226 (edited by ctabuyo 2016-08-20 10:24:17)
Hello, I found a bug:
I´ve told the plane to make a direct to MABUX. But look how the screens look:
http://i.imgur.com/nISNm9l.png
227 (edited by hades.esp72 2016-08-20 12:51:22)
GA Track, not follow flight plan, only follows the current heading.
http://jardesign.org/forum/img/m/1123/t/p1aqk02e1l1pj213lr1v5712i5mmt3.png
228
Yeah I know. But that´s because it did´t get the direct to MABUX... It says VARUT.
and  an old problem and never settled by JarDesign, to me comes out flight plan not respecting the route points, sometimes it happens and sometimes not, hopefully in a future update.
230
I am having a strange issue. Every time I load the A320, my key assignment in x-Plane gets reset to ZERO, defaults. Nox axis assigned, no buttons. I am really clueless what to do. A330 is fine. Done a flight to Vancouver from zurich yesterday.
Thanks for help
231 (edited by ali.mazhari 2016-08-27 10:20:33)
I have issue with MCDU , when I have inserted the route for example OIAW - OISS  and I have corrected discontinuity but I can not see some information on MDCU such as height, speed.
please help me to fix this issue.
My A320 neo versio is 2.6
Ali
232
Did you enter a Cost Index and Cruising FL on the INIT Page as well as entering all the weights on the second init page?
233 (edited by laohu314 2016-08-27 13:10:44)
Thanks for help
I am using FlyWithLua (I highly recommend to anyone who hasn't done so looking into FWL). With FWL you can easily create a config.lua file for each of your aircraft. FWL will generate a file with all button assignments automatically every time you exit XP. THis file is then converted to a Lua script.
I am attaching the one I use for the A320 (to go with my Saitek X52 and other Saitek equipment).
After installing FWL, look in your plugins/FlyWithLua folder for the "initial_assignments.txt" file. That's the one to convert by just adding a couple of lines and renaming it. It's all explained in the FWL documentation
234
I already have reinstated the x-plane, and the A320. I have no signs of the weather in the instrument.Please help me how i will fix this;
http://jardesign.org/forum/img/m/3065/t … l1fsj5.jpg
235
Hi Sir on x-plane set the weather from the net.
236
And if you use anything but XP10.50rc3 you are out of luck because NOAA changed their URL for weather downloads which has been addressed in rc3. I'm not sure about 10.45, which may use a different weather source. Also, JAR uses NOAA as w weather source so it mayweed an update too.
237
Thanks for your answer, but I have always tick "get real weather from the network" check this at the beginning of the program. Also at the weather menu.
238
Thanks, i have XP10,45 and ahave not intall (yet) the NOAA.
239
mikri wrote:
New 2.6.1 looks fine, but:
- Engine covers, chocks and traffic connes are not removed (Shift + 1 view)
- display for QNH shows permanently 0000, altimeter and PFD are OK
- cannot fill From/To, reports that airport is not in database
Mike
Delete all files in folder \Custom Data\GNS430\navdata of your xplane folder .. i find it today and works for me !!
240
Guys I hope in your advice. Since last Windows10 update (2 days ago) I have big troubles using the JAR320/330. Basically the frame rate larks between 60 and 15 FPS in every condition and stage of flight. I get 60FPS and after half second 15...then 60 again after another half second. All SIM and NVIDIA control panel settings are unchanged and all other aircraft are working exactly the same as usual. Anyone has any clue?
241
Remove KB3176938 windows update - that fixed it for those who were seeing the slowdown.
242 (edited by psitulskis 2016-09-23 19:54:17)
I. Climbing to FL270 using OP Climb.
At FL210, with to (Managed) CLIMB mode.
1. When TC is reached, it is not FL270 (see the image)
2. I believe it should have slowed down or moved TC point further if unable.
p.s. FMC programmed with cruise LVL 270 and in FLIGHT plan it is also FL270.
Many thanks
http://jardesign.org/forum/img/m/1175/t/p1atc7sjq51skq4fn1be8krm12093.png
II. DES mode. FPLN says I suppose to be at ARSUP waypoint at FL282 but I was at FL260 already by ARSUP. I don't think that is correct.
243 (edited by domined39aniello 2016-09-23 20:46:19)
Many thanks
Hi Sir you put a Cost Index in to MCDU? The speed is high
244
1. You probably started your climbing too late. We see the aircraft in climbing situation thats is correct.
2. If you programed on FMCU FL270 how do you can be at FL282?
3. TAS 478 at FL 270 should be OK
245
As far as I know GA-Track mode means Go-arround so what's the point?!
246
Ali
Probably your FL was not appropriate and therefor not  accepted....
247
Does anyone else notice the A320 and A330 fish tailing in 10.50 - tail moving from side to side and plane wobbling constantly?  I know there are now winds aloft in Europe which are new to most of us and understand that turbulence are pretty normal.  However, the reaction of both a/c doesn't appear natural.
Not sure if this is a JAR issue or a 10.50 one.  I'd guess the latter.
248
check out the less_bumps.lua script in this thread:
http://forums.x-plane.org/index.php?/fo … -in-v1050/
I'm using it and the overall effect is great. Still turbulence when present but manageable. I highly recommend it. My personal opinion, not backed by any data, is that XP10.50 leads to an exaggerated effect of turbulence (and wind in general) on aircraft behavior. Maybe because winds aloft weren't available in previous versions and aircraft flight models have not been optimized for them.
249
Cheers, I'll give it a go.
250
Engine and system sounds are very low under OS sierra. And not only this product but with A330 also. I tried everything, reinstall, etc. Any idea?
Mac OS
A320
A330
