:46)
Re: X-Life ver 1.2
Today new flight and X-Plane has "crashed".
As yesterday X-Life seems to be linked to this problem.
I don't understand.
The PC I used is not connected to internet; is-it a problem to use X-Life ?
Thanks for helping,
Adrien
108
Re: X-Life ver 1.2
Adrien KZO wrote:
You're welcome.
Thanks for helping,
Bye,
Adrien
Im am pulling this from your log text and only trying to help you :
log.txt for X-Plane 10.51r2 (build 105101 64-bit)
compiled on Oct 18 2016 23:50:47
X-Plane started on Mon Apr 10 14:18:58 2017
This log file is generated automatically by Laminar Research applications and contains diagnostics about your graphics hardware, installation, and any error conditions.
If you need to contact tech support or file a bug, please send us this file. NOTE: this file is rewritten every time you start ANY of your X-System applications.
Windows 10.0 (build 14393/2)
This is a 64-bit version of Windows.
CPU type: 8664
Physical Memory (total for computer): 12821790720
Maximum Virtual Memory (for X-Plane only): 140737488224256
CPU 0: Intel(R) Core(TM) i3-4170 CPU @ 3.70GHz  Speed (mhz): 3691
X-System folder:'D:\X-Plane 10 Ordinateur Paris 3 juillet 2016/X-Plane 10/', case sensitive=0
WGL_ARB_buffer_region WGL_ARB_create_context WGL_ARB_create_context_profile WGL_ARB_create_context_robustness WGL_ARB_context_flush_control WGL_ARB_extensions_string WGL_ARB_make_current_read WGL_ARB_multisample WGL_ARB_pbuffer WGL_ARB_pixel_format WGL_ARB_pixel_format_float WGL_ARB_render_texture WGL_ATI_pixel_format_float WGL_EXT_colorspace WGL_EXT_create_context_es_profile WGL_EXT_create_context_es2_profile WGL_EXT_extensions_string WGL_EXT_framebuffer_sRGB WGL_EXT_pixel_format_packed_float WGL_EXT_swap_control WGL_EXT_swap_control_tear WGL_NVX_DX_interop WGL_NV_DX_interop WGL_NV_DX_interop2 WGL_NV_copy_image WGL_NV_delay_before_swap WGL_NV_float_buffer WGL_NV_multisample_coverage WGL_NV_render_depth_texture WGL_NV_render_texture_rectangle
OpenGL Vendor    : NVIDIA Corporation
OpenGL Render    : GeForce GT 710/PCIe/SSE2
OpenGL Version   : 4.5.0 NVIDIA 381.65 (450/0)
OpenGL Extensions: GL_AMD_multi_draw_indirect GL_AMD_seamless_cubemap_per_texture GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_bindless_texture GL_ARB_blend_func_extended GL_ARB_buffer_storage GL_ARB_clear_buffer_object GL_ARB_clear_texture GL_ARB_clip_control GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_compute_shader GL_ARB_compute_variable_group_size GL_ARB_conditional_render_inverted GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_cull_distance GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_derivative_control GL_ARB_direct_state_access GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_indirect GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_enhanced_layouts GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_ES3_1_compatibility GL_ARB_ES3_2_compatibility GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_layer_viewport GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_get_texture_sub_image GL_ARB_gl_spirv GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_ARB_gpu_shader_int64 GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_indirect_parameters GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_bind GL_ARB_multi_draw_indirect GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_parallel_shader_compile GL_ARB_pipeline_statistics_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_query_buffer_object GL_ARB_robust_buffer_access_behavior GL_ARB_robustness GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_seamless_cubemap_per_texture GL_ARB_separate_shader_objects GL_ARB_shader_atomic_counter_ops GL_ARB_shader_atomic_counters GL_ARB_shader_ballot GL_ARB_shader_bit_encoding GL_ARB_shader_clock GL_ARB_shader_draw_parameters GL_ARB_shader_group_vote GL_ARB_shader_image_load_store GL_ARB_shader_image_size GL_ARB_shader_objects GL_ARB_shader_precision GL_ARB_shader_storage_buffer_object GL_ARB_shader_subroutine GL_ARB_shader_texture_image_samples GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shading_language_420pack GL_ARB_shading_language_include GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_sparse_buffer GL_ARB_sparse_texture GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_tessellation_shader GL_ARB_texture_barrier GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_buffer_object_rgb32 GL_ARB_texture_buffer_range GL_ARB_texture_compression GL_ARB_texture_compression_bptc GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_stencil8 GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_transform_feedback_instanced GL_ARB_transform_feedback_overflow_query GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_64bit GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXTX_framebuffer_mixed_formats GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_polygon_offset_clamp GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_shader_objects GL_EXT_separate_specular_color GL_EXT_shader_image_load_store GL_EXT_shader_integer_mix GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback2 GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_EXT_vertex_attrib_64bit GL_EXT_window_rectangles GL_EXT_import_sync_object GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KHR_context_flush_control GL_KHR_debug GL_KHR_no_error GL_KHR_robust_buffer_access_behavior GL_KHR_robustness GL_KTX_buffer_region GL_NV_alpha_to_coverage_dither_control GL_NV_bindless_multi_draw_indirect GL_NV_bindless_multi_draw_indirect_count GL_NV_bindless_texture GL_NV_blend_equation_advanced GL_NV_blend_square GL_NV_command_list GL_NV_compute_program5 GL_NV_conditional_render GL_NV_copy_depth_to_color GL_NV_copy_image GL_NV_depth_buffer_float GL_NV_depth_clamp GL_NV_draw_texture GL_NV_draw_vulkan_image GL_NV_ES1_1_compatibility GL_NV_ES3_1_compatibility GL_NV_explicit_multisample GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_framebuffer_multisample_coverage GL_NV_geometry_shader4 GL_NV_gpu_program4 GL_NV_internalformat_sample_query GL_NV_gpu_program4_1 GL_NV_gpu_program5 GL_NV_gpu_program5_mem_extended GL_NV_gpu_program_fp64 GL_NV_gpu_shader5 GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_coverage GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_parameter_buffer_object GL_NV_parameter_buffer_object2 GL_NV_path_rendering GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_shader_atomic_counters GL_NV_shader_atomic_float GL_NV_shader_atomic_int64 GL_NV_shader_buffer_load GL_NV_shader_storage_buffer_object GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_multisample GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_transform_feedback GL_NV_transform_feedback2 GL_NV_uniform_buffer_unified_memory GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_attrib_integer_64bit GL_NV_vertex_buffer_unified_memory GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NVX_conditional_render GL_NVX_gpu_memory_info GL_NVX_multigpu_info GL_NVX_nvenc_interop GL_NV_shader_thread_group GL_NV_shader_thread_shuffle GL_KHR_blend_equation_advanced GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum GL_WIN_swap_hint WGL_EXT_swap_control
threaded_avail   : 1    aniso_avail      : 1    timer_avail      : 1    sync/fence       : 1
pbo_avail        : 1    frameblit_avail  : 1
gpu_shad4_avail  : 1    shad_lod_avail   : 1    array_tex_avail  : 1    texture_rg       : 1
tex_float_avail  : 1    seamless_avail   : 1    drawbuf2_avail   : 1    packed_stencil   : 1
framebuffer_srgb : 1    copy_buf_avail   : 1    ubo_avail        : 1    gshader_avail    : 1
base_vert_avail  : 1
instance_avail   : 1    dis_fog_avail    : 1    pinned_avail     : 0    debug_avail      : 1
max tex units    : 32 (32/8)
max iso filtering: 16.000000
max texture size : 16384 (hardware limit)
max point size   : 189.875000
idx in vram      : 1
GLSL Version     :4.50 NVIDIA/450
first-gen shaders: 0
(16/4096/124/192/32/4096/4096)
This video card is: DX10 or 11 - With instancing
CPU count        : 4
UTL_drm: GetAdaptersInfo returned: 232 on first call.
OpenAL loaded: Resources/dlls/64/openal32.dll
OpenAL devices: OpenAL Soft
Open AL default device:OpenAL Soft
OpenAL vendor    : OpenAL Community
OpenAL renderer  : OpenAL Soft
OpenAL version   : 1.1
OpenAL hardware  : OpenAL Soft
OpenAL extensions: ALC_ENUMERATE_ALL_EXT ALC_ENUMERATION_EXT ALC_EXT_CAPTURE ALC_EXT_DEDICATED ALC_EXT_disconnect ALC_EXT_EFX ALC_EXT_thread_local_context ALC_SOFTX_device_clock ALC_SOFTX_HRTF ALC_SOFT_loopback ALC_SOFTX_midi_interface ALC_SOFT_pause_device AL_EXT_ALAW AL_EXT_DOUBLE AL_EXT_EXPONENT_DISTANCE AL_EXT_FLOAT32 AL_EXT_IMA4 AL_EXT_LINEAR_DISTANCE AL_EXT_MCFORMATS AL_EXT_MULAW AL_EXT_MULAW_MCFORMATS AL_EXT_OFFSET AL_EXT_source_distance_model AL_LOKI_quadriphonic AL_SOFT_block_alignment AL_SOFT_buffer_samples AL_SOFT_buffer_sub_data AL_SOFT_deferred_updates AL_SOFT_direct_channels AL_SOFT_loop_points AL_SOFT_MSADPCM AL_SOFT_source_latency AL_SOFT_source_length
0:00:00.000 E/NET: Download failed with error: 6 for URL http://lookup.x-plane.com/_lookup_10_/s … ist_10.txt
0:00:00.000 E/NET: Download failed with error: 6 for URL http://lookup.x-plane.com/_lookup_10_/s … e_1050.txt
Fetching plugins for D:\X-Plane 10 Ordinateur Paris 3 juillet 2016/X-Plane 10/Resources/plugins
Loaded: D:\X-Plane 10 Ordinateur Paris 3 juillet 2016/X-Plane 10/Resources/plugins/PluginAdmin/64/win.xpl (xpsdk.examples.pluginadmin).
Loaded: D:\X-Plane 10 Ordinateur Paris 3 juillet 2016/X-Plane 10/Resources/plugins/EasyATCPlugIn/64/win.xpl (KiemLesNavions).
Ground Handling Plugin by JARDesign v.220815 for X-Plane 10
PluginPath=D:\X-Plane 10 Ordinateur Paris 3 juillet 2016\X-Plane 10\Resources\plugins\GndHandling\
Re: X-Life ver 1.2
Thank you.
I'm sorry, maybe I don't understand the meaning of every expression, english is a foreign language to me.
I didn't solve the "X-Plane problem".
To be continued...
Bye,
Adrien
110 (edited by fjperreault 2017-04-12 03:16:36)
Re: X-Life ver 1.2
After using X-Life for a while now I see several areas that need fixing or improving to better work in X-Plane.  In my case I am using X-Plane 11 final release.
Fixes Needed
  • Setup Window - The labels extend past the right edge of the display window.  It makes it tough to know what value you get when moving the slider all the way to the right.
  • Gate Editor window - inconsistent select action.   Selecting "None" deselects all checkmarks for all entries in the list.  Selecting "All" only selects entries currently visible, not "all" entries.
  • Gate Editor Window - scroll control works in reverse.  When the list control gets loaded with gates the first entry is at the top of the window as it should.  In order to scroll down the list I have to hit the scroll up button.  It also appears that the "thumb" is opposite of there it should be. Isn't this control supposed to work like it does in Windows?
Enhancements
  • Give the option to disable ATC in the setup options.
  • Give other weather options such as xEnviro and SkyMaxx.
  • Allow X-Life to work with the XPlane 11 "Draw parked aircraft" option.  That way I can have an airport loaded with both active and static planes.  I would like to have a full or almost full airport (think of KATL). Of course this would require x-Life to be aware of where static aircraft are and not draw an X-Life airplane on top of a static one.
  • Have X-Life get the Ramp Start data from the .dat, in particular the airline info.  Use this to put the correct livery at the appropriate gate. If that data isn't in the .dat file (older, non-updated sceneries) then do random airlines as it does now.
  • When pushing back make things a bit more realistic. As it is now, the plane backs up slightly then does a 180 degree turn. This is highly unrealistic.  Maybe have the plane back up to the first node in the taxi route from Ramp Start, then turn, would be better.
That's all I have for now.  If you have any questions, let me know.
111
Re: X-Life ver 1.2
X-Life ver 1.2  Flying from KBOS to KJFK . 20 miles from KJFK . My computer crashes running X-Life
Re: X-Life ver 1.2
Can you supply log.txt file, please .
This can help to understand what happened .
Re: X-Life ver 1.2
Here's log txt
114
Re: X-Life ver 1.2
Hi Xlife users
Received my Xplane 11 DVD's install OK works fine....
Also upgraded A330 A320 Xlife and GHD with the XP11 last versions.
A330 A320 and GHD work fine without any problem.
Xlife also works fine but only at the departure airport where I have traffic and static planes
at the arrival airports (payware and freeware Jar certified or not) I never see any static plane nor traffic...
I tried a lot of airports that worked fine with XP10.
After landing I shut down traffic and reactivate it again, then it's OK
Is there anything different in XP11 vs XP10 that I must do ?
Thanks for help if someone had the same issue
115
Re: X-Life ver 1.2
JAR
Airports are not automatically refreshed after activating X-Life ! (UWUU, UWWW, UWOO)
116
Re: X-Life ver 1.2
my X-Life crashed as well, at least according to my X-Plane log.txt
unfortunately I can not add any files, so what should I do now?
117 (edited by captbullett 2017-04-16 14:56:39)
Re: X-Life ver 1.2
why can't you add files there is a 'Browse' button down at the bottom of the webpage next to the word"Attachments" from there you should navagte to the log.txt file in the XP main folder.
then look for the dump txt also, this will take some getting use to so be pasent and take your time.
I hope this helps you, and after you up-load the files we can work on the next issue.
Re: X-Life ver 1.2
how about trying a rute like EGLL to a german airport a short hop over the English channal is what I would try and see if you get better results the work out from there the program is learnning...
Re: X-Life ver 1.2
only when quoting I have it. But anyway, attached the logs.
120
Re: X-Life ver 1.2
Hey,
i am absolutely new to XPlane, so maybe my question is a bit stupid.
I've installed X Life as stated in the readme:
1. X-Life Folder to XPlane11/Resources/plugins
2. OpenSceneryX Installer
3. Download Bluebell XL and move the folders to Custom Data.
I did not Update Nav-Data as i do not know what that means.
In the game, Xlife appears in the plugin folder.
Afer activating it on Heathrow, Munich and Nuremberg it always says:
Airport is not X Life verified. Please use menu and check verified airports map.
Well according to the map, at least Munich and Nuremberg should free?
Can you help me?
121
Re: X-Life ver 1.2
firewatch117 wrote:
Hey,
1. 1-3 OK
2. for downloading actual nav data you must have a subscription of example from Navigraph (recommended)
3. X-Life is a plugin. All plugins appears in X-Plane during flight. If you didn't buy X-Life purchase it and then you
see a bar on the left screen side. You will have to initiate deluxe (purchased) version from X-Plane plugin scroll bar..
Look at some tutorial videos, that is the best way to learn....
Can you help me?
122
Re: X-Life ver 1.2
Hi Everybody,
X-life have perfect traffic simulation, but from ATC I miss the following features:
1. after takeoff ATC say contact approach, but did not say contact center according FIR, like Frankfurt, Vienna, etc., just when I report TOD, say me contact center and I must say again report TOD.
2. I can't request flight level change in flight.
3. I do not hear another AI aircrafts communication.
4. In flight ATC not said me that I change my flight level according semicircular/hemispheric rule to odd or even flight level.
5. I don't have to tune the radio frequencies, this is very not realistic.
6. ATC does not use real frequencies, why?
7. TCAS not show x-life aircarfts, only default AI aircrafts.
Freeware like 124th ATC is more realistic, now, but I hope the future version bring us more realistic usage.
Peter
Re: X-Life ver 1.2
Thanks for your reply.
It does. But when i want to activate it, it says "Airport is not X Life verified. Please use menu and check verified airports map."
1. 1-3 OK
No, i did not (yet) purchchase X-Life. First of all i am interested in the traffic simulation.
The X-Life Homepage says:
X-Life traffic is freeware. X-Life may use freeware aircraft objects libraries (not included), like OpenSceneryX. X-Life may use traffic with freeware and payware sceneries. X-Life may be used with any X-Plane aircraft. X-Life may use NavData-base what always included to X-Plane 10. X-Life have "Deluxe" additional features, like ATC, that are payware.
- So, is it absolutely necessaray to subscribe to Navigraph/NavDataPro to use X-Life?
- Do i have to download some additional airport files or something to actually activate the traffic?
Thanks again
124
Re: X-Life ver 1.2
My precedent problem seems to be resolved. An "internet connection" seems to be necessary to use X-Life.
I had an other problem, X-Plane crashed and X-Life seems to be linked to it.
I didn't find the "origin" of the problem.
I put files with this message.
Do you have an idea ?
Thank you.
Bye,
Adrien
125
Re: X-Life ver 1.2
In an emergency situation, when do I need to get to the nearest airport? How do I apply to the ATC? There should be that option and the X-life give me the correct approach vectors to the runway.
Another example, when selecting to fly directly to any waypoint, X-Life could give me directions (Vectors) to get there, but today it continues on the scheduled route, ordering me to turn around at all times.
