76 (edited by kyuui13 2016-07-28 17:56:55)
Given that, 41N30, 44N60, 46N50, 47N60 and 47N70 all enter in just fine, it only freaks out at 46E80 I'm kind of wondering about that.  I've used this format up till now with zero issues I don't "think" thats the issue, but will check it out.  As far as the DCT, that i knew, but i'm testing EFASS NG and it doesn't have the PATCO system in yet so it tends to drop those points; as I have said though, thats not a big deal.  The boat load of SASL errors and the mixture issue is the bigger ones.
EDIT:  Reloaded the plane just to start fresh did as you suggested with the FP and it still freaks out. it sends the FP to the wrong waypoint and adds well over 10K NM to the flight.  The SASL errors at the end of the log, i "think" are from me trying to clear out 4680E and try 46E80
KYUUI13 instead making a salad of WP (and as homer wrote not on FR) you should look at OnlineFlightPlanner and make your FP as it should be:
KPHX SID BCE J523 WANTA J54 TOU J523 YZP TR19 FRIED J804R MDO J179 SQA J501 BET J120 SPY G469 NYMPH R220 IXE Y88 DAIGO Y10 STONE STAR RJTT
Then you have to get the latest SID and STAR charts and get the latest AIRAC 1608 for you FMC . Then you get an airliner FP program..... (any other way collecting WP from any where is botchiness)
Considering I'm using the recognised PATCO system from the FAA, on Skyvector,  I am using a Flight plan "as it should be"  I have a sub to Navigraph for charts plus FMC data so i'm using the latest information.  If you'd like to learn about the PATCO system, and how it works (very similar to the NAT system) http://tinyurl.com/hqg5kyu will take you to the PDF from the FAA about it.  It turns out that 46E80, throws an odd error, while 46N80 will not.
Either way, the issue with the mixture effecting start up still exists.
79 (edited by ilankrt 2016-07-30 14:13:31)
I red just now about PACTO System. It is indeed very interesting, but beyond what I understand to be near real flight plans.
My solution to get the real feeling for preparing a flight is to use the extraordinary Dispatch System of SimBrief.com. More real than that? ...........
BTW I asked SimBrief developer if it is possible to add a download for JAR A320/330 FP format  .txt. A day later we got in on the list - kudos !!
I'm not sure what you mean by " beyond what I understand to be near real flight plans." because its an actual system used by the airlines to fly across the pacific. if you look at flightaware you can see them being used.  in fact AA27 which is scheduled to depart in about 6.5 hours already HAS its track listed.  As far as Dispatch systems go I have heard of SimBreif but don't use it, between flight aware, skyvector, EFASS NG and PATCO information I have what I need to run the flights.
Please, can someone tell me how to use the Ground  Handling, which I got with the A330. I only know how to use the pushback.
Hello how are you
Several problem for me:
- The screen does not indicate weather with NOAA weather
- The tail of the plane did enlightened than the right side
- The cockpit lights not working
- Exterior lights not very enlightened that can
Thank you for your answers
83
Not able to made on your own a google search?!
https://youtu.be/Km0U6beXz7Y
It is annoying that new X-Life user do not even bother to look themselves after how to do what ..
Then they ask questions without to give minimum of information about their computer, X-Plane version etc.
Before asking any question you have to read yourself the instructions, search yourself for further information and only after that asked for help.........
hello JD ,  I have installed and activated the whisker version A330 JD v1.3r2, but I have a problem, I can no longer turn on external power, making refueling, the plugin is not included in the downolad folder , the hand that is used to change the values and 'disappearance. How can I fix?
thank you
"HOW TO INSTALL:
(if you use v.1.3 b1, you not need reinstall r2)
  - be sure, that you use X-Plane 10.36+
  - Download more fresh version of «GndHandling» plugin from official
    board http://jardesign.org/forum/viewforum.php?id=29
  - activation works well with both MAC/WIN 64 bit"
Read the install instructions. Then you would have seen that you have to download the GND Handling as a separate download.
The update 1.3R2 for X-Plane 10.50 RC2 is really good. So far no major problems but of course theres always room for improvements. for example if you go above 300 kts the Autopilot disengages and your not even in the red zone. Also, the nav sources dont work except for APT display and there is no fix page on the CDU. The weather radar could do with some improvements as well but other than that, its a very good update for X-Plane 10.50 RC2.
As discussed many times before, you ARE in the "red zone" (MMO)... The overspeed tape is simply missing. I don't know why JAR still hasn't fixed this... This is why the autopilot disengages.
This happened to in a flight yesterday and today again. X-Plane 10.45 OS X please help urgently!
http://i.imgur.com/1NuKhyL.jpg
http://i.imgur.com/hXahOcY.png
Pase help!!!!
Did you change something on the rendering settings during flight?
If this appears go to plugins->A330->Settings and choose disable rain windows.
No, I didn´t change anything. It just appeared by itself after take-off.
Regards!
10.50RC3
El Capitan
A330 1.3R2
Glare shield lights seem to be not functional. Tried to use them underneath the glare shield but they were not operational.
Many thanks,
Dan
psitulskis wrote:
10.50RC3
El Capitan
A330 1.3R2
Many thanks,
Dan
Do you have HDR turned on in the rendering settings?  It's needed for some of the light effects.
Hi JAR,
Both of your busses are great and are lots of fun to fly! Thank you for contributing them!
I have got two things i want to Point out:
1. I would love seeing the beacon illuminating the engines and the wings during a night flight. Your a320 is already doing it and it would be great if your A330 could do it as well. Looks just great and so real.
2. and im not sure if that is your programming area or belongs to x-aviation. (this includes A320)
i have got skymaxx pro v3 installed and as soon i am flying into a cloud the strobe completely dissapears. would be so nice to see the wing dissapearing and the strobe illuminating the cloud around it!
However Keep up your work it is greatly appreciated!
Thanks a lot,
Louis
95
Everything is working fine in 10.50rc3 (which is the final) except the QNH will always flash in the STD mode rather than when it needs attention.  Also, the right click to take it to STD causes the entire screen to shift for a split second.
John
96 (edited by Metallist 2016-09-27 07:03:11)
X-plane 10.50 A330 1.3R3
Don't work the sound button on overhage (fuel L1, L2, R1,R2, BAT1, BAT2, bat APU, master APU SV, START, etc. ). The sound of the tumblers work.
Не работают звуки нажатия кнопок на оверхеде (fuel L1, L2, R1,R2, BAT1, BAT2, bat APU, master APU SV, START и т.д.). Звуки тумблеров работают.
97 (edited by jatar 2016-09-30 18:23:22)
Hi we are doing a review again of this aircraft, can you expose the changelog has the new version?
Fixes, what is improved in fmc...
Updated but still reading v1.3r2 in FMC
Hello JAR,
Do the problems associated with x-plane 10.50 include the failure of all exterior lights on v1.32 and 1.33. The interior switches seem to operate but the lights do not.
The lights on the A320 operate normally.
Thanks for both of these great aircraft and for any help
Hi, I still have the problem that the aircraft does not follow the flight plan. After reaching the FMS point it does not go to the next one, so I need to work on direct for each point.
1.3 r3 installed on Windows 10 machine.
