Topic: 11 Italian Airports for X-Life/FM
I have developed 11 set of files for X-Life/FM. I've tested and they are working.
Naturally all must be tested not only by myself.
Here the list:
LIBD Bari Palese
LICD Lampedusa
LICJ Palermo Punta Raisi
LICT Trapani Birgi
LIEA Alghero Fertilia
LIMC Milano LMalpensa
LIML Milano Linate
LIPE Bologna Borgo Panigale
LIRN Napoli Capodichino
LIRP Pisa San Giusto (this is a new version of already posted here)
LIRQ Firenze Peritola
For all but two (LIBD and LIRP) I did have used the X-Plane gateway scenery packages 3D latest.
I have tested with X-Plane 10.45.r2 and 10.50.b4 and latest version of X-Life/FM.
I did developed some other (not only italian) but some of them are not working alway giving me:
"MessageRed: Please turn On traffic before" x-life in X-Plane log but I do not know what is wrong.
Re: 11 Italian Airports for X-Life/FM
hi karterilla,
many thanks for your work. I know it´s a lot of work making taxi-routes (I have made about 15 to 20 airports), but i only have tested one airport and found many things that will not perfect work with x-life:
- make nodes as less as possible (read "tutorial" atc-routes)
- place stands very correct (in xlife the icon in WED is the FRONT of the airport not the middle)
- also place taxilines to the stands very accurate
- make correct definitions in gateeditor and radios
i have corrected your .dat and .txt files for LIPE and they work like it should be in xlife
Here the list:
LIBD Bari Palese
LICD Lampedusa
LICT Trapani Birgi
LIML Milano Linate
hi karterilla,
You been quicker than me to edit LIPE. Right now was editing that while i found you already fixed it.
Many thanks.
Wow, Thats a yuge amount of work you did! Thanks for your contribution, I'll def check it out!
Here the list:
LIBD Bari Palese
LICD Lampedusa
LICT Trapani Birgi
LIML Milano Linate
Thank you SirOTheOne for pointing me out what should be corrected.
Did you ever step in airport which it is not working after creating the ",dat" file.
I've 3 of them which refuse to work having only a line in XP log file saying Please turn On traffic before.
These are my very first efforts with WED and X-Life and I developed for myself but like to share.
Welcome everybody to use them and correct all the different files.
Please post the changes as for LIPE.
Thanx
corrected and adapted LIRQ files
in future, please less nodes and all available stands/gates.
great work
Thanx
corrected and adapted LIRN files
Thanx
Karterilla, I've checked LIBD taxiroutes and you done a extra work, since I already released LIBD with corrected exits and apron, according LIBD charts.
Here you can find the updated taxiroutes  for LIBD.
Just 1 point. When extract taxiroutes from custom sceneries, check always the airport charts, finding notes and drawing. This make you sure that the airport don't have wrong traffic flow.
Thank you very much.
Great job.
Tanks to all of you.
Will do.
adapted and corrected LICJ
Great job.
Will do.
Great stuff...thanks a lot from an italian pilot smile.
Any chance to get LIPH ( Treviso) and LIPZ ( Venezia) traffic? Thanks a lot
LIPZ it is not working in X-Life (together with LIEE Cagliari) whatever scenery I do use.
I 've spent a couple of days for each airports with no luck. It always keep saying I need to turn On traffic before while the plugin it is already been started uo.
Need to understand in which way X-Life can be logged to understand what's going wrong.
Will work on LIPH and other northern italian ones (XP gateway scenery pkg) as soon I do have finished southern italian (small?) airports: I do have ready (need people testing/check them; thanks to SirOTheOne specially and randyran for their suggestion) the following:
LICA LICB LICG LICT.
Will post them hoping they are a better effort then the first ones.
These are working but again for my way of using them, which cannot be perfect or the way it should be in the X_life creators view.
I do also have some other southern Med APTs already ready for debugging. Together with GCLP.
Ciao
13 (edited by SirOTheOne 2016-06-28 14:52:37)
Hi karterilla,
i already have made LIPZ and LIPQ and they work well. Design was i bit tricky
on LIPZ use V2 to ignore rwy 04L/22R (normally closed)
Ciao
Hi karterilla,
Ciao
WOW THAT'S GREAT.
In which way do you have LIPZ working? What scenery pkg did you have used?
Did you try LIEE? Even that one it not working for me same error after X_Life loads.
Later I'll post in a new thread the other 4 APTs and to make happy our friend even LIPH (I was working on that one some times ago and was almost - I said almost - ready to go).
Thank a lot.
Hope everyone can enjoy your contributions.
Thanx
15 (edited by SirOTheOne 2016-06-28 14:58:22)
use scenery which if had upload (ZIP-files)
on LIPZ there are 2 possibilities LIPZ.dat and LIPZ V2.dat (please read above)
rwy 04L/22R is normally closed and used as taxiway (see charts) and in reality it is true, too.
use V2 to get not to much traffic for one runway, because xlife doesn´t check it, that only one rwy is in use (it´s a small bug)
LIEE if have not tried
karterilla wrote:
Hi karterilla,
Ciao
WOW THAT'S GREAT.
Thank a lot.
Thanx
