benjcarter wrote:Oasis wrote:Thank you so much for your help. So do I need to activate the product again after I replace the whole aircraft folder with Beta 7 (like my first installation for beta 6)?
Yes - same process as normal. Enter your activation code into the pop-up and then reload the aircraft when it prompts. I have the BSS soundpack and I had to completely quit XPlane and restart to get the sounds to work. Worth bearing in mind if you have the soundpack.
Thanks, just wondering how many times we can use our activation code to activate the aircraft after the updates? or there are no limitations?
I don't believe there are limitations - I certainly haven't experienced any and I update with every Beta? I imagine the activation code will only work on one version at a time though.
