326
Can anybody help me with this? I can't get my sound to work at all, I had the BSS pack installed, uninstalled it to see if it would work, and it still is not working. My log.txt is attached,
Using a Macbook Pro 2012
327
schineb13,
As far as I know, BSS isn't yet compatible with XP11 on macOS.
I'd recommend you to reinstall JAR from scratch and avoid BSS until they confirm Mac compatibility.
328
Hi Sir delete folder sound3d in to A320jar,and attach only BSS sound. Work fine X-plane11 rc1
329
Vertical807 wrote:
Is anyone having trouble with the APU just randomly shutting off?
I'm following proper procedure:
1. GND PWR ON
2. BAT 1 & 2
3. EXT PWR ON
4. APU & APU START On
Then, when about a minute after I disconnect EXT PWR the APU just randomly shuts off.
out of fuel?
330
FIREBLADE103 wrote:
I'm getting lines going across the cockpit windows from the external view of the beta 7 aircraft... has this been recognised by Jar?
Screenshot will be useful.. please?
331
rsd99 wrote:
Having an odd issue here.  I use a Saitek X-55 Rhino, and have the flaps assigned to switch 1 and switch 2 on the throttle side, when i go to raise/lower the flaps, all i hear is "Flaps 0" and the lever or flaps never move.  Let me know what logs i need to attach.
XP 11pb17
Latest 320 Beta
Mac OSX 12.4.3
32GB Ram
1TB SSD
Nvidia GTX-970
Rob
Please check are you have hydraulic power On.
332
It was already reported multiple times: http://jardesign.org/forum/viewtopic.ph … 098#p16098.
333
Hi Sir Romanov i know if you change the texture? In the evening plane flies well without dips important in framerate. The fall especially heavily morning the vision
334
What do you all think about beta pilots streaming their test flights as a basic for discussion about
what is good and what goes wrong?
It can be made under VIDEOS so everyone who is interested can look their after someone streaming online
and after that discuss issues...
335
Ok, pilots..
We have XP11 release now and need a little time to check details, make some little fixes and prepare release v.3.0r1 for X-Plane 11
"JARDesign" home livery will include.
336
Ok, pilots..
Great News !!
337
Just now I finished another test flight A320b7
Everything works fine under X-Life
1. The problem looking from left sit to left window 90º (headrest as a white oval disturbing view) remain although the 3D sit position is more frontally .....
2. This should be checked. Landing on RWY 14 with headwind 14 kt from 143º, aircraft was swinging hard (also under AP) !!!
3. Strips on cockpit windows seen from outside
Beside this disturbances I had a great flight and now awaiting the new release.....
338
1. I adjust the viewpoint by moving camera a bit forward to avoid looking into seats etc.
2. Have you turned off camera shake in the MCDU settings?  I find it  too severe and turn it off when I remember (it should really be off by default)
3. I can confirm the stripes on the cockpit window in outside view. That's a XP11 issue on all my ac.
339
Hello together, do you know the issue after replay mode. Engine went to full power and I couldn`t stop it.
xp 11 rc1
a320 beta 7
regards
340
xp 11 rc1
a320 beta 7
regards
I had the same issue with pb17.
341
It is a known bug. Before going into replay mode you must have parking brakes on. Return from replay mode always from cockpit view and then immediately disable ATHR
crisk73 wrote:
xp 11 rc1
a320 beta 7
regards
342 (edited by dimkzr 2017-04-01 09:35:22)
J.A.Romanov,
laohu314,
The stripes on windows are still present in XP11rc1.
I never had this problem with FF-757v2, RWDesigns DHC3, Zibo's 737-800 or any stock XP11 aircraft.
Only with JAR320 beta.
I really hope Mr. Romanov is paying attention to this thread and our comments.
So far my two biggest issues are sudden crashes (the plane can literally CTD for no obvious reason) and imperfect FMC (weird CRZ ALT calculations, no "auto-scrolling" for flight plan, terrible waypoint entering when you must insert and confirm each one separately, etc.)
There's more stuff that needs to be fixed (like HDG knob not working on the ground or ND range knob stucking on 160nm), but those two are the most annoying.
343
First off, I have now being flying with a320 b7 and xp11 rc1 a few times and there is not a lot of issues left. I realy like to fly the a320.
I had some issues that I simply could not place on ither the a320 or xp11, but as mentioned on an other post I actually got rid of some of the issues by deleting the content of the "X:\X-Plane 11\Output\preferences\" folder. But be aware that you have to setup everything again (joystick and everything).
I have one issue that I can't fix! When programming the FMC to take a flight from EKAH (Aarhus) to EKCH (Copenhagen), I have trouble with the departure. Because EKAH has no SID it will go directly from runway to (T/C) and I get a "---F-PLN-DISCONTINUITY---" that I can't delete. I have tried to add a few more waypoints (AH284 and GINUB) but I simply can not delete "---F-PLN-DISCONTINUITY---".
This does only seem to occur on departure airports without SID. I'm not sure this is a bug because I actually got it working ones. But I do not know why.
/Michael
344
1. Yes first of all I set the camera to be in the middle of the captain sit, then I adjust the distance to see always the APPR button. I can try to set it once more forward but I like to see in the 3D position all needed buttons. (if you like send me your position setting)
2. Yes I always disable it and it must be really off be default !!
3. There are some more issues mentioned by dimkzr to get this aircraft model to 100%
345 (edited by dimkzr 2017-04-01 09:33:29)
MichaelMaar,
I just tried your route with same results.
Since there's no SIDs for EKAH, I just picked runway for departure, entered a couple of waypoints toward EKCH and picked STAR for EKCH arrival.
FMC doesn't allow me to delete discontinuity as well, and doesn't even draw route on ND like there's no valid flight plan at all.
http://jardesign.org/forum/img/m/4188/t/p1bckdp4hfnbns7o15kvb0v1oj33.png
http://jardesign.org/forum/img/m/4188/t/p1bckdp72kkeecgo1iahk7ipba.png
346
Ok, seems like we very-very close to release of version 3. That was a looong way. A lot of things was done. Some - not. Anyway - this topic close not and we will jump to release topic http://jardesign.org/forum/viewtopic.ph … 330#p16330
Sure we need wait day or two to see `Download link there, a little details (strips on windows) should be solved.
I want say THANKS A LOT lot all beta-testers, who take part in this trip and report their test experience. I read it 100%, please be sure. Thank you Very much!
