151
volvic wrote:
There is no terrain then TERR ON ND on. Where is a problem? XP 10.
http://jardesign.org/forum/img/m/1829/t/p1b470pj151pfj1nm61mk319h0lje3.jpg
What do you expect to see, a grey mouse running under the plane? Start flying and then activate terrain......
152 (edited by Nicco54 2016-12-18 14:26:13)
Volvic is right, there is a problem. Firstly terrain on ND should not make the ARC, let alone any info that was on the ND before activating it disappear. The display never goes black.
Secondly you activate it BEFORE takeoff, not after, so telling him to "start flying and then activate terrain" is wrong.
If you don't actually know how the aircraft's systems function either, don't bother replying to others just asking for help with a rude message.
This appears to be a bug, but I never had it before, mine always worked correctly.
153
We discussed about is a lot. There is no need to repeat same things thousand times. One must read the whole thread and see if he is contributing a new occurrence  as a beta tester. Because it doesn't happened the beta test is degrading to a personal questioning site, coming especially from new users. That is not the information we need. If you for example were looking after my contributions from day one, you had got an idea about my experience.  Have a look at this address, maybe you learn something...
http://ilankrt1.blogspot.co.il
154
Hi Guys,
I have a question regarding the MCDU.
I visitied lot of pages, but I didn't find the answer.
How can I set a waypoint as an over-fly in MCDU? Is it a supported feature? If not then is there any workaround?
Daniel
155
Hey Daniel,
if I remember correctly the overfly function is not implemented at the moment. I don't know if JARdesign plans to implement it at some point, but I sure hope they do as it is an essential feature.
The only way around it is to do it manually. Select HDG mode, overfly the waypoint that way, and once passed it re-select NAV mode.
156
I would like to see more weather on the mfd with a radar movement too. Plus, has the Facebook site been taken down?
157
What is the latest version of JarDesign A320? Is it V2.7 R1?
158 (edited by slar164 2016-12-22 06:24:49)
Hi, anybody has this phenomenon: when I desactivate APPR Mode, at the same time VVI button is pulling up?
Is it normally?
159
yes
160
Thanks Nicco54!
161
Appears that there is a typo on the A320neo Updates page. The update is listed as version 2.7r2 but the link downloads version 2.7r1.
http://airbus320neo.com/updates/
Attachment icon Screen Shot 2016-12-25 at 10.48.54 AM.png 43.53 kb, 162 downloads since 2016-12-25
162 (edited by Sloboda 2016-12-25 16:21:00)
There's not any problem, download with the link. After install, you will see the good version wright in your cockpit.
But i have not ear anything about a v2.7r2
163
Greetings and happy holidays to all.
Is there any news of new updates or some progress? It seems that this updates has been a little stopped since the V2.7R1 came out ...
Once again I wish you happy holidays and that all your wishes will be fulfilled in 2017.
164
Dear J A Romanov PLEASE can you insert the 3d pilots of the 330 in the 320neo?
We, the customers, dont want fly any aircraft with EMPTY cockpit
Well if you can, integrate it. Thank you
165
Any news?
166
Can anyone explain how come I am getting unable to crz alt error ?
I am doing flight KSAN - KSFO I want to flt FL370 but it only takes FL 170 all above with it give me an error .
167
May be the crz level 370 you want to fly is too high and distance between KSAN and KSFO too short .
In that case the Aircraft cannot reach TC (top of climb) because it reaches TOD before ...and this is not possible .
But with FL170 this is correct ...
168 (edited by dron420 2017-01-02 11:26:33)
zoomm69 wrote:
Здравствуйте, у вас сейчас есть скидки на а320 нео?
Да - смотрите http://jardesign.org/2014/11/09/for-rus … ing-users/
169
And again a problem present since last versions: when you are in rainy conditions and you don't set the ignition selector in the right position as you call the "before takeoff checklist" starts a sound loop "engine mode selector" impossible to stop and you I have to abort flight. Can anyone try this?
170
Я очень сомневаюсь в этом, мы все еще ждем для достойного обновления, который, кажется, принимает навсегда
171
Hello, I find it impossible to set the range knob to 320 nm, I am only able to set it up to 160. This is using A320 v 2.6R2
172
AP disconnect .
after reaching cruise level, plane is  overspeeding to .84 and AP disconnects ,I can slow down and reengage AP but it would it overspeed again and disconnect all the time.
Any suggestion why ?
173
maxikk wrote:
AP disconnect .
I'm thinking your auto throttle is not on...
174
Hi everyone,
Congratulations for the A320/330.
Is it planned to realize an A321 in future in JardDesign group please ?
jcmic
175
hdespres wrote:
maxikk wrote:
AP disconnect .
No, auto throttle was on.
I am not ever sure how can it cruise at .81 or even .84 per  per wikipedia cruise speed is .78.
