Re: X-Life ver 1.1 (r1, ++)
Thank you Kyuu113.
I was as crazy find this...
Ggretings
JARDesign Group Board → Updates & General Discussion → X-Life ver 1.1 (r1, ++)
Thank you Kyuu113.
Ggretings
Hi, Someone know if X-plane 11 work with X-life??
My x-plane 11 crash when try it.
Just completed a flight from KBOS to KEWR in the A320 with XP11 and X-Life. Both worked. The A320 has some issues that will be rectified when XP11 is stable, I'm sure.
Read the forums to figure out what you need to do to make it work if you want to play with it now.
For one, you need to put your GNS430 folder from XP10 into the XP11 Custom Data folder...
Oooohhh,
I will try to put folder GNS430 in Custom data Foder...
I hope it works.
Thanks laohu314!!
No work....
I will be trying...
"Read the forums to figure out what you need to do to make it work if you want to play with it now."
Laohu, no find the info...
CAn you help me??
CAn you help me??
Please attach your log.txt and any other log files you have in your XP11 folder (FWL, JAR etc). I'll have a look and if I find something I may be able to help. No guarantee.
Unless you are an experienced XP10 and JAR aircraft user I would highly recommend you wait for XP11 to be stable and out of beta and for JAR Design to provide an updated version for XP11
From time to time I used to made a video of my test flights:
EETN - EYVI
A320 v.2.7
XL v.1.1r6
iMac Retina 5K, 27-inch, 4 GHz Intel Core i7, 32 GB 1867 MHz DDR3, AMD Radeon R9 M395X 4096 MB, year 2016
FPS 27, rendering high
without any occurrences
Hi Laohu314.
Copy and paste the last lines of my log.txt
Thanks!!
0:01:33.469 I/SCN: DSF load time: 938846 for file Custom Scenery/0España-LESS/Earth nav data/+40-010/+40-003.dsf (0 tris)
0:01:33.469 I/SCN: DSF load time: 132835 for file Custom Scenery/2España-toros/Earth nav data/+40-010/+40-003.dsf (0 tris)
0:01:33.469 I/SCN: DSF load time: 238947 for file Custom Scenery/3zzz_Treelines_Farms_Europe_v2/Earth nav data/+40-010/+40-003.dsf (0 tris)
0:01:33.469 I/SCN: DSF load time: 15975890 for file Custom Scenery/0España-LEVD_Villanubla/Earth nav data/+40-010/+41-005.dsf (0 tris)
0:01:33.469 I/SCN: DSF load time: 61765 for file Custom Scenery/2España-Puntos VFR EVA 4.3.2/Earth nav data/+40-010/+41-005.dsf (0 tris)
0:01:33.469 I/SCN: DSF load time: 969728 for file Custom Scenery/3zzz_Treelines_Farms_Europe_v2/Earth nav data/+40-010/+41-005.dsf (0 tris)
0:01:33.469 I/SCN: DSF load time: 39123 for file Custom Scenery/Global Airports/Earth nav data/+40-010/+41-005.dsf (0 tris)
0:01:33.469 I/SCN: DSF load time: 58613 for file Custom Scenery/Texture-AHS_PuntosNotificacion/Earth nav data/+40-010/+41-005.dsf (0 tris)
0:01:33.469 I/SCN: DSF load time: 32154917 for file Custom Scenery/z_SpainUHD_+40-003/Earth nav data/+40-010/+40-003.dsf (1560226 tris)
0:01:33.469 I/SCN: DSF load time: 41475678 for file Custom Scenery/z_SpainUHD_+39-005/Earth nav data/+30-010/+39-005.dsf (1505877 tris)
0:01:33.469 I/SCN: DSF load time: 28845872 for file Custom Scenery/z_SpainUHD_+41-005/Earth nav data/+40-010/+41-005.dsf (1501588 tris)
0:01:33.469 I/SCN: DSF load time: 16331 for file Custom Scenery/0España-Campos Eventuales/Earth nav data/+40-010/+40-005.dsf (0 tris)
0:01:33.469 E/SCN: Failed to find resource 'redhangerconcrete.png', referenced from file 'Custom Scenery/0España-Fuentemilanos/objects/'.
0:01:33.469 E/SCN: Failed to find resource 'frequency.png', referenced from file 'Custom Scenery/0España-Fuentemilanos/objects/'.
0:01:33.469 I/SCN: DSF load time: 247107 for file Custom Scenery/0España-Fuentemilanos/Earth nav data/+40-010/+40-005.dsf (0 tris)
0:01:33.469 I/SCN: DSF load time: 594990 for file Custom Scenery/0España-LEMT-Casarrubios/Earth nav data/+40-010/+40-005.dsf (0 tris)
0:01:33.469 I/SCN: DSF load time: 22950 for file Custom Scenery/2España-toros/Earth nav data/+40-010/+40-005.dsf (0 tris)
0:01:33.469 I/SCN: DSF load time: 40164 for file Custom Scenery/3zzz_Treelines_Farms_Europe_v2/Earth nav data/+40-010/+40-005.dsf (0 tris)
0:01:33.469 I/SCN: DSF load time: 19711 for file Custom Scenery/Global Airports/Earth nav data/+40-010/+40-005.dsf (0 tris)
0:01:33.469 I/SCN: DSF load time: 6299301 for file Custom Scenery/z_SpainUHD_+40-005/Earth nav data/+40-010/+40-005.dsf (1515483 tris)
[33m2016/12/05 09:43:28 [1] Un-muting new cockpit sounds[37m
0:05:23.978 E/ACF: Failed to open the aircraft file Aircraft/Payware X-plane 10/Carenado C337 Skymaster v2/Car_C337.acf, probably because it was created by a version of X-Plane that is too old.
0:05:23.978 E/ACF: Failed to open the aircraft file Aircraft/Payware X-plane 10/Carenado C90 King Air v1.1/Car_C90.acf, probably because it was created by a version of X-Plane that is too old.
0:05:23.978 E/ACF: Failed to open the aircraft file Aircraft/Payware X-plane 10/Carenado Mooney M20J v2.1/Mooney_M20J.acf, probably because it was created by a version of X-Plane that is too old.
0:05:23.978 E/ACF: Failed to open the aircraft file Aircraft/X-Aviation/Bombardier CRJ-200/Users Modifications/CRJ without Cabin Pilots and GPU/CRJ200.acf, probably because it was created by a version of X-Plane that is too old.
[31m2016/12/05 09:43:29 [2] Uh oh, cannot load sound '060_obj_release' because alGenSources says there's a problem: Unknown error.[37m
G64: 324.166: Trigger: Run('OnBoot')
SkyMaxx Pro: METAR parser enabled
SMPMetarBridge: METAR activation fired.
XL: 0 : JARDesign plugin: /Users/marcpalencia/Desktop/X-Plane 11/Resources/plugins/X-Life/News/news.txt file updated.
XL: 0 : MessageGreen: X-Life Traffic by JARDesign Ver.1.1r6 061116
SkyMaxx Pro: Activating METAR parsing.
SkyMaxx Pro: Found new METAR.rwx file
SkyMaxx Pro: Parsing METAR data
SkyMaxx Pro: METAR parsing took 3855 ms.
SkyMaxx Pro: WARNING! CPU free memory at 26200 KB. X-Plane may crash due to lack of memory. Close other applications, reset your settings, or remove memory-intensive add-ons such as photo-scenery.
0:09:30.652 I/ATC: Airport flow changed at LETI!
CurFlow: AUTOGEN: North NewFlow: AUTOGEN: East
0:09:30.652 I/ATC: Changing LETI CabState from 0 to 1
0:09:30.652 I/ATC: All departures are done at LETI. Advancing...
0:09:30.652 I/ATC: Changing LETI CabState from 1 to 2
0:09:30.652 I/ATC: All arrivals are done at LETI. Advancing...
0:09:30.652 I/ATC: Changing LETI CabState from 2 to 0
XL: 0 : Bluebell XL library find: /Users/marcpalencia/Desktop/X-Plane 11/Custom Data/Bluebell XL/
XL: 0 : !!! Error: Cant read file /Users/marcpalencia/Desktop/X-Plane 11/Resources/GNS430/navdata/airports.txt
XL: 0 : !!! Error: Cant read Ats file
Hi Laohu314.
Copy and paste the last lines of my log.txtThanks!!
I would really need all of the log file, and please attach it rather than pasting it in. You can do that when you edit your post.
From what I see, the error might be related to Navdata. Do you have the GNS430 folder in the Custom Data folder?
Well, in addition to many other problems, the one that is most likely to cause XL to quit is the fact that you don't have any navigation data in your navdata folder. They absolutely need to be there!
Sorry for my question , but...
Where are the "navigation data"?? In X-plane 10 I do not remember having to do anything
Tnaks!!
I found it!!
My folder with navdata it was in "resources/ plugins/ GSN430.
Copy the folder in X-plan 11 and work perfecti!!!!!
Thank you very muuch!!
I hope I hepl to others users...
Hi, Tugmaster, FM Car and X-Life all seem to be working for me in X-Plane 11, the only very small point I've noticed is that landing lights and turnoff lights do not seem to be working on approaching aircraft. I'm using the BluebellXL aircraft pack.
X-Plane 11 is still early beta so I'm sure it will be sorted out at some point.
Xplane 11 crashes every time i open Xlife
For me to but a reinstall solved it ![]()
Hello Jar! I have 2 questions: 1) how to change the voice of a flight dispatcher?; 2) how to edit traffic x-life deluxe? For example, I would like to see at the airport USSS airline Ural Airlines, UTA, SBI, AFL TSO and the desired aircraft. Is this possible?
It happened often that when my aircraft is on taxiway (mostly guided by FM car) other AI aircrafts coming from opposite are steering to the same taxiway. In best case they stop in front of my aircraft but mostly they are continuing to roll through it.
Is there a way to program an instruction for AI aircrafts to avoid a taxiway if my aircraft is rolling on it, and if there is no alternative taxiway for them to stop immediately where they are before entering the occupied taxiway?
Yes I just downloaded xlife for the first time today and followed the instructions posted. I'm unable to get it to show up in the plugins. I have opensceneryx and using ksan airport. My operating systems windows 10 and X-plane 10 updated
Please help me figure this out
Marvin Brooks
in tools, AI ACF editor totally CTD for me...
Is it the same for you ?
Dear Jar
First of all, thanks for your great work, I own ALL your products!
Since you said that you were taking comments for future debugging, I was wondering if anyone has had the same bug as me with Tugmaster Deluxe and X-Plane 11: when I start the Tugmaster deluxe in the plugins menu, I immediately lose the the sound for ATC (I am talking about the default XPlane ATC) ???
Been using this for a while and it's been good. I'm using the free version so far and I was wondering if this will show planes in the sky as I am flying or is this plugin just shown at airports.
Is copying the NAV folder the only thing we have to do to make X-life work for XP11 PB3? Love the program.
x-life crashed everytime when i start it in x-plane 11.what can i do??
in the Attachments are my Log.Text
cheers
cheers
XL: 0 : OpenSceneryXpath find: C:\x-plane11\X-Plane 11\/Custom Scenery/OpenSceneryX/
XL: 0 : !!! Error: Cant read file C:\x-plane11\X-Plane 11\/Resources/GNS430/navdata/airports.txt
XL: 295 : X-Life plugin ver.1.1r6 061116 detect crash.
If you still got X-plane-10 Installed Go into Resources folder, Copy folder GNS430 and paste into X-plane 11's Resources folder. This should solve your problem.
Please read the forums people already mentioned about this. Thank you.
