Re: a320neo JARDesign ver 2.7r1 WIN/MAC 64 bit (X-Plane 10)
During the night, the display lights on the switches lose their brightness.
When the light of day everything works ok
tks
JARDesign Group Board → Download, Updates → a320neo JARDesign ver 2.7r1 WIN/MAC 64 bit (X-Plane 10)
tks
If you need to change the SID in the FMS or pick the wrong one you can't reselect a new one. It stays stuck on the one you've already selected it. Bug?
Nonsense! I just made a flight (EYVI/EDDC) and at destination airport the wind changes so I decided to land instead of RWY 04 on RWY 22. For doing this I programed STAR for new on FMCU during flight just before descending (TOD)..... No problem at all !
When the light of day everything works oktks
Do you want blinding pilots, so they cannot see e.g. the RWY?! ...
Anyone found success with the A320 with XPlane 11? Having issues using the flight computer and the Navigraph data. As far as I can tell the data is not being read at all... Can't even seem to locate the airports, error I've been getting is "arr/dep apt not found" Might just need to wait for an update unless I'm missing something.
LR changed the format of the navdata , you may check the ORG forum and you find a soultion for your problem.
jetherjr wrote:During the night, the display lights on the switches lose their brightness.
The indicator lights on the buttons do not work as they should.
I had problems with the screen that was gradually lose until it was completely black, at click shit F4 and then clicking "w" on the screen backs on, but repeats the process
ilankrt wrote:jetherjr wrote:During the night, the display lights on the switches lose their brightness.
Are you using XP 11 Beta ?
Was just wondering when update will be available for xplane 11 as when at night there are no speed heading alt and v/s displays but in day its fine.
I see my A320 in XP11 as these pictures.
Generally spoken: Your information and some other complains concerning XP11 and JAR are useless!
There is a total lack of information.
Computer sort and configuration. Operating software...
JAR A320 version
XL version
XP 11 public beta (?)
The more information we get the more we can contribute from our own experience.
jetherjr wrote:ilankrt wrote:Do you want blinding pilots, so they cannot see e.g. the RWY?! ...
Yes this probleme is XP 11 Beta
I use the last version on XL and A320 V2.7b and XP11
ali.mazhari wrote:Hi,
I see my A320 in XP11 as these pictures.Generally spoken: Your information and some other complains concerning XP11 and JAR are useless!
There is a total lack of information.Computer sort and configuration. Operating software...
JAR A320 version
XL version
XP 11 public beta (?)The more information we get the more we can contribute from our own experience.
i have got problem with FMS, when i enter EDDH/EDDL (default FlightPlans), when i click CO-RTE i get this message "co-rte file not found". I have got Xplane 10 64bit, 10.51 last update and newes A320neo.
Thank you for respons
Adam
Adam
Hi.
You must enter EDDHEDDL, without "/".
Can't remember if this was a feature:
When I turn-off pressurization in-flight (green, yellow, blue pumps) there is no audible chime or master caution warning (if pressure < 1450psi). Autopilot will try to fly the aircraft but fail (which is correct) until the pumps are turned back on.
Might be an issue: with 2.7r1 "Ext. ground power" is not available after landing (nothing is happening when I click on the icon).
If you want to get a solution to your problem rather than just mentioning a factoid, upload your log.txt
Are you on Parking at this moment?
Did a leg today YBRM/YPXM, went to the apron, engines off, parking on (brake + a320 parking plugin "PARK") - then tried calling "GND PWR" and nothing happens (label not illuminated in green).
I have carefully registered the differences to JAR A320 model and found out that the "flightsimlabs" model not only contains everything the JAR model offers but also 25 additional important elements, which are worth to be integrated into the JAR model. These elements are therefore so important because they are included in the FCOM procedures for flight preparation, if you want to make the simulation as real as possible. The differences I will publish soon in my blog and open to the discussion.
http://ilankrt1.blogspot.co.il
On all cases I would like to ask you to watch this tutorial. As a matter of fact, the simulating real pilot did not find one procedure that was missing !!
I hope that as result we as JAR test pilots we will be able to develop a more realistic concept in our discussion
I just read your blog. You stated you would be willing to pay an additional ~$30 to the cost of this addon if it included the 25 features you see as missing. I can understand your desire to have a simulated Airbus that can be started according to the FCOM and have some FCOM associated button clicking, but I do not understand how this would improve the functionality (flight, navigation, systems administration) of the plane.
That is where I would have issue in paying an additional $30.
Having just puchased this as a recent transplant from FSX, I am still under some sticker shock when comparing the capability of the JarDesign with that of the Aerosoft A320. Jar needs to at least get the MCDU functionality up to spec, and the PFDs, before adding other features which, in my opinon, add nothing to the flyability of the aircraft.
I am actually surprised you did not mention the T.O. Check Button not working, as this is a serious safety feature that is missing. Also, the lack of speed constraints in the MCDU....
Hallo Scoochy
Yes I am willing to pay for implementing more functioning avionic systems. For example if we could have a simulated radar system on board, or a pressurization system would work and could be regulated, they will make the simulation more real. More real also during flight and navigations as for example you will see on weather radar a storms ahead that you want to avoid, or if you forget to activate pressurization you get in serious flight situation or even a deadly incident over 10000ft. This are only 2 examples and I can count a whole list...
The T/O button is indeed what I would like to have. But for now I am happy with JAR F.O. checklist before T/O (ECAM memo no blue). As pilot you should anyway check the data on screen. The MCDU must be developed more to the depth. Speed constrains are marked as on charts after route and FL input. The MCDU is indeed the Achilles' heel of JAR aircrafts.
On the other side you have any time the option - back to FSX A320....... :-)
All of the above plz, its about time!
Can i use the gnd handling for free with this plane the same as with the a330?
NO
