Totti wrote:
Hello, first l'd like to say THANK YOU for this nice aircraft. I came from P3D to X-Plane 11 and the P11-virus touched me.
But I don't understand the posts about the NAVDATA-UPDATE. I think, it's a little confusing. I am reading about XP11 and then I am reading to put navdata in XP10-folder. Also reading about A320 and putting navdata in A330 folder.... Is it possible to write a short tutorial about updating navdata in XP11 to use A320 and A330 with the newest navdata? Take care, Thorsten
Assuming you have access to current AIRAC from Navigraph or Aerosoft:
1. Create a folder named "GNS430" in the XP11 "Custom Data" folder
2. Download GNS430 data from Navigraph or Aerosoft and put the "navdata" folder into the "GNS430" folder you created earlier.
That's it. Both A330 and A320 will now use these data.
27 (edited by dimkzr 2017-04-02 15:33:00)
Only problem I'm seeing are ground proximity warnings when on final and fully established on localiser and g/s.  Not sure if this is a JAR or XP11 issue.
Same here!
Can't remember when exactly, but there was brief GPWS "Terrain" warning either on departure from Edinburgh (no mountains or hills in close vicinity) or during landing in Amsterdam (completely flat terrain for miles).
Could you please clarify the following Question?
Bought my A320neo for XP10 before October 2016.
What do i get, if i upgrade for $19.95?
Do i get V3 and the new Serial or just a new Serial to use V2.7 in XP11 and XP10?
Read about this Question on many Posts here in the Forum and on your Website.
Unfortunately i could not exactly identify, what i get.
Would you please give me an Answer, that i really understand? Thank you.
X-Plane since V10
amo63 wrote:
Just out for a quick flight it looks like the cfm engine template has been changed can you confirm this and will it be available?
Hopefully get this livery finished and uploaded to simliveries this week
Thanks for your work
http://jardesign.org/forum/img/m/4051/t/p1bcnimbgs1vqoeoro6u1jmv4uq3.jpg
Template? If you about paintkit.. As I remember was not changed since ver.2.7 Anyway actual paintkit you may find at simliveries now.
30 (edited by dadez77 2017-04-02 16:33:21)
http://jardesign.org/forum/img/m/742/t/p1bcno6mbr1ne9nb444n2831fnd3.pngHello, i'm testing the rc1 and i've had some problems.
First is a SASL error and I pase my  SASL error, second is still present a trasparency error with sealt, image in attach.
[SASL ERROR] can't load component    debug_log_write
[SASL ERROR] Error updating avionics: [string " Avionics/ap.sec"]:0: attempt to call global 'debug_log_write' (a nil value)
Will get new serial what is good for XP10 and 11 both.
Further to the previous message about no status info in upper ecam, there is also no status in ADIRS or VHF control panel to left and right of throttle quadrant
First, please attach log.txt
Next, please Take your (virtual) head out of the headrest
Can we download for XP 10?
Thanks for reply! In attach my log.
Tomorrow i'll try to move the head.
Thanks in advance
36 (edited by piecko 2017-04-02 18:51:27)
Hi everybody,
first of all, I'm a total Noob to flight simming.
I had several problems, where the auto pilot seemed to disengage randomly. So I thought, maybe my flight plan wasn't good enough, as I just imported it from EfassNG with no restrictions and VNAV info.
I started to hack in the waypoints myself, so the fmc can calculate a vertical profile for my flight.
After adding the waypoints and the SID, I needed to get rid of that discontinouity between SID and my first "real" waypoint.
After clicking "CLR" and the corresponding line in the flight plan, I got SASL error and the fmc crashed.
37 (edited by obadvw 2017-04-02 20:04:18)
engines display went black during flight
check attached image
Log file attached as well since aircraft didn't intercept ILS @ HEGN
thought its simulated damage , reset all failures but still didn't work
38 (edited by danpetrayovich 2017-04-02 20:57:17)
Great update, but i must report that the aircraft simply won't climb as planned on the MCDU! Altitude is set on the FCU, and the alt button/knob is pushed, but it won't climb, ever. I have to manually set the climb rate to 2000 fpm. No problems whatsoever for the descent, though. It descends just like the real bird.
Also, whenever i takeoff with TOGA thrust, it does not let me retard the throttle back to climb, it remains at TOGA, and after this point, even if i disable the A/T, the bird won't ever fly like i want it to. To fix this, i always take off in Flex mode, even at dangerously short runways. One more thing: I can't set the autobrakes to MAX when landing at, say, SBRJ (which has REALLY shot runway).
That's all i have to report for now, looking forward to making this bird as real as is gets. Good job improving and updating, JAR!
**EDIT: Just noticed that night lights in the cockpit are now worknig for the PFD and MFD. Their brightness fades out dramatically during night time
39 (edited by adit.aviator 2017-04-02 20:43:56)
Engine Paint Issue
Kindly see the engine area. The paint is somehow not taken into account. Please let me know why this is happening. The liveries are downloaded from simliveries.com.
40
Engine Paint Issue
I have the same Problem.  I need help wink
Greetz
41
http://jardesign.org/a320/ and scroll down - you will see download link for v.2.7
Thanks in advance
Check log. Please follow this post http://jardesign.org/forum/viewtopic.ph … 368#p16368
If you can repeate this, please contact me direct via skype j.a.romanov
May be sim failures - a reason. May be - conflict with other plugins.
44
Anubis221 wrote:
Engine Paint Issue
Greetz
That easy - this liveries done for CFM-56 engines. You may switch it via MCDU MENU
45
Please check FCOM Part 3 - is this GW can climb this CRZ FL?
Thanks you are right...... so easy big_smile
Greetz
Whiskey in the JAR! I love it! Thanks Eugeny. Just bought XP11 and the first thing I tried to do was open my A320. Now it will actually work. Thank you!
—SHaines
48 (edited by dvc 2017-04-03 00:09:24)
In replay mode flight controls seems to either counteract the aircraft motion or work opposite way than supposed to.
(X-Plane 11 and a320neo updated to latest)
Video example below
https://youtu.be/4xoabN4ES-k
49
Great work...  Thanks Eugeny!
50 (edited by simonbarget 2017-04-03 09:36:57)
I'm having an issue with AP and SASL. How do I post my log file?
Ok - I just did it!
So the problem is that I get an on screen SASL error message at the beginning of the flight and the autopilot goes crazy. Hoping you can help.
