426
Acei wrote:
Flew KBOS to KJFK in the A330.  Only issue I noticed was that you can't export the flight plan from XL to the A330.  Works fine on the A320.
A330 ver 1.3 beta 1 ???
427
Test flight LEMG  - GCFV,  X-Life 1.16, A330 v.1.2r3, latest X-Plane version on iMac27 Mavericks
No crash.
LEMG:  X-Plane warning  - cannot be installed !?, X-Life is functioning well...
GCFV: Low traffic frequency ......
Question to JAR what is new in A330 last version (we must know for what we are looking for in the test flight)
Question to JAR and pilots/experts: I forgot for what purpose I need the Gizmo64.plugin. It lies a long time in my plugin folder and maybe it is not necessary any more...... ? (needed together with FlyWithLua ?..)
330 1.3b1 have improved MCDU FlightPlan (check it during regular flights with SID/STAR), Flightplan can be imported to 330 from XL, animated pilots in cockpit (external view), News instant messages system, improved some cockpit objects and textures.
428 (edited by captbullett 2016-05-14 22:09:02)
No SID out of KORD using the new A330 log.txt to follow but the Bluebell working good some issues with transition from hand off in the ATC and you will not see it in the log but it is in the visual display of the X-Life and the way the hand off goes in holding short for a non-bussy runway.
and the route; KORD to KMIA
when I got to KMIA all the Bluebell aircraft were in the airport and the display of the airport was as it should be, I did have to do a GA, the third GA I have ever had to do but again no real issue except with the Aircraft I need to know How to set the throttle so I do not get overspeed when I do a GA with a FL of no more than FL50, now this is my issue and not the X-Life issue or the4 aircraft so, any help from pilot or ... would be nice...
very good job JAR and Beta team.
429 (edited by captbullett 2016-05-14 22:48:36)
No crash.
good day,
First after reading your log.txt you need to run your X-Plane installer because your re-cuts are in-need of repair
this might solve some of your issues.
Then you need to up-date your RE Library to fix this issue ;
Unable to locate object: RE_Library/Fire_station/Type_2/left_hand/4_bay/open/Firestation2_L_4_ocr.obj
GISMO 64 runs many things go to there web page and do some research and you will find out what it runs ...
but I would not get rid of it or make any changes to it it runs in the back-ground...
this is your Gizmo working ; G64:  50.896: Livery Details:
G64:  50.896:   Folder: (Aircraft/2 Normal size Jets/330_JARDesign/)
G64:  50.896:     Name: ()
Ps, if you want your silver linings weather plugin to keep working you do not want to mess with you Gizmo64 !
So, if you can fix these issues you will have a better time flying ...
Anyone else have an issue with KMIA Miami international using windows 10? I posted my problem earlier. Traffic at the airport will not appear nor will flight info on the lower left screen. My machine is fairly new and 64 bit. All other airports work fine using the latest version of X-Life 6 with Bluebell packs. Have tried the default included KMIA.dat and XP default and a Gateway scenery. None work. Just want to rule out some variables and determine if this is truly a Windows issue or a bug possibly with X-Life. The log states an error saying plugin is not a WIN32 application, but then reading on further the plugin opens as WIN64 application. Does the XPUIPC possibly need to be updated? All other airports display traffic normally. Can the KMIA sceneries I have used be corrupted from the Gateway? Logic seems to point to that or is it possible that X-Life just can't read KMIA using Windows 10. If someone can verify that KMIA traffic works on windows 10 with a Gateway or default scenery, then I know I can rule out those 2 variables as a cause. Logs are posted below. Thanks for anyone's help and Brian who had earlier suggestions. cmck
431
X-Life beta (BlueBell) 6 ver 1.1crash:
JAR A330 1.3b1
LFMN-LEGE
Everything normal until arriving at holding runway 4L (as directed to)
Held for 15 minutes and I decided to takeoff anyway since 15 minutes is way too long...
After retracting gear, atc says continue taxi, I then press repeat and then crash.
all logs attached
432
No, didn't realise there was an update!  How did I miss it?
Installing the update and will try again.
433 (edited by jcdp 2016-05-15 11:04:03)
I use W10 64 bit and have no issue with X-life traffic in KMIA (see attached picture)
I have used KMIA from both payware and freeware scenery ...
http://jardesign.org/forum/viewforum.php?id=21
435
Strange thing show up, I upgrade XL to 1.1b6, but every time I vacated from the runway of the ARR airport, the ATC will change to the departure patern, and ask me report hold short and then line back to the runway.
436
HI
Starting a flight from GCRR to LEMG I launched X-life but it has been impossible to create a flight plan ...
Each time I clicked on flight plan icon I got the message " turn on X-life before" ....
see attached log.txt
437 (edited by captbullett 2016-05-15 15:58:55)
JAR A330 1.3b1
LFMN-LEGE
all logs attached
this is what you need too do when you are told to hold short,
1) open your radar so you can see the other aircraft in the area and change the range 50NM
    this will show you the aircraft inbound to the runway that you are going to be taking off from.
2) close the radar screen and open the ATC, then let it close and wait for the ATC to give you clearance.
    This process works for me when I get a command hold short and you will get a CTD if you do not wait for the ATC to clear you from the hold short since, the string command is broken in the ATC.
HI
For testing reasons please change your language to English as you have an Error message in you language area.
ERROR: language file line 'Video is recording! This message will NOT be visible in the movie.==== Enregistrement vidéo! Ce message NE sera PAS visible dans le film.' does not have the same leading spaces.
ERROR: language file line 'm====m' missing right side translation.
ERROR: language file line 'bleed air: right engine==== prélèvement air: moteur droite' does not have the same leading spaces.
ERROR: language file line 'Water-Way Takeoff    ====Décollage Hydro-Base     ' does not have the same trailing spaces.
ERROR: language file line 'Fuel pumps on.==== Pompe carb ON.' does not have the same leading spaces.
ERROR: language file line 'com-port====port-com' is a second translation of com-port====port-com
ERROR: language file line 'PRESSURIZATION====PRESSURISATION' is a second translation of PRESSURIZATION====PRESSURISATION
ERROR: language file line '#====#' missing right side translation.
ERROR: language file line '.====.' missing right side translation.
if you issues stop then your issue is in the language if not is something else but i would start here since the X-Plane language and X-Life language is done in English.
439 (edited by laohu314 2016-05-15 16:29:26)
No crash.
AFAIK, the Gizmo64 is installed with SkyMAXX PRO and doesn't get removed when you uninstall SMP, at least thats what happened to me. Nothing to do with FWL and not needed for FWL.
440
HI
Hi Brian
From the first day I used this language and X-Plane and X-life are working nicely ...
For all other airports (JAR verified) I have not this problem except for GCRR where when I want to create a flight plan I got the message "You should turn on X-life before" ...with X-life is alreary on ...
Whole log text is in English ...
and I use English when I play  so I do not think the trouble comes from language ...
HI
Hi Brian
Ok, then it is the airport can you re-download the airport if you have not done so, As I just had an issue with KFLL and a runway not show up on the MCDU on the A320Ne and there are all kinds of little issues we have to work through and with X-Life it a whole new  world for us as fare as testing all the airports that are getting converted.
Ps, Thank-you for your help and work on the project.
442 (edited by captbullett 2016-05-15 17:24:05)
as I was saying in the post above the ATC cleared me to use 09R at KFLL to KEWR and the runway did not show-up on the MCDU list.
first time I had this happen to me.
Since this is a Nav data issue JAR I am sending you My Nav data the ATS.Txt ...
should help you sort out any bugs.
Attachment icon cycle_info.txt 646 b, 200 downloads since 2016-05-15
Attachment icon Screen Shot 2016-05-15 at 12.52.28 PM.png 664.02 kb, 148 downloads since 2016-05-15
Attachment icon Screen Shot 2016-05-15 at 12.52.36 PM.png 128.55 kb, 141 downloads since 2016-05-15
443
This is one greatly needed and apprecaited add on for XP, thanks for making it a reality!
I noticed a drastic drop in FPS at airports, using BlueBell packs using latest XL beta from the permalink. I go from ~50 to ~20 when XL is turned on. The air traffic density setting in XL does not seem to affect FPS. Point of view (insde, outside, zoomed in or zoomed out) also does not seem to affect FPS, may be 2-4 at the most that I noticed. Aircraft also does not seem to affect FPS much at all, as I am writing this I am testing with 320neo_JARDesign (V2.6r2). When I turn off XL the FPS do not return to ~50 but do go up slightly to ~22. If I restart XP only then FPS will return to ~50. I realize that Ai aircraft would eat up some FPS but 30FPS drop, does not seem like it should be this big of a drop? No errors on screen or in the log.
Specs:
i7 5820k
NVIDIA GTX970
32GB DDR4
500GB Samsung EVO SSD
MSI x99s SLI PLUS MB
Cheers
I7-5820K 4GHZ (OC) | GTX1070 8GB | 32GB DDR4 | 512GB SSD Samsung 950 PRO .M2 x4 | MSI X99S SLI PLUS | WIN10 x64 PRO
"If only I could stop flying toy air planes..."
444
JAR A330 1.3b1
LFMN-LEGE
all logs attached
Hi Brian, thanks but I'd tried that..several times while waiting. I watched as planes made their line up and final as well as one doing a go-around lol. Finally, when two planes were way out there, I said I'm going for it and of course the crash after clicking atc response.  I'm thinking maybe I put too many BlueBell ac into the mix and atc just concentrated on them instead. I'll try a new approach (no pun intended lol).
ciao
445
Morning Mr. Jar and team
I was just wondering about the FM car.
At destination when arriving at the parking slot, the car drives straight through the scenery (depending on the scenery off coarse). Would it not be possible for the car to rather make a U-turn (perhaps 10m or so before parking slot) and sort off drive off out of view.
Also. Sometimes when a runway is in use and you hold short (as per ATC instruction), the FM car is in the middle of the runway. I had an A340 run over my FM car yesterday. Hehehehe. Perhaps the distance between the car and your aircraft could be shortened.
Thanks for a fantastic plugin. Was it not for X-Life, I would have given up on X-Plane and reverted back to FSX.
Regards from a very happy X-Life Deluxe user.
446 (edited by ilankrt 2016-05-16 10:29:52)
I intend to fly under XL for the first time over the USA east coast region:
KMIA - KMCO - KATL - KILM - KRIC - KJFK - KBOS
It will be great if someone can also fly this route parallel to me, so we can change information about occurrences during our test flights.....
First test flight today from KMIA to KMCO using the newest version of XL and A330.
http://jardesign.org/forum/img/m/1591/t/p1aishmoo7l0kq4anpm1alg4125.jpg
447
Hi Brian
Hi Brian
I followed your recommendations and have redownloaded the Airport GCRR and reinstalled it ...and ...
eveything works perfectly now .
Thanks for your help
What scenery do you use for KMIA? I tried using 2 from the scenery Gateway and created ATC taxi routes but none of them work. Have also used the included KMIA.dat  Planes do not appear nor does flight info window on the lower left screen. It's weird because all of my other airports work perfectly including lots of unverified airports. Very odd problem. Running windows 10 64 bit. Oh well I will try and make Tampa work. Good luck with the test flights, I like KBOS great airport to fly into
449
bug in x-life logic -> see pics (LZIB)
CNF-566 is waiting on runway for taxi, while C172 is taxing to starting point
450
pic wrote:
JAR A330 1.3b1
LFMN-LEGE
all logs attached
ciao
there is only so many aircraft in the library so, it is not the issue this is the timing and X-Life as I said when you are told to hold and you do not as soon as you do not you break the string in the ATC programming and it will Crash you.
But now I would say you need Mr JAR's help and escalate this to Skype him if you can.
