On which Airport please , can you mention it ?
JARDesign Group Board → Beta-versions (Download & Discussions) → ver.3.0 beta 2,3,4,5,6,7 for X-Plane 11
EKAH Aarhus Denmark
Test flight A320 b5, ULLI - UUEE
1. Very annoying is the new (?!) reflexion of the sun light (I think because of the low sun position in the north hemisphere) on the instrument panel, so it is not possible to read data !
2. The reflexion of instruments and seat cover in the pilot windows is also too egregious and really disturbing during flight - see image
3. Knob story seems now to have an end
4. Calling FM car for taxi don't work, I have to do it over the FM map...
You can switch all reflections off by clicking switch zone
Landing at EKAH Aarhus Denmark...
I need to have confirmed this. On ILS glide slope I'm off the centerline by 20 meters to the left, and the ILS dimond does not center ither (see picture:
When actually landing the plane banks to the right at the last moment (see picture):
Is this a bug in the A320 or is it X-Plane 11 (LR) or is it the navdate (I'm running 1703)?
Maximum Wind Conditions for CAT II or CAT III
Automatic Approach:
- Headwind 30 kt
- Crosswind:
CAT I - 20 kt
CAT II or III - 15kt (for OpSpec)
- Tailwind 10 kt
Your ND shows 11kt and on PDF we can see how the wind pushes the aircraft.
AP should handle it but I think you made a mistake. I guess that you landing speed 129 kn was too low.
This can influence the aircraft stability during landing.
Next time look at your APPR page..
MichaelMaar wrote:Hi,
Automatic Approach:- Headwind 30 kt
- Crosswind:
CAT I - 20 kt
CAT II or III - 15kt (for OpSpec)- Tailwind 10 kt
You were right (my bad). My speed was too low.
But after I had looked on APPR page (Vapp = 141kt) I did the whole trip again. It was better this time, but it was still banking to the right at the last moment. Not as much as before but it did. It might be me (I'm only a toy pilot), but I didn't see it like this in X-Plane 10.51. But I'm still learning.
Thanks for your input...
/Michael
Anyone problems with XP11 PB14 ?
Looks like they changed the tire modell, I have problems rolling on the ground .. it is really jerky...
with pb13 all was ok...
with pb13 all was ok...best regards,
Same problem. Just turn off head shake in the FMS.
Hello everyone!
I can not activate the JarDesign A320neo beta in X-Plane 11! I already deinstalled all plugins and checked but it didn't work! I have the latest navdata cycle and my serial number is valid as well. As you can see in the image I get this error message and I can not see the sasl plugin in the upper bar - but I enabled it! I have no idea how to fix this - can someone please help with this problem!
If you can not read the error message,
It says:
ERROR: a320 systems (SASL) plugin not activated.
- Please check your aircraft installation!
- Please check what your aircraft was activated!
- If activation window not appear - please contact support
Thx!
Are you using old or new key?
Hello everyone!
It says:
- If activation window not appear - please contact supportThx!
I use a new key.
philip-freitag wrote:Hello everyone!
It says:
Using B6
After takeoff flaps retracted, THR CLB, plane pitch up and speed increasing above speed restriction!
A/P disconnect.
Whats the problem?
Dekel
I have problems to complete a flight. SASL ERROR
I'm using XP11 PB14 and JARA320 V3.0B5
Any idea?
Log when error start:
124thATC v2.0-a53 15:59:12 : ILS Path set to RWY 21.
124thATC v2.0-a53 15:59:12 : Take arrival runway 21
[SASL INFO] "mcdu_fpln" --> Set active WPT to 17L for APT_DEP/DEP_RWY reason
[SASL ERROR] Error updating avionics: [string "u//mcdu_fpln.sec"]:0: attempt to index a nil value
124thATC v2.0-a53 15:59:12 : reading acc.dat
same issue here
Anyone else with the follow issues (v3 b6): maybe I am doing something wrong.
1. Does not capture the LOC/GS correctly.
2. AP1 engaged, aircraft flies off course. Happened twice during approach. Manually turned and aligned to the runway heading, back to first point with LOC/GS not capturing !!
3. Xplane11PB14 , weight and balance : Automatically on either end of the slider, restoring to default will show a balanced center, but if you save and check later, its back to either side. +37 or something like that.
4. At times cannot delete or clear (CLR) a Discontinuity in the Flight Plan).
Forum doesn't let me save a signature yet, so my specs and versions are:
JARDesign A320 v3.B6
XPlane 11 PB 14
AsusROG G752VY: NVidea 8GB GTX 980M, M.2 512GB(RAID 0), 64GB DDR 4
XP b14 seems to cause problems due to changes modeling physics ... B15 should be out today but I don't know
if it will fix them. It think that it will be a good idea to stop for now at b13 and wait a while...
Jar has also announced a new beta version but I think that he is also waiting for XP changes...
Unfortunately, I was away on a trip in China for 3 weeks and missed XP updates until XP11pb14. Did a test flight ZSPD-ZUUU (one I did in RL in an A321 recently). Things went pretty well until final, when the last turn onto runway heading didn't occur automatically and I had to line up manually. Also, the front landing gear didn't deploy so the landing was less than satisfying, if you know what I mean... (no idea why that happened, I thought that the A320neo didn't support failures...). Also, during descent, the speed window (between overspeed and stall speed) was VERY small at times, although overall I felt that the managed descent worked much better than previously.
One additional minor thing, the Barometer knob direction is programmed in the opposite direction, i.e. that you have to move left (or down) to increase and vice versa for decrease but maybe that's just a personal fad of mine.
iMac Retina 5K, 27-inch OSX 10.11.06, 4 GHz Intel Core i7, 32 GB 1867 MHz DDR3, AMD Radeon R9 M395X 4096 MB, XP11v.pb14, XL 1.2r2, A320v.3.b6, JAR FM and GHD
Just completed ZUUU to ZSPD with A320v3b6 and XP11b15. Absolutely PERFECT flight, one of the best I've ever experienced. Managed LNAV and VNAV totally perfect.
Fantastic job Eugeny, congratulations!
iMac Retina 5K, 27-inch OSX 10.11.06, 4 GHz Intel Core i7, 32 GB 1867 MHz DDR3, AMD Radeon R9 M395X 4096 MB, XP11pb15, XL 1.2r2, A320v.3.b6, JAR FM and GHD
One additional minor thing, the Barometer knob direction is programmed in the opposite direction, i.e. that you have to move left (or down) to increase and vice versa for decrease.
Yes would appreciate that being put back the normal way.
Hi, is it me or in these xp11 beta versions setting flaps at 1 does not command speed reduction at 180 kts anymore? Have to rotate the speed knob manually and then speed is reduced. Is this the right procedure? Thank you.
Hello Eugeny,
you have like a broken glass in the middle of the cockpit
Hello Eugeny,
Please attach log.txt. I'm not seeing this in my A320...
Hello Eugeny,
This is part of seat in view area.
it feels like you need a lot of throttle input to make the A320 taxi, also when you advance the throttle it just jump to higher N1 then back settle to lower value .
is it how it should be or something need refining here?
It seems like the barometer settings from the actual barometer and the number in the pfd are different.
http://imgur.com/a/lvT0w The picture was taken in LSZH - but I think it got nothing to do with the airport.
I also had problems with the ILS when trying to land in EDDF. The markers in the pfd were way off and I wasn't able to capture LOC or the GS.
Has Anyone else had this Problem?..on the A20..V3.6B The radio light will not work for me in XPlane 11.B15
I am using..
iMac (Retina 5K, 27-inch, Late 2015
4 GHz Intel Core i7
32 GB 1867 MHz DDR3
mac os 10.12.3
Xplane 11.B15 (64 bit)
X55 Saitek Pro Rhino Stick
X55 Saitek Rhino Throttle
