26 (edited by zasavage 2017-02-17 18:20:39)
So far so good Eugeny , Looks good
The size of the icons created is wrong , A320 is the only aircraft doing it ,
And please add Aircraft Class , Design Studio and manufacturer to acf ..
P acf/_manufacturer Airbus
P acf/_is_airliner 1
acf/_studio JARDESIGN
Lawrence
Looking at throttle input vs actual performance...
should they not be equal ie: 25% throttle equals 25% RPM?
Please see video...
A320 v3 b2 video: https://www.youtube.com/watch?v=Pr49vBJ5gkc
The A330 b6 seems to perform properly - see video below.
https://www.youtube.com/watch?v=OwVM84c9po8
Hope this helps.
Very very good job. First flight from LSGG to LEPA without problems. Even from the paintkid the created liverie worked for our airline. The only thing in the Sid goes the A320 in the overfly.
Thanks for the great aircraft.
http://up.picr.de/28348866ds.jpg
http://up.picr.de/28348867sy.jpg
Question on liveries - plan on buying this product tonight do older community repaints work with this new beta version for XP11 if not then what are the provided liveries that are working with this new version - thank you
30 (edited by scoochy 2017-02-17 20:14:01)
The United livery I grabbed from the ORG seems to work!
http://jardesign.org/forum/img/m/3517/t/p1b96r9u8es8f1m63bmu871tu4.jpg
Thanks want to here from developer also smile
So why do I have to pay an upgrade when I bought mine in October?
All users who bought the A320 AFTER the X-Plane 11 presentation event (October 2016 and later) may use their serials with X-Plane 11. If problems - please http://www.support.jardesign.org
- All users who bought the A320 BEFORE the X-Plane 11 presentation event (October 2016 and later) may update their serials (get new one) to make it worked with both - XP10 and XP11.
I paid for the update yesterday and still have no email response. Paid through PayPal.
      JeffG
Bought mine OCT 16 and according to the serial key updater I have to pay.
36
So as I've doe couple of flights  these are maybe the things I'd like to see fixed asap!
1. IRS Align. ND should not show map before IRS is aligned. Now it does show even there is 5 minutes remaining according ECAM.
2. QNH Knob. Sometimes it skips one number and there is no way to select it (i.e 1027-1028)
3. Little bit tuning for speed hold. This is not critical as it works way better now than it did before update
Otherwise I am quite happy with this now. Flights are quite smooth and plane works and annoying graphical bugs are gone.
37
My serial is rejected too.  I ve bought my copy of a320neo on 11.11.  I dropped a ticket.  No replay yet.
Loaded the update today, worked well with the BSS sound pack v3.1. I had a small issue with the sound pack as I run XP on Mac, when I loaded the Mac fix that came in the file as per instructions it CTD 3 times, but when I undid the Mac fix it worked fine.
Did a flight from EGLL to LFPO there were no problems apart from the ILS course issues which I understand is a XP bug.
Like others my old liveries don't appear to work, hopefully someone cleverer than me can sort that in due course.
Re my entry above, I just downloaded a livery from the Jar website and it worked. Not sure why my previous two attempts failed.
40
when I save and load a situation, the flight plane nor the plane settings are saved or restored. It works fine on the stock planes. Is that a known issue?
cheers
XP11 beta 13,  A320 3b4, Windows 10, GTX 1070, Intel Core i5-6600K @ 4.3GHz
41
The Loud Speaker button does not work properly. The button only works as Mute or Maximum. The button does not rotate in the intermediate values.
Can't go TOGA with ATHR on. Can't limit thrust either, unless set it all the way down to idle.
https://youtu.be/-z4q64cnP40
Two flights today... one day flight CYVR / CYOW with no problems at all. One night flight this evening CYOW / CYHZ... Ecam buttons not lit and brakes display not lit up either. Small stuff. Love your products and the A320 is always my favorite aircraft. Thanks for being here Eugeny, great job!  Cheers. :-)
44
How can I pay for the downloaded A320neo Beta for Xplane11 to get the serial key (Regcode) ???
El Gringo
45
Here :
http://jardesign.org/a320-serial-update-step-13/
46 (edited by sulstore 2017-02-19 21:59:53)
I had 2 problems:
1º When the X-Plane showed in the upper right corner that there was punctured tire, but in the ecam the tire was still full.
2 Even though I did not send a flight plan for X-Life, I wanted to know what would happen when I clicked on report TOD and because of my surprise the x plane closed.
47 (edited by YYZ342 2017-02-19 22:25:54)
First attempt with XP beta version on XP11pb11.
Few issues:
- Liveries downloaded from JAR forum do not switch; thumbs do not generate correctly. Generated thumbs placed in the livery folders are the same stock A320 Neo livery. Seems aircraft does not "see" liveries folders, except Lufthansa it came with, : D:\X-Plane 11\Aircraft\320_JARDesign\liveries. I have two other 3rd party airplanes, CRJ 200 and Epic 1000 v.2, both switch liveries and generated thumbs OK.
- Parking brake release will disconnect and remove ground power and remove fuel truck; aircraft will go cold and dark if was powered up
- If parking brake was released before connecting ground power and/or calling the fuel truck it is no longer possible to connect the ground power or call the fuel truck; other options like doors, stairs are working
- Switching airport while A320 is loaded will remove parking brake when aircraft loads at the new airport, thereby making it impossible to call the ground power or the fuel truck
- XP11 weight/balance/fuel menu shows single fuel tank
Log attached.
I7-5820K 4GHZ (OC) | GTX1070 8GB | 32GB DDR4 | 512GB SSD Samsung 950 PRO .M2 x4 | MSI X99S SLI PLUS | WIN10 x64 PRO
"If only I could stop flying toy air planes..."
48
---------------Tried a ton of them all working fine here
---------- see this also but doesnt do it all the time - weird
49
Pls point me to one of the liveries that worked for you.
Thnx
Cheers
50
http://forums.x-plane.org/index.php?/fi … s-a320neo/
I have many more that all work - I would assume you know where to place them
