276
Thank Eugeny for this new version 2.0b5
Will try soon
277
Just tried b5, found a couple of issues. On takeoff not getting the instruction to reduce to climb power and AP not managing speed. It just holds at 250 knts even though it was above 10000 ft.
I will reload it and try again.
278
Ok, thanks for comments!
a330 beta 5 is out:
+ APU fuel cons. fixed
+ Tow crash fixed
+ COM radio freq tuning fixed
+ cockpit light fixed
+ minor bugs fixed
As we expect, the correct engines work will be broken with next XP11 beta, cause of Laminars want rework some inside XP11 code. So, will see and fix if need
Thanks Eugeny!  Gonna make some time to test this one out smile
OK, now I need to RANT!
............when new people come to the forum, some people that have been here for awhile (even less than me!) really pounce on these poor fellows looking for help in order to HELP US! It is very disconcerting as well as RUDE, and I don't blame anyone for getting hot under the collar when some idiot thinks he is king of the hill. The only King here is Eugeny and his crew.
We are all equal, no one else is the BOSS. Treat people the  way YOU want to be treated.  I did not see any disrespect from one of the posters here, but some idiot needs to pounce on the poor kid. Not naming names and will not be entertaining any more convo on this.
THIS HAS TO STOP!!!!!!
Rude people not only chase others away, but make all of us look bad. And that in turn would make a potential customer say byebye, I'll buy elsewhere.
It's time the very few people here get their act together and treat people like you want to be treated.  LET'S ALL BE HELPFUL, NOT HARMFUL
++++++END OF RANT+++++++ ++++++++++++++ END OF CONVERSATION
279
Thank you for your update, hope, that laminar will develop xp11 so far, that you doesn^t work behind them :-)
Your aircraft isn`t the only type who have some problems on xp11 at the moment. But my last flight with a330 went without important bugs. only the replay issue came back.( engines went to full power after stopping the replay mode)
I will test beta 5 soon.
thank you and
regards
Volker
280 (edited by Sloboda 2017-02-08 01:08:58)
Hello Eugeny,
that's new ?
I have the plan on the map but IRS not aligned.
is it normal ?
http://jardesign.org/forum/img/m/1506/t/p1b8dk3v0kugb16ko1m3t1d7m16vo3.jpg
281
Hello Eugeny,
that's new ?
is it normal ?
This not normal for real AB, but this is model simplification.
282
I've tried beta 5 with the exact same results. No instruction to reduce to climb power and auto throttle not working properly. Also noted that my climb rate was above 4000 fpm until it reached FL400 at a speed of 250 knots. Aborted flight and went back to beta 4.
Thanks for the update.
283
Ohhhh! You are right, but i am stupid. Sure, this work wrong with beta 5, sorry. Rebuild and post beta 6 cause of this.
+ SPEED mode unstable fixed
+ LVR CLB flash fixed
+ vertical profile improved
284
Thank You Mr. Romanov. Looking forward to trying this out again.
Hervé
285 (edited by Sloboda 2017-02-09 07:15:40)
It ask me to contact support for bug SASL just after i type DIKOL and paste it on LFPO.
286 (edited by hdespres 2017-02-09 12:23:40)
CYUL/CYYZ flight went as it should reference previous troubles. Thank You. Short video is included... as I have a "HYD ELEC PUMP" warning on center ecam. This was also seen on beta 4. This was intermitent and mostly on approach phase.
Short Youtube video link also included here... problem is seen at 2:10 mins on video. I have no failures set up.
https://youtu.be/YHhs7rZ1XOE
Cheers
287
I can confirm Speed mode working well even in bad weather were it used to surge up and down. I do get HYD ELEC PUMP warning but only on approach intermittently.
i5 4670K @ 4.6Ghz, 16GB Crucial Ballistix Sport VLP, ASUS GTX 760, H80i Cooler & 3 SSD's
288
Hello Eugeny,
since v2b, a330 not place correctly at autogate.
It always enter in buildings.
289
Hello Guys,
I´ve two problems:
First problem: I´m on the ground and the PFD shows me a altitude of -8800ft.
Second problem: When I give a little bit thrust, the PFD shows me after 5 seconds 300knt+ indicated and I´m very fast airborne - not flyable. The Secondary Flight display shows me the correctly ground speed.
My system:
Mac OS X 10.12.3
A330 V2.0b6 - X-Plane 11 pb10
Saitek X52
Greets Max
X-Plane 10&11 @ iMac 27" (late 2013)  Intel i7 4771 @ 3,5Ghz (Turbo-Boost 3,9Ghz); Nvidia Geforce GTX780M 4Gb VRAM; 24Gb DDR3 RAM; 1TB Fusion Drive / Saitek X52 & CH Yoke // A320&A330 by JarDesign / B757,767,777 by Flightfactor/ IXEG B737-300/ B747-8,Embraer 190LR by SSG / CRJ200 by JRollen / PC12, CT206H, PA34 Seneca II by Carenado // Navigraph Ultimate Subscription // Vatsim ATCo & Pilot(1000h+)
290
Hi Eugeny
Just as information:
With Windows 10 and
      X-Plane v11 b9 and A330 v2.05 everything worked fine ...
      X-Plane v11 b10 and A330 v2.05 it becomes impossible to adjust QNH with the knob ...(no effect)
      X-Plane v11 b10 and A330 v2.06  no possible QNH adjustment (this means also no possibility to talk with X-life ATC ) and , surprise : a "nice" pink color around the winscreen ...
       Also A330 has desappeared in pluggins menu ...so it is not possible to close the doors ...
As I have just downloaded and XP b10 and A330 v2.06 at the same time I cannot tell where problems are from ...
Here is log.txt for last try .
Hi Eugeny
With Windows 10 and
Hi again
After many starts of X-Plane 11 b10  I confirm knobs don't work (QNH , speed, flight level ...
so no possibility to fly ...
(The "nice" pink color seems to have desappeared definitively )
No A330 in pluggins menu ... so doors remain open ...
292 (edited by hdespres 2017-02-12 00:59:20)
Strange you are having these problem. In flight now and no issue so far... will update this post when flight complete.
Flight went well... no problems other that the star... aircraft turn wrong way... but we recovered and landed into CYHZ... Love the new scenery there.  Cheers
293
m.kunz0108 wrote:
Hello Guys,
I´ve two problems:
My system:
Mac OS X 10.12.3
Saitek X52
Greets Max
To your first problem: I think that your QNH was wrong? (see if  airport altitude is the same as on PFD...)
Second problem: maybe you have to calibrate your thrust levers (Saitek?) probably they went to TOGA ..  Weird...
294
sorry if this was already answered or not. during cruise flight FL380 the aircraft surges +/- 200fpm, it never stays level. Is this a bug in the plane or xp11? Other A/C I have dont do this. I can live with it but its annoying hearing the engines rev up and down the entire flight. Thx
295
Hi Eugeny
With Windows 10 and
Hi again
From your log:
Fetching plugins for D:\Desktop/X-Plane 11/Aircraft/Aircrafts/330_JARDesign/plugins
D:\Desktop/X-Plane 11/Aircraft/Aircrafts/330_JARDesign/plugins/330/win.xpl : Error Code = 1114 : Une routine díinitialisation díune bibliothËque de liens dynamiques (DLL) a ÈchouÈ.
D:\Desktop/X-Plane 11/Aircraft/Aircrafts/330_JARDesign/plugins/diagnost/win.xpl : Error Code = 1114 : Une routine díinitialisation díune bibliothËque de liens dynamiques (DLL) a ÈchouÈ.
[SASL] Starting...
X-Plane scriptable avionics library plugin snapshot 2.4.22 20170206 Commercial Edition
Loaded: D:\Desktop/X-Plane 11/Aircraft/Aircrafts/330_JARDesign/plugins/sasl/64/win.xpl (1-sim.sasl).
D:\Desktop/X-Plane 11/Aircraft/Aircrafts/330_JARDesign/plugins/sound1d/win.xpl : Error Code = 1114 : Une routine díinitialisation díune bibliothËque de liens dynamiques (DLL) a ÈchouÈ.
D:\Desktop/X-Plane 11/Aircraft/Aircrafts/330_JARDesign/plugins/sound2d/win.xpl : Error Code = 1114 : Une routine díinitialisation díune bibliothËque de liens dynamiques (DLL) a ÈchouÈ.
D:\Desktop/X-Plane 11/Aircraft/Aircrafts/330_JARDesign/plugins/sound3d/win.xpl : Error Code = 1114 : Une routine díinitialisation díune bibliothËque de liens dynamiques (DLL) a ÈchouÈ.
[SASL] Path to panel: D:\Desktop\X-Plane 11\Aircraft\Aircrafts\330_JARDesign\aircraft.key
You can open youtube and search like "windows 10 error 1114" to read about solution. The problem is wrong power settings for videocard.
296
Hi Eugeny
With Windows 10 and
Hi again
From your log:
[SASL] Starting...
Hi Eugeny
Thanks for your quick answer .
I am a bit surprised but I am going to investigate according to your suggestion ...
As i see automatic rollout is not stable now, cause some was changed in XP11. So, i work on it and this will be fixed with next a330 beta.
298
Hi Eugeny
Following post 296 ...
I found info about error 1114 on internet (web is confusing ...) but in the meantime I have downloaded a new XP 11 beta ...
and ...
A330 works fine again ...(A330 is back in plugins menu, knobs operational ...)
I noticed that "burnt gases" behind reactors have desappeared ...
Thanks for help
299 (edited by siege00 2017-02-13 03:40:27)
Good evening and thank you for such a great product and access to the beta.  I haven't read through all of the pages of comments but wanted to post my observations.
I just flew an afternoon to evening flight from KCOS to KLAX and observed the following:
1. Flt Plan does not automatically scroll when passing waypoints.  This may be by design.
2. I could not enter heading mode while on the ground for preflight.  While airborne I was able to select heading mode.
3. Heading bug on ND did not render while in managed mode to allow for pre-selecting a heading before selecting heading mode.
4. Decelerate did not indicate on the PFD when passing T/D. (it's possible that I may have missed it by looking in the wrong place)
5. In descent phase, the CAB PRESS page of the ECAM did not render correctly.  No needles were shown on the digital gauges.
6. At night, the ECAM page select buttons were not illuminated with the rest of the panels. (Did I miss a knob?)
7. Constraints did not print on the ND when selected.  Not sure if this is planned for/implemented or not.
8. Altimeter wouldn't display 30.08.  It displayed 30.09 twice however, Example: 30.07 -> 30.09 -> 30.09 -> 30.10.  Maybe a conversion issue from hPA to inHG.
The plane flew a great VNAV profile and AUTOLAND worked like a charm except for the rollout, which I saw the comment above.
Thanks again!  I have to say that I love this plane!
Edited to attach log.zip
300
Hello everyone,
Just a question. This update is only for X-Plane 11?. Or can I update my A330 on X-Plane 10 with it as well?
Thank you in advance
Javier
