Stefan wrote:Stefan wrote:I've found a situation, where a F-PLAN discontinuity cannot be cleared.
The route is EDDV SID WRB UN850 NATOR N850 TITIX UN850 TRA M858 SRN UM858 VOG STAR LIMJ
Initial departure runway was 9L and SID was WRB2Y, but ATC told be to change to runway 27C. Then it was not possible to clear the occured F-PLAN discontinuity .
Please check the video: https://youtu.be/1jGT4JV3qbo
As there are some users at the org forums reporting similar issues, I'd like to know if this issue is adressed and possibly solved for the next update?
In my experience, when the F-PLAN is entered with correct SID and STAR there is no problem clearing discontinuities. I would always advise to ignore ATC when you have studied the charts and know a particular SID and/or STAR is correct. Also, in the latest version you can request the runway you believe is right.
