rsvette12 wrote:
No reason Blue Sky would not work its just a sound replacement
No they use plug for sounds settings over the mcdu
Yet completely useless to me.
1.) Autopilot does not turn on
2.) While attempting to DIRECT, devices and displays crazy(freezes). FPS dropped to a minimum and simulator stutters.
3.) The Displays are often illegible due to lighting.
4.) During takeoff-strange sharp jumping camera and plane was poorly controlled.
5.) Airbus engines react immediately. In reality, the engines have a delayed reaction.
X-Plane 11b3, I7 4970K 4.5Ghz, GTX 1070 8GB vram, 16GB RAM, Windows 10 x64
Sorry for my bad english
53
Just one minor visual detail, engines seem empty smile
I just found that Xplane crashes, if Xenviro is on, with this beta, as soon as you try to change anything in A330 settings menu
Same here, do u use Xenviro?
No, Skymaxx
Correction
BSS sound plugin pack 2.01( mac version ) work correctly .
58
on my initial climb out of CYVR with this error. the MCDU wasnt going to the next waypoint. so i pressed direct and the plane went into a very lag like state, with very low FPS
59 (edited by WoDi 2016-12-31 10:24:31)
After take off I have problems with SASL (XP 11b3). I can´t use LNAV, only HDG.
log.txt: [SASL ERROR] Error updating avionics: [string "u//mcdu_fpln.sec"]:0: attempt to index a nil value
Some minutes later: [SASL ERROR] Error updating avionics: not enough memory
regards
So.. we still wait new XP11 public beta where navigation and some other issues will be (we expect) fixed and allow us to prepare more stable prerelease version.
61
Okay, I´m still waiting ...
A happy new year and all the best for you.
Dieter
Is anyone having issue with the Tiller and Nose Wheel ? , for some reason it seems locked and cant move ? ...
Emma Bentley
Apple Mac Studio M2 Max , 38 Core GPU
XP10.51 - No (NWS can be disconnected via button assignments even though there is no option in the cockpit. I had that assigned to a button once and it gave me grief)
XP11pb3 - Yes, had that originally. Needs calibrating a lot and making sure lua config file is correct (it needs each axis defined twice; initial assignments.txt shows the correct setting after proper calibration)
64
Appreciated!! yikes smile
@J.A.Romanov
Just did a flight on the new XP 11 PB5 ,
The plane is following the flight plan , Happy days
No we can Fix other related issues  . When Entering the DH any height still shows 200 on PFD
Lawrence
I purchase the a330 upgrade for xp11 but didn't receive any serial, i am afraid my bank account has been debited, its been 24 hours since i'm waiting for a confirmation from paypal but to no avail.  Please help
67
Write a ticket direct to Eugeny:
http://www.jardesign.org/ticket/kb/index.php
68
does the blueskystar sound pack work with someone?
Yes
no problem for me with BSS
I did a flight between FACT to FAPE , XP 11 PB5
1. Engines are see through from the front
2. The STAR is drawn incorrectly , Navigraph 1701  Flight Plan OKTE1C OKTED UQ12 XUGOL UQ56 OKSET DCT PEV DCT " PEV1 " transition for RWY 08
As you see on the Flight log the aircraft tried to fly it correctly ,  : )
3. Still cant enter any DH above 200 , as it always shows 200 on PFD
4. There was an Issue with after lading at gate the engines would no shutdown , had to switch fuel pupms of the kill engines ..
71
Ok, today we get new beta and it is better. So, i spend day with a330 testing and rework again. Also, i just rebuild Ground Handling plugin (may download from http://handling.jardesign.org) to avoid red a330 message of GHD incompatible. Will continue to prepare new a330 version soon. Thanks for your reports!
72
Is available new ground handling version? (070117) The link you provide, at "download" is broken.
Waiting 2.0b2 a330! smile
Cheers.
73
I do not understand anything ... ...the  new beta versions of the A330 and 320 which will be available on the forum won't be compatible with x-plane 10?? Yes or no?
74
Cheers.
Just test - download work well.
If aircraft was saved in XP11 PlaneMaker - it cant be compatible with XP10, XP10 cant read it.
