626 2016-05-25 14:39:08 (edited by tommy0204 2016-05-25 14:42:55)
I was reporting these successful flights because ilankrt and I had CTDs at KJFK under the same circumstances which we also reported. So maybe the good people at JAR Design can compare the logs and crash reports to figure out what went wrong.
Yes, sure, I get all CTD reports and analyze it. If this CTD happen again and again, this may help me understand issues in my code, data structure, etc
628 2016-05-25 15:07:05 (edited by ilankrt 2016-05-25 15:09:23)
hi JAR!
X-life can use weather plugins?I use FS Global Real Weather but every time i arrive to vhhh will give error rwy and can't auto load AI Plane in airport!Sorry my eng so bad
Try doing like me. Disable FS GRW (take it out of the plugin folder) and enable X-Plane real weather. See how it works.
BTW, I cannot recognize anything on you images (too small). Next time send the of respective part....
630 2016-05-25 20:21:05 (edited by captbullett 2016-05-25 20:29:29)
where were the Log.txt ? you and ilankrt did not post any log txt did you. Oh, after I posted this you then posted a log txt...
631 2016-05-25 20:22:11 (edited by captbullett 2016-05-25 20:31:19)
laohu314 wrote:I was reporting these successful flights because ilankrt and I had CTDs at KJFK under the same circumstances which we also reported. So maybe the good people at JAR Design can compare the logs and crash reports to figure out what went wrong.
yes, but the two of them did not post log txt until I had to ask him to ...Yes after I post the above comment He post log txt
hi JAR!
I just tried the Real Weather plug in NOAA weather and it does not allow the X-Life plugin to load the Real weather, instead it loads the 'set weather uniformly over the world' so, there is a conflict in the latest update of NOAA weather. As, for the other weather generators i can not tell you since, i have not tried them.
hi JAR!
Not use plugins info and not care. XL just read real weather data from NOAA server and use it. If real weather is not equal some plugins weather - XL just not care about this. User choice - select weather system and plugin what get weather equal real.
634 2016-05-25 23:52:11 (edited by captbullett 2016-05-26 01:36:03)
tommy0204 wrote:hi JAR!
X-life can use weather plugins?I use FS Global Real Weather but every time i arrive to vhhh will give error rwy and can't auto load AI Plane in airport!Sorry my eng so badNot use plugins info and not care. XL just read real weather data from NOAA server and use it. If real weather is not equal some plugins weather - XL just not care about this. User choice - select weather system and plugin what get weather equal real.
Oh, Thank-you Now I know how to use the NOAA weather So,
1) when you start X-Life with the NOAA Real Weather or another Real Weather plugin running you will be asked to start X-Life a second time. so, click on the start button two times but only after prompted too.
2) let X-Life continue to load and then you can continue to set-up X-Plane and X-Life.
This is the [XPGFS] NOAA Weather injector for X-Plane. The forum ; http://forums.x-plane.org/index.php?/fo … er-plugin/
The Download site:
http://forums.x-plane.org/index.php?/fi … ent-170321
actual download site for NOAA Weather Plugin;
http://x-plane.joanpc.com/plugins/xpgfs-noaa-weather
the JPG show the placing of the files on the iMac
Thank-you for the information JAR,
Happy Flying ,
635 2016-05-26 03:21:05 (edited by captbullett 2016-05-26 03:25:50)
Good Day,
So, A CTD on this flight now the only difference is the new weather plugin.
and please note the error that was displayed in the log.txt for XL 599
Seriously?
Logs and OSX crash reports where filed at posting! No logs posted for successful flights, because - not useful.
Lighten up, man!
637 2016-05-26 10:31:33 (edited by pic 2016-05-26 10:32:02)
OKIE dokie...CTD
LFMN-LSZH, hand typed complete route into FMS (737 not accepting xlife auto into FMS), all ok then when told to continue taxi, bingo crash
latest beta xlife, 737-300 IXEG
logs attached
638 2016-05-26 10:53:03 (edited by captbullett 2016-05-26 11:21:37)
captbullett wrote:laohu314 wrote:I was reporting these successful flights because ilankrt and I had CTDs at KJFK under the same circumstances which we also reported. So maybe the good people at JAR Design can compare the logs and crash reports to figure out what went wrong.
captbullettSeriously?
Lighten up, man!
How do I say this one I am sorry I did not see the first post because, ilankrt had posted such long posts and yet if you look at his posts only after I complained did he post log.txt.
Two, by you posting the extra posts it only made thing confusing and this is why I had my attitude as far as lighting up, well some people listen and some people just don't want to and this again is a Beta testing Group it is not what you or I want done it is what the developer want's done and I am like a watch dog to make sure JAR development Group get good data so this X-Life App can be a good app and not one that people complain about that it does not work.
Third,How do you think this happens, Oh, by good data and a good original Beta Team that I have been working with and now there are some new members that are Public Beta tester that do not do what is asked of them and it makes the job of collecting data just that much harder because, they do not or will not follow directions.
Finally, The original Beta team has worked Very Hard over eighteen months on this project to make it one of the best plugins in X-Plane and I am not going to let anyone railroad the project just because, of not sending data or two just wanting to blog instead of really testing the project.
So the screen shot is just an example of the post that has no log.txt that caused the issue.
Happy Flying,
Good Day,
and please note the error that was displayed in the log.txt for XL 599Brian
That was just X-Plane CTD as I see from log.txt
captbullett wrote:Good Day,
Good-Day,
Thank-you, I will continue using the NOAA weather plugin .
Yes, I will continue to use the NOAA Weather Plugin.
Ok, I analyse logs and .dmp files from your and my CTDs, 2 issue was find in my code, fix it now. Also just fix a bug when pilot report runway vacation, but get message what RW not vacated (also was my bug with logic). As result - beta 8 with bug-fixing only. To update from beta 6,7 - need install .xpl files only. Thanks all for reports!
643 2016-05-26 15:40:33 (edited by captbullett 2016-05-26 15:41:57)
Ok, I analyse logs and .dmp files from your and my CTDs, 2 issue was find in my code, fix it now. Also just fix a but when pilot report runway vacation, but get message what RW not vacated (also was my bug with logic). As result - beta 8 with bug-fixing only. To update from beta 6,7 - need install .xpl files only. Thanks all for reports!
Thank-you, JAR I am flying last flight and will up-date, and Thank-you, Beta testing team for all the good work and the reports that lead to good up-date and code fix.
This is why we do what we do, it makes JAR able to find the issues in his code and then he can think on how to fix it, when it is not always just a fix but how to fix and write the code in the wright way so it works ... now time to test again ...
Happy Flying,
644 2016-05-26 19:37:22 (edited by Watauga 2016-05-26 19:38:04)
Flight from EDDM to LOWS.
Cleared for ILS approach to LOWS RWY 33. RWY 33 is RNAV per charts. Only RWY 15 has ILS at LOWS per charts.
XL: 1869 : ---+++--- ATC: N982AR, Identified, expect BADI1R arrival, ILS approach Runway 33, descend to FL 39
XL: 1878 : ---+++--- Pilot: Descending to FL70, expect BADI1R arrival, ILS approach Runway 33, N982AR
ATC said to descend to FL 39. Pilot response descending to FL70.
XL: 2779 : > ATC: N982AR, Identified, expect BADI1R arrival, ILS approach Runway 33, descend to FL 39
XL: 2779 : > Pilot: Descending to FL70, expect BADI1R arrival, ILS approach Runway 33, N982AR
645 2016-05-26 21:35:39 (edited by ilankrt 2016-05-26 21:36:40)
XL 1.8b A320 2.6
KDFW - KDEN
KDFW
1. As I initiating XL, the X-Plane ATIS is activated and I can stop it only by changing radio channel, but it appears again every time I click on DELIVERY, GROUND, TOWER !! - as I wrote about v.1.7b
2. ATIS/ATC text out of frame !!
3 asking DELIVERY for flight plan it says fault... and I have to read again ATIS before I get plan
4. Delivery advice to shortest RWY (17L) at KDFW without SID ?
5. Only few traffic in the air and on ground
KDEN
6. STAR DANDD7 don't fit ILS to RWY26 as it should (I have to fix route on fmc)
7. Approach stopped at FL90 instead to lead to FL70 for ILS
8. Poor Air traffic and only 3 aircraft on taxi ways...
Hi Jar,
i think there is a bug in 1.1b8
flying from LSZH to EDDF - ATC forced me to land on rwy 36, but rwy is not allowed to land (see EDDF.txt and charts)
see also pic and log
Hi Jar,
Yes, will check this.
So I work on add ability to request another runway for departure from Delivery. So I really dont know 2 point.
1.Do I need offer to select all Runway for request (all what marked for departure, like at screenshot) OR only Runways in use now (from ATIS info)
2.If ATC decision is negative - is this ATC answer is correct?
Sorry Eugeny,
it was my mistake - i had wrong rwys selected in Airport Editor.
sorry
Mike
SirOTheOne wrote:Hi Jar,
650 2016-05-27 17:57:35 (edited by lanmancz 2016-05-27 18:02:14)
Good news! I hope requesting arrival runway will be the next step in this direction. As for the question I would vote to be able to request any runway (for dep as well as arr). But I guess it depends on which basis will the ATC allow or deny this request. If the ATC will be programmed to deny a runway that is not currently in use then I guess there's no need to have the option there. But if the ATC would not deny these requests then yes, I'd like to be able to chose any runway that suits me best.
