First attempt with XP beta version on XP11pb11.
Few issues:
- Liveries downloaded from JAR forum do not switch; thumbs do not generate correctly. Generated thumbs placed in the livery folders are the same stock A320 Neo livery. Seems aircraft does not "see" liveries folders, except Lufthansa it came with, : D:\X-Plane 11\Aircraft\320_JARDesign\liveries. I have two other 3rd party airplanes, CRJ 200 and Epic 1000 v.2, both switch liveries and generated thumbs OK.
- Parking brake release will disconnect and remove ground power and remove fuel truck; aircraft will go cold and dark if was powered up
- If parking brake was released before connecting ground power and/or calling the fuel truck it is no longer possible to connect the ground power or call the fuel truck; other options like doors, stairs are working
- Switching airport while A320 is loaded will remove parking brake when aircraft loads at the new airport, thereby making it impossible to call the ground power or the fuel truck
- XP11 weight/balance/fuel menu shows single fuel tank
Log attached.
I7-5820K 4GHZ (OC) | GTX1070 8GB | 32GB DDR4 | 512GB SSD Samsung 950 PRO .M2 x4 | MSI X99S SLI PLUS | WIN10 x64 PRO
"If only I could stop flying toy air planes..."
