Topic: a320neo JARDesign ver 2.7r1 WIN/MAC 64 bit (X-Plane 10)
ver 2.7 WIN/MAC 64 bit
WHAT NEW:
+ MAC OS Sierra compatible
+ New PW1100G Engines 3D model included (need to select by MCDU MENU)
+ Pause at TOD added (MCDU MENU Page 2)
+ Possible to unlock and then to open cockpit door
+ New cabin ("Sky interior") lighting system
+ New cockpit "Dark cockpit" lighting system (please use "Dark cockpit" option by MCDU MENU)
+ New cockpit manipulator system "mouse wheel control" (need to select by MCDU MENU)
+ New ground equipment set, include new lighting system
+ Working sunshields
+ Cockpit textures and details improved
+ Cockpit Integ.light/light system improved
+ New cockpit and cabin windows set
+ Visual Ice detector added, include icing effect
+ Few bugs fixed
+ Some PFD/ND details changes
+ Wipers operation effect and some rain improvements added
+ New cockpit “reflecting” glass effect added
+ New cabin windows textures added and fixed issue with “missing strobe glass” for cabin view
+ Fixed wrong left wiper handle orientation
+ Fixed wrong “Cold & Dark” Ground power and battery voltage indication
+ New controls for door switch and trimmer handle added
+ Possibility to control Flaps and Speed brake lever by mouse added
+ Some issues with wheel mouse control fixed
+ New ground Handling
+ Landing Gear tuned
- be sure, that you use X-Plane 10.50 or 10.51 (64 bit only, MAC OS Yosemite-to-Sierra or Windows 7-8-10)
FMS NAVDATA Update:
v.2.7 use NavData from ../X-PLANE 10/Custom Data/GNS430/navdata/ folder
- “a320/330 Native format” or (the same in fact)
and put new cycle to ..X-PLANE 10/Custom Data/GNS430/navdata/ folder
DOWNLOAD:
http://jardesign.org/a320/download/install/JD320.zip
New PaintKit (PW engines included):
http://jardesign.org/a320/download/pain … intkit.zip
if you use BSS sound pack, please delete exist sound3d folder and add sound3d folder from BSS. It can be named sound3d-1 or you can rename it to sound3d as you like.
