451
bug in x-life logic -> see pics (LZIB)
CNF-566 is waiting on runway for taxi, while C172 is taxing to starting point
Please send log.txt so we can sort it out.
brian
452
Dewald wrote:
Morning Mr. Jar and team
I was just wondering about the FM car.
At destination when arriving at the parking slot, the car drives straight through the scenery (depending on the scenery off coarse). Would it not be possible for the car to rather make a U-turn (perhaps 10m or so before parking slot) and sort off drive off out of view.
Also. Sometimes when a runway is in use and you hold short (as per ATC instruction), the FM car is in the middle of the runway. I had an A340 run over my FM car yesterday. Hehehehe. Perhaps the distance between the car and your aircraft could be shortened.
Thanks for a fantastic plugin. Was it not for X-Life, I would have given up on X-Plane and reverted back to FSX.
Regards from a very happy X-Life Deluxe user.
when you send a report like this please send a log txt also this way JAR can look at what is going on also if you have a JAR aircraft in uses please send a box.txt also it is found in the JAR aircraft folder.
you might not think the log.txt is needed but here at JAR development we need the good and bad log.txt files please.
cmckjodi wrote:
I intend to fly under XL for the first time over the USA east coast region:
KMIA - KMCO - KATL - KILM - KRIC - KJFK - KBOS
It will be great if someone can also fly this route parallel to me, so we can change information about occurrences during our test flights.....
First test flight today from KMIA to KMCO using the newest version of XL and A330.
http://jardesign.org/forum/img/m/1591/t/p1aishmoo7l0kq4anpm1alg4125.jpg
What scenery do you use for KMIA? I tried using 2 from the scenery Gateway and created ATC taxi routes but none of them work. Have also used the included KMIA.dat  Planes do not appear nor does flight info window on the lower left screen. It's weird because all of my other airports work perfectly including lots of unverified airports. Very odd problem. Running windows 10 64 bit. Oh well I will try and make Tampa work. Good luck with the test flights, I like KBOS great airport to fly into
If I am not mistaken, 2014 I purchased from X-Plane.org the KMIA airport, but as I looked at the images yesterday it seems to be
now an updated version. Anyway taxi in the air and on ground works perfectly... and I saw KBOS its really great.....
454
Thanks! Yes, I know about this issue, it is in my task-list. Hope, someday I will improve this FMCar functions.
455
Test flight KMIA - KMCO
X-Plane, XL, A330 last version
Using iMac27 Mavericks
No crash
KMIA - I used an older version of this airport but it works also well. Air and ground traffic very buzzy. The only thing to mention is the initial position of the A330 outside terminal! (I chose a position change to gate E22 - recommended )
KMCO - needs a lot of libraries. I missed one of them and landed on odd place. After installing it, I got an error massage from X-Plane but the scenery is shown well. Very good traffic scenery and FM is guiding as it should be.
One thing to mention: leaving the runway, I need to get the aircraft further than the hold line. Only then I get taxi order from ground. Sometimes my aircraft was thereby too far from the correct taxi direction.......
456
For both LEBL and LEMG using photo scenery from http://www.spainuhd.es/p/descarga.html prevents traffic being turned on. Both airports work great until I include photo scenery in my scenery folder, then although activating traffic seems to work no planes appear, and if I try to go to ATC I am told to activate traffic first
Anyone else having problems with photo scenery, seems odd, but have tried eliminating al other plugins, sceneries, and it seems the photo scenery is the culprit...take it out and everything works again
thanks!
457 (edited by captbullett 2016-05-16 22:03:15)
thanks!
you must use the X-Life ready airports the map is here;
https://www.google.com/maps/d/viewer?mi … tAA_7MfME4
and as far as the photo scenery as you have just tested it is not working right now as for in the future I am not the one with that answer.
I've been using KMIA from FryPilot (v5.1). Works like a charm. I have 57 busy gates and ten aircraft moving at all times. I am working on improving the ATC Routes because the ones that come with the scenery are not conforming to the rules too well. Will publish here tomorrow.
If you don't get traffic check your gate editor and make sure the aircraft have enough space. Remove some ramps if necessary and make the size limits smaller (This is a recommendation from JAR, who is a genius, as we all know). It has worked for me in the past with any problem airport.
459 (edited by laohu314 2016-05-17 00:50:36)
I'm in! I will start on that route tomorrow (i'm based at KBOS). I have just set up my new iMac 27" (latest model full options). It is so much better than my MacBook before. Will also use the new A330 version.
460
No crash
I have experienced the same thing with ATC and FM car. Currently, the system doesn't realize that you have vacated the runway until you are pretty far away and I often go the wrong direction and can't find the FM car anymore. Then I just use the FM car plugin  to get a new one smile
461
I just purchased and activated X life deluxe and i can only have 50% occupancy of stands. How do i get it to the 90% option?
462 (edited by cartayna 2016-05-17 10:33:39)
Congratulations! is a very nice addon to Xplane.. !!! i have 2 problems: 1, the planes do not show up in my radar of the a320, and 2, there are very few airplanes in the activity of EDDM (for example, following exactly the same tutorial video made by you in youtube).. how can i change this?
Attachment icon Captura de pantalla 2016-05-17 a las 11.42.34 copia.jpg 635.56 kb, 148 downloads since 2016-05-17
Attachment icon Captura de pantalla 2016-05-17 a las 11.42.42 copia.jpg 906.54 kb, 148 downloads since 2016-05-17
Attachment icon Captura de pantalla 2016-05-17 a las 11.48.16.png 263.65 kb, 145 downloads since 2016-05-17
Attachment icon Captura de pantalla 2016-05-17 a las 12.32.15 copia.jpg 792.08 kb, 133 downloads since 2016-05-17
463
thanks!
Thanks for the response! at least it wasn't just me...but it is a shame,
hopefully the photo scenery issue can be resolved in a future update, I will keep my eyes on the forum
thank you!
464 (edited by Dewald 2016-05-17 12:49:02)
Strange --- Ortho works for me --- G2XPL
I must admit though. I don't use Spain UHD --- Perhaps VRAM issue
thanks!
thank you!
465
I have the same problem as you. I filed a ticket and I got a reply saying that those settings were the maximum and that is the highest amount of aircraft posssible. Does anyone know how to fix this?
466 (edited by captbullett 2016-05-17 14:20:56)
See two post and I have asked for the log.txt and bbox.txt so we can see what is going on.
but you say you put a ticket in so, JAR has said that it is the highest amount of aircraft then this is so, why you ask because,
each airport as a different size so a different amount of traffic.
second, we are not wanting anyone to have a FPS issue so, JAR has worked on making a plugin that works for everyone in x-Plane not just one person.
Third, if aircraft are not showing on radar this is radar not in the right range , and if the range is right then I will start a process,
1) go to EGLL this airport you should get aircraft and many of them not only in the airport but on the radar screen.
2) start X-Life fresh do not do this after the X-Plane has already been started after you have been flying this might be you issue you cannot start X-Life after X-plane is already open.
3) set your Real weather .
4) open you settings for X-Life and do not set to the highest settings let X-Life set the settings
    the only setting i want you to make here is at the top and it is a # value set to 89 in the very top box.
5) start X-Life and let it finish before you do anything else.
6) set-up your Flight plan and aircraft settings
7) call the ATC and ask for the clearance
8) by now the server should have loaded the aircraft into your system and now I want you to check your radar.
9) if you still do not have any aircraft you must send a log.txt box.txt and please a screen shot of the radar screen I do believe you but this is to document your issue.
Ps, EDDM is a very slow or should I say there are few aircraft at this airport yes for the size.
Thank you for your help.
I found this on the .org website and wanted to share now I also invited him over to are website to join in the fun with X-Life.
http://forums.x-plane.org/index.php?/fo … nt-1028140
468 (edited by laohu314 2016-05-17 14:18:05)
CTD at KMIA
iMac 27” (late 2015), Core i7, OSX 10.11.4, 32GB RAM, AMD Radeon R9 M395X 4096 MB
Saitek X52,  Radio, Switch and Multi Panel, TM Cougar, XP 10.45, JAR A330 1.3b1, XL 1.1b5
Attachment icon bbox_log.txt 118 b, 215 downloads since 2016-05-17
469
Is it possible for this setting to be 90% because it shows it on the deluxe purchase page and I bought it for that feature.
2) start X-Plane fresh do not do this after the X-Plane has already been started this might be you issue you cannot start X-Life after X-plane is already open.
Is it possible for this setting to be 90% because it shows it on the deluxe purchase page and I bought it for that feature. The stands setting to be 90% instead of 50%.
CTD at KMIA
Good day
you are using the wrong KMIA for X-Life you are using my friends, Frypilots scenery which is good but not for X-Life even though he was working on it he never finished up I had the same issue.
by Frypilot v5.1/Earth nav data/+20-090/+25-081.dsf (0 t
472 (edited by captbullett 2016-05-17 14:47:29)
yes very much so, I just don't want you to get a low FPS rate and you can always add but you can't take away ... so start off low and work up to where you see what you like and what your computer can handle.
I can only make it 50% at most and I am running about 45fps with x737 v5. I have i7 4790k 4.6ghz 16gb ram and 4b gtx 970. I have no option to put the stands to 90%. How can I change that?
474
I have no option to make it 90%
475
I got a reply from my ticket and they said 50%is the maximum. Is that only for this beta?
