EmmaBentley wrote:Is anyone having issue with the Tiller and Nose Wheel ? , for some reason it seems locked and cant move ? ...
XP10.51 - No (NWS can be disconnected via button assignments even though there is no option in the cockpit. I had that assigned to a button once and it gave me grief)
XP11pb3 - Yes, had that originally. Needs calibrating a lot and making sure lua config file is correct (it needs each axis defined twice; initial assignments.txt shows the correct setting after proper calibration)
