pic wrote:
Thanks all your comments and reports! We wait next XP11 beta to test our beta-2. Hope (and test this with developers version) we will see some bug-fix inside simulator.
Hi Eugene, Trying to activate..sent a ticket
Thanks a ton!
Luigi
Luigi, Done, please use.
Got it! Thank you.......Now, I put it into xp11.3, was able to do a complete fms input flight, perfs..then before taking off, I changed the 330 settings for no fps message, then re-opened 33o settings and sim froze, ctd.  I noticed another thing. After entering serial number then reg Ground plug, the sim froze and then I had to force a ctd. Anyway, for the first item, I attached my log, bb
Thanks a ton!
Luigi
Got the 330 flying, but right after takeoff and getting prepared to climb out, went to single frame/maybe 10-12 after.  Tried taking out smp, head shake to no avail. Then took out goflight plug, after putting back in, ctd.
FMS works great, plane looks and sounds super..just gotta iron out these few bugs and we are set!  Files attached
impossible to activate
thanks for your job
Bon courage
30
Framerate in XP-11 is bad regardless of aircraft used. They are still optimizing code at this stage.
yea, that last xplane 11 update is killing frame rates!
Yes, It is the FMC that caused the Framerate drops. Is it possible to upload the Beta 2 for us, the users only need to change the x-plane.exe back to beta 2 and the problemes are gone wink
So.. Just install XP11 pb3. No old my code, no my reworked code not work well with pb3. Reworked code work well now with pb2. With pb3 - not work. I dont know exactly what a reason, but seems like after passing next point, XPLMGetDestinationFMSEntry back me to prev point. Seems like when i set XPLMSetDestinationFMSEntry instant FMS not mark prev points as "passed". But this is my guess only. My fact - not work. So, XP11 is megabuggy now.
The main issue - instant FMS not work correct with actual waypoint. So, just report this to Ben and Phillip. Wait..
Confirmed. Just tried a flight with pb3 and it was a disaster. All went well until TO. Then the FMS went ape....  It flew right by the first WP, after a Direct it started flashing and FPS went down the drain...  Well, it's a beta. Let's hope pb4 is better!
I have found a bug in XPL 11 with Ground Handling 051216. If you reload an aircraft or if you change from an aircraft to an other the plugin menu shows twice or more depends on how many times you have reloaded.
http://prntscr.com/dml2ey
Ok, good news! I just get developers version of XP11 beta from Laminars and.. a330 flying route well now. They are fixed some. So, we need wait next public beta to test next  a330 beta.
36
Very well... Thank You.
37
GREAT! Looking forward to it smile
is the new version 2.0 also going to work at xp10 or only xp11
This is excellent news! I have the a320neo. I am getting much better frame rates overall in xp11. I will purchase the a330 and happy to beta test!
40
I have acquired the beta for xp11.
After about 5 hours of flying this magnificent bird I am having the following problem:
When AP is activated the plane starts to follow the flight plan.
After a few seconds, a red SASL error message blinks on the display.
It is hard to read the complete message, however, the initial part says SASL error, some problem with activation....
After the error, the plane stops following the FMS and the only way to follow the plan is by activating HDG or manual flying...
Happy holidays!
41
Hi:
Is it ok to buy at simmarket and use it in XP11 PB3 - I know A330 is not stable but would prefer to use it in PB3 - want to check it out nothing serious - understand its a wip - thank you
Regards, Rich
Need wait PB4, i get info from Laminars today what needed changes will be included.
Happy holidays!
Same problem, i have a red text flash when i want enter a SID
44
Thank you looks like a great product smile Happy Holidays
45
Hi couldnt wait bought A330 from simmarket but cant activate it in XP11 PB2 or PB3 - any help would be appreciated - is it possible to remove vc pilots - thank you
Well I didn't know it downloaded a key file automatically into my downloads folder happen to see it there put it in main A330 folder all went well - pilots are gone also nice  smile
i just paid for the upgrade from x-plane 10 to x-plane 11, says it takes 18-24 hours for my key. i assume it's because of the holiday.
48
Sorry if I have missed this but does the Blue Sky Star sound pack work with this beta version thank you.
49
No reason Blue Sky would not work its just a sound replacement
50 (edited by kebs 2016-12-25 15:26:00)
BSS sound doesn't work, I tried it ( Mac Version )
