Homer.Simpson wrote:
To install the bss sound packed If understand correctly you have to remove the "sound3d" (backup it First) folder from A320/plugins/. Then put the "sound3d-1" from the bss soundpackage into the A320/Plugins folder and after that rename it to "sound3d".
This is slightly confusing. It means that the BSS install instructions are wrong!?!
I'm trusting JAR on this so I'll try it this way...
Wow
BSS instruction was done on beta stage (too early).
I see. Thanks. They might want to update the instructions.
I'm sure it's confusing a lot of people
27 (edited by laohu314 2016-10-31 18:47:47)
On my first flight with v2.7r1 I noticed that Descent (DES) mode and Open Descent (OP DES) mode seem to be swapped. In DES Mode the aircraft dips down at full speed VVS -3500fpm and more (leading to uncontrollable over speed), while in OP DES Mode the VVS seems more normal.
In previous versions this was reverse, i.e. OP DES Mode generated unrealistically high VVS
Did another flight (EDDM-EGLL) just now. Interestingly, the DES and OP DES now worked correctly. No idea what I did wrong yesterday...
I did notice, however, that the speed brakes do not deploy on the aircraft, i.e. not visually, when looking outside to the wings. The lever deploys in the cockpit and the message "spoilers full" comes on when deploying. I am also not sure if there is an actual effect on the aircraft performance, as in descent with N1 at 20.0%, speed does not decrease when speed brakes are fully deployed...
Has anyone seen this, too?
All in all, though, the A320 and the A330 are my favorite aircraft, hands down.
amischkowitz wrote:
Ok, thanks a lot smile
I didn't know that. It's perfect for the glass effect. For me I would like even a little more effect on the PFD and ND but that's personal gust.
But I notice that the two ECAM brightness knobs are inoperating. That's sad.
thanks for all
If so, please download this file and put it to /Custom Avionics/ folder instead of old file.
Good evening Mr Romanov
Thanks a lot for all your advices. It's work perfectly for BSS, lightings knobs and so on... smile Perfect
If you can, in a next updates it would be great a little more glass effect on the ND and PFD.
Thanks again
29 (edited by rynoosh 2016-11-01 02:31:33)
How do I install BSS IAE V2500 v3.0? There is no sound3d-2 folder with the engines folder inside for the Jar A320 v2.7.
30
Need delete exist sound3d folder and install new one.
Please contact me direct via skype - we will check this on your side.
Some requests if possible :
-NAV logos switches : isn't a two position switch ?
-would it be possible to have a range from 160 NM to 320 NM ?
-magenta indication of T.O and landing Inhibit on the ECAM like on the A330
-also possibility to have the same radio panel that on the A330 with interactivity with ground and flight attendant
-if possible 3 digits after the . on radio management panel
Thanks a lot
I'm guessing this is not a bug, but still has not been implemented yet.
The A320 increases thrust while in FLARE mode with the A/T active for landing, to compensate for the increase in AOA, which makes it float rather than maintain a smooth descent.
In reality the thrust should not increase at 50 feet while you start the flare.
The A330 has this feature correctly modeled, so any chance of having this in the next release? smile
Concerning the Side stick priority light , is it possible to have the red light for the pilot who left this one, with green light ?
http://jardesign.org/forum/img/m/1125/t/p1b0g4okq0u3q6nh17ah3041quq3.png
Thanks a lot
Sorry this is a Translate Massage!
Hello Mr. Romanov, I have been watching for some time but never really found time to report about it:
At the airport Salzburg LOWS (regardless of pay or freeware) and only with their aircraft A320 + A330 all versions.
With B777,B767 no Problem!
And indeed, a cut edge of two tiles goes through the airport you go over here spins everything:
In the PFD Display: A.Floor in green
Engines on max no longer controllable, etc helps only finish!
greats from Germany
Manuel
http://jardesign.org/forum/img/m/587/t/p1b0g6tlmkttiu3o17g1pumgle3.jpg
36
Hi Mr. Romanov, I did delete the sound3d file & installed the new for CFM engine sound.
My questions is for the IAE engine sounds. BSS instructions are not correct anymore after 2.7 release.
37
After several night flights I noticed that (for me) FCU with digits (included baro set digits) lack a little from brightness.
The same (in the glass effect option) for the both ECAM
Is it possible thanks to knobs to get them brighter ?
Thanks a lot for all incoming updates
38 (edited by stevehaines 2016-11-01 19:13:43)
The other day I wrote a note on this board regarding the cockpit colors of the updated A320 NEO (ver2.7 r3). I am writing today to acknowledge that I was mistaken in not remembering how the MCDU "dark/light" cockpit settings worked. I rediscovered that today and apologize for mistaking the light blue color as a "new feature". It isn't.
However part of my comment was in regard to the contrast or sharpness of the instrument displays in the new version. I am attaching a screenshot of each version to show what I mean. The version identified as JAR B2 7 B3 is the new updated A320. Please notice how much sharper and detailed the earlier model is, particularly in the instrument and dial displays. Both images were taken with no manipulation of the colors or lighting, just opening the model and selecting "quickstart" to illuminate the instruments.
As mentioned earlier, I do like the new "scrollwheel" dial manipulation feature of this new version. If you can revert to the earlier cockpit appearance I would prefer that. This is a case of, "if it ain't broke, don't fix it."
Also, I retested the performance of both versions and found no errors at all. Both perform properly and accurately. Any irregularities found earlier were due to my error.
I am using the BSS Sound Kit with the A320 NEO v2.7 b3. I am not able to raise or lower the volume of any sounds separately, either by using the Plugin Sounds 3D panels or the MCDU Sounds panel. All I can do to adjust sound levels is raise or lower my Mac volume. Is this caused by a faulty installation of the sound files or is there an issue regarding this version of the A320?
40
I experience the same thing
41 (edited by hades.esp72 2016-11-02 07:37:27)
Good day.
Are possible over QNH, Heading,  Speed, Altitude and Vertical Speed knobs, assign (comfort controls), left mouse click to push and right mouse click to pull?
Thanks so much.
Thank you! Will try to catch you tomorrow.
BTW I know that in the past looking at the repetition video we basically couldn't see the deployed speed brakes.... Or did you stop XP while aircraft on RWY?
44
First test flight with the newest v.2.7r1 EDDF - LOWI without any occurrence. now the A320 fly very smooth at high level and 45kt side winds. Aircraft swinging seems to be over! I have to made some additional flight to assert that we are getting closer to have the perfect and best airliner model of X-Plane.
Great job JAR
45 (edited by Yelmo 2016-11-02 09:26:36)
This happens to me yesterday as well. It looked like both modes were swapped.
Just click on upper zone between Captains PFD/ND and you can find what you are requested
http://s018.radikal.ru/i527/1611/eb/735718d9f1e2.jpg
BSS are aware of this and an update should be out in a few days.
Check their facebook page :-)
48
Press on panel at top between PFD and MFD and it will light up :-)
49 (edited by jmeleanor 2016-11-02 20:08:20)
Hi Mr Romanov.
First, Thank you very much for the fantastic work you've done on this A320 and the others products.
Just a Problem i have often with the flightplan; after some waypoints on the FMC, wich pass white during the travel,  all waypoints become green and on  the plane doesn't follow the flightplan and stop on a DECEL or TD waypoints.
I try to tell the plane to follow the next waypoint by the DIR function, but it doesn't work anymore.(there is no waypoints list at DIR option.)
I join some screenshots forexplain it.
Thanks for your help (Excuses me for my bad english.)
http://jardesign.org/forum/img/m/616/t/p1b0j9lqcvta841l1cuggfl3eh.png
http://jardesign.org/forum/img/m/616/t/p1b0j9o59t1r4k1iejjrl6uf1ijhp.png
http://jardesign.org/forum/img/m/616/t/p1b0j9oqd21fjl1dis16ig2fk12dd12.png
50
Thank you for the replies regarding screen contrast and reflections. I will experiment with the "secret spot" shown in the clip. Is this considered a JAR "Easter Egg"? : )
