Topic: a320neo JARDesign ver 3.0r1-6 WIN/MAC 64 bit (X-Plane 11)
Download link: http://jardesign.org/a320/download/inst … 20XP11.zip
- be sure, that you use X-Plane 11.00
- please visit www.simliveries.com to get 130+ free liveries
a320 use NavData from
../X-PLANE 11/Custom Data/GNS430/navdata/ folder
../X-PLANE 11/Aircraft/330_JARDesign/_navdata/
and put new cycle to ../X-PLANE 11/Custom Data/GNS430/navdata/ folder (create this folder if need)
What new in this version:
+ External 3D updated by Felis
+ Internal 3D and Ground stuff updated by Dron
+ Systems updated by JAR
Need details? Well..
for R1:
+ objects and textures was reworked according with new material system of XP11.
+ redesigned/retextured MCP especially around displays (so you can see all panels layers here)
+ new textures on spots around
+ reduced amount of loaded textures (some are gone)
+ no more any gaps between panels (no flicker on any gaps in cockpit)
+ new reflections
+ now all cockpit screens/lcd panels have new glass with reflections
+ new things in cabin and new cockpit/cabin glasses (inside and outside)
+ some changes in Sky lights in cabine by yours requests
+ reflective ground stuff
+ NavData was removed from XP11 by Laminar Research and this was fixed for a320 (add _navdata with old Aerosoft cycle direct to a320 folder). Fixed.
+ User can select navData source at MCDU Status page. Improved.
+ add Diagnostic plugin, what can help if some installation was wrong (red message at screen if problem happen)
+ Perfomance and fuel calculation was broken in XP11 and fixed for version 3.0
+ Navigation system was broken and FMGS was reworked to be compatible with new XP FMS.
+ Cockpit buttons night lighting was broken. Fixed.
+ rework ND flightplan path drawing.
+ vertical profile calculation reworked
+ NEW CRZ FL option was reworked
+ Go Around fixed
+ ILS approach fixed
+ Impossible engines shutdown fixed
+ cockpit 3D light fixed
+ SPEED mode unstable fixed
+ LVR CLB flash fixed
+ display brightness improved
+ flight log improved
+ horizontal FD during SRS/RWY fixed
+ "CF" legs drawing improved
+ Rollout mode (Autoland) unstable fixed
+ reflection maps for external 3d improved (thanks Rashid)
+ brake and clock night lighting (front panel) fixed
+ baro selector work fixed
+ fcu knobs work improved (mousewheel selection work both for classic/comfort manipulators style) - please use MCDU Menu page 2 to switch style
+ not-transparent in-cockpit sunglasses fixed
+ engines start issue fixed
+ ILS DOTs indication fixed
+ JARDesign "Home" livery add (Thanks to Slava!)
+ www.simliveries.com download service add for free a320 liveries
For R3:
+ EWD/SYS disp/brightness fixed
+ displays incockpit reflections fixed
+ Terrain On ND "black" issue fixed
+ SASL error during AP auto disengage fixed.
+ Perfomance table fixed
For R4:
+ Add ability to hide rain windows using MCDU MENU Page 3
ForR5,R6:
+ NEW CRZ FL issue fixed
+ “flying cars” issue fixed
+ TOW issue fixed
About serials and activations:
- All beta-testers, who have personal serial from JARDesign may use it with XP11. If problems - please skype me or http://www.support.jardesign.org
- All users who bought the A320 AFTER the X-Plane 11 presentation event (October 2016 and later) may use their serials with X-Plane 11. If problems - please http://www.support.jardesign.org
- All users who bought the A320 BEFORE the X-Plane 11 presentation event (October 2016 and later) may update their serials (get new one) to make it worked with both - XP10 and XP11.
This JARDesign service should help for any users, what have a320 from any shop http://jardesign.org/a320-serial-update-step-13/
Update fee is about $19,95 (not include VAT for your country). Sure, you own a320 for X-Plane 10 and may continue to use it with X-Plane 10 simulator with no problem. No update need in this case. Support is continue.
Thank you!!!!
